"FREE" can get expensive.
Quoted: 640 Post(s)
Liked 1,311 Times
A week or so ago I posted this '78 Peugeot UO-9 parts bike I got for free in the "saved from the dump" thread. I started stripping it today and soon began to wonder if it was worth saving........
Under those nice red Sakae dust caps (which I need for another bike) the Nervar crank is held on with 16mm crank bolts, I've read about them on here but this has been my first hands on experience, until now I'd always been lucky and only had to deal with 14 and 15mm. I'm not grinding down one of my Snap On sockets so I ordered a "cheap" thin wall 16mm spark plug socket, hopefully I won't have to grind it but if I do no big deal. I could have gone to the local farm store or parts place and bought one but I have to wait for the Bicycle Research CT-3 freewheel tool from Greece anyway so no rush. The socket will get here first anyway. And why do I need a Bicycle research CT-3 freewheel tool you may ask?
Because just to keep things interesting it also has a 24 spline Maillard freewheel, one of the few I don't have a tool for. It feels pretty good and I'll use it on something else so I might as well have the tool. Plus I have 3 Gitanes I haven't torn into yet so I may need it again. On the upside it's screwed onto a nice Sunshine rear hub.
Last and actually "least", the head tube is so short my headset cup removal tool couldn't expand to catch the edges of the cups so I had to resort to using a screwdriver and mallet. The cups came out unscathed but the same can't be said for my now handleless screwdriver. At least it was a cheap one.
It's a real "pig" of a Pug but it does have some good pieces under the crust, I may even break even by the time I get it all stripped. Hopefully it's a French threaded BB, not Swiss. So, as you can see "free" isn't always free.
Likes For Murray Missile:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 965 Times
Yes, I have taken dozens of "free" bikes I have picked up directly to the co-op for this exact reason. There the bike can get "free" donated consumables, and "free" (volunteer) mechanics time. Those donated bikes can end up helping someone without transportation become mobile, get to work, or whatever. I volunteer at those co-ops too.
But if I take on such a "free" project, I usually end up upside down. Free bikes tend to also be neglected bikes, and will need tires, saddle, pedals, fresh cables, housings, bar tape, chain, and more. And once finished in my market, the value will not cover the consumables expense.
Now sometimes those free bikes can yield a part of two that I can rehome. Then it can work out financially.
By the way on older French bikes, particularly the lower end ones, I hope to find Swiss bottom brackets. I've got three in the queue right now, two with Japanese Swiss BB, one with a Campy Swiss threaded BB.
I ground down a cheapie 16mm socket. But I have since misplaced it, so I will have to grind another. The worst recent example is someone replaced the non-drive side arm on a Stronglight with a Sugino arm, but kept the 16mm BB bolt. Not fun. Plenty of room for that 16mm bolt in a 23.35mm Stronglight arm. Not nearly enough room in a 22mm Sugino arm.
Likes For wrk101:
feros ferio
Quoted: 1394 Post(s)
Liked 1,336 Times
I did grind down the walls of a 16mm socket for a TA Professional crankset I used to own, and I still have the socket in my toolbox for the next time I encounter a crankset with a 16mm bolt.
I do agree with the general theme of the thread, that some bikes are indeed "free and worth every penny," or free but of negative value.
Quoted: 640 Post(s)
Liked 1,311 Times
I've had the same experience fixing up free and seemingly "cheap" bikes and being upside down in them at the end but then that's my general modus operandi anyway, buy high, sell low. I just chalked them up to "stress relief", much cheaper and healthier than alcohol and cigarettes. Even when they fight me like this one.
I had an old partial set of Craftsman metric sockets with worn out 13 and 15mm sockets and peeled chrome on the others so I bought a new Snap On set and gave the old ones away a few months ago........ C'est la vie.
It's my understanding this Nervar crank is 22mm, I have a couple Stronglights and TA Specialties cranks so I'll save the 16mm bolts for one of those. They're really nice chrome bolts, might as well use them.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,320 Times
There are worse things to spend money on than a "free" project bike.
Likes For Chuck M:
Yep, free is never free. I'm currently working on a "free" 1960s Capo (alone building new wheels will be expensive!) and a "free" Dusika 26" conversion, now trying to find italian size cotter pins for not-crazy money.
Quoted: 604 Post(s)
Liked 1,064 Times
Yes it can, got a free crashed Bianchi from a mech at one of my LBSs, he said it was my size, it was, or close enough, largest one they made, 1700 dollars later I had a bike.
Tim
Unfortunately the original fork did not survive
1982 Champione del Mondo
Tim
Likes For tkamd73:
I don't know.
Quoted: 321 Post(s)
Liked 860 Times
yep, the frame whether free or very inexpensive is just a money pit. It's fun though.
Likes For RB1-luvr:
Quoted: 604 Post(s)
Liked 1,064 Times
For YEARS I have tossed around the thought of building up something off of an old Schwinn Typhoon frame, but I'd add up the cost and go on to something else.
Then it finally happened, I stumbled onto an old Typhoon frame. Free. I passed it up at first because I knew what it'd end up costing me. But the draw could not be ignored. I was telling a friend abotu it that evening and as soon as I finished the story I went and got it.
Just the frame. I was leaving town the next day for a trip. But before I left, I found a chain guard and fork for it on ebay. Right color, right amount of wear. Overpriced... but when are you going to find this stuff in the right color? I bought it so it wouldn't be gone when I got back.
I decided I needed a two speed hub. They seemed to cost $100-$200, but then I found an old Schwinn Breeze for sale. It was overpriced, but it had a two speed hub. I paid $75 for the entire bike, thinking I had paid too much, even while I was rebuilding the two speed hub I was planning on spending $100 on. Funny how that works. All the hub needed was TLC by the way.
Buying this donor bike really got things rolling. Long story short, in the past few months I've bought 4 old bicycles and spent literally hundreds on new parts.
And the Typhoon that started all this nonsense?
I didn't use the fork and chainguard I over spent on. I've ridden it once. And I'm pretty sure the two speed hub is going to get pulled from that to put into a '62 Schwinn Racer frame I got (with fenders and a chainguard), for $15. Which means I'll need to find another donor bike/hub for the Typhoon. Maybe a 3 speed coaster this time? And I still want to find a 3 speed '62 Racer. To go with the two other Racers I already have I suppose. It would appear I am developing a "thing" for old Schwinn 3 speeds.
I also started volunteering at the local bike co-op when searcing for parts/bikes led me to ther site again. Yesterday I rebuilt an old Schwinn Hollywood someone had donated, everyone else was gravitating towards the modern stuff...
I'm positive none of this would be happening if I hadn't found that "FREE" Typhoon frame!
Likes For DesmoDog:
Quoted: 634 Post(s)
Liked 444 Times
Cool Pug, @Murray Missile Is the plan to build it back up or are you stripping it for parts and moving along the frame?
There's a saying in the motorcycle world that the most expensive motorcycle is a free one. Free bicycles are similar in that they always need something but they are at least a lot cheaper to fix than motorcycles.
Quoted: 640 Post(s)
Liked 1,311 Times
I finally got the crankset off and just pullled the BB, it's a Nervar BB, can't tell the overall condition until I get the petrified tar out of the cups but the axle looks good. Too damn cold out there to mess with any more today. It is, however, BSA threaded not French so it goes in the BB collection. Since I last posted though I came across a brand new set of French threaded cups in a box of parts. I have no recollection of buying them but I surely have the right axle in my stash to use them in the bike I was wanting the BB for. I'll pull the freewheel tomorrow and pull the hub out of the wheel.
Quoted: 1372 Post(s)
Liked 1,755 Times
"Free can get expensive" and it does so almost every time. Absolutely!
Free...
...$550.00 later...
Free...
...$550.00 later...
Likes For randyjawa:
Quoted: 634 Post(s)
Liked 444 Times
For some reason this thread kept coming up with an error message the past few days or I would have replied sooner. To answer your question, it is strictly a parts bike, I had toyed with the idea of putting it back together with a set of SS/FG parts I have and trying to find it a new home but it's even rougher than I first thought.
I am sure you could find someone that would want that frame for a SS/Fixie. I have been able to offload complete single speeded Schwinns for ~$200 that were previously derailleur clawed bikes. I am sure you could get $50 for the frame. The hipsters (speaking as an old hipster myself) seem to love Pugs.
Quoted: 640 Post(s)
Liked 1,311 Times
Quoted: 557 Post(s)
Liked 419 Times
I never hunt for free bikes that are advertised.
They are always utter crap and never worth my gas.
A lot of folks also just leave their free items outside and won't hold anything for you. They don't care who grabs it first. It is sure fun wasting gas and time and adding mileage to your vehicle.
The only way I end up with free bikes is when I see them tossed out while I am already driving around on another errand. Here I am not wasting gas, only about 30 seconds of time stopping to load it. Almost all of these go straight into the donor pile section of my property. Having loads of land makes this possible.
Paying $20 or $40 for an indoor stored bike that the seller will hold for you gets a bike that is ten fold better across the board.
PeopleCode delaminator
The majority of bikes I've dragged home over the years meet that description. The ones that didn't? They weren't complete or intact.
Enjoy your therapy-by-disassembly!
Likes For RandolphCarter:
