Shimano Tiagra - Expanding Cassette??
Hi,
I have a 10 year old roadbike that is kitted out with a Shimano Tiagra groupset. It is 50/34 on the chainwheel and 11/28 (10spd) on the cassette. It is in pretty good nick but don't really want to spend lots of money upgrading ( I would rather put that towards a new bike when the time comes). I have a trip coming up with a few tasty gradients over a few days. So question: Is there any way I can expand the rear cassette to incorporate a bigger granny cog, say a 32t (or a 30t), without having to buy a new groupset / lots of new parts? Is there something similar to the 'oneup' system where I can take one sprocket out of the current cassette and replace with a 32t sprocket in the cassette? Or can I replace with an 11/32 cassette only (if I can get one) without buying a new shifter/derailluer/chain etc? I understand the issue with the cage length, but if I only used a new 32t sprocket whilst in the 34 chainwheel upfront (and adjusted the B screw) would that work? Or am I just barking up the wrong tree?? Just trying not to spend a lot of money.
Many thanks in advance
Cheers, Jason
Cheers, Jason
Quoted: 1819 Post(s)
Liked 1,695 Times
Which version of 10 speed Tiagra do you have? There are two, 4600 series and 4700 series. If your shift cables are concealed under the bar tape you have the 4700 series version. You will have to verify if your rear derailleur can access a larger rear cog, I don't think that the 4600 version is able to handle a cog that big and the 4700 rear derailleur which can isn't compatible with a 4600 shifter. Not all is lost however because a 4600 shifter will work with a Shimano 9 speed rear derailleur which will allow cogs even bigger than 32 teeth. First thing is to determine which version of 10 speed Tiagra you have before trying to make the changes you want to do
Likes For alcjphil:
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Hi,
I have a 10 year old roadbike that is kitted out with a Shimano Tiagra groupset. It is 50/34 on the chainwheel and 11/28 (10spd) on the cassette...Is there something similar to the 'oneup' system where I can take one sprocket out of the current cassette and replace with a 32t sprocket in the cassette? Or can I replace with an 11/32 cassette only (if I can get one) without buying a new shifter/derailluer/chain etc? I understand the issue with the cage length, but if I only used a new 32t sprocket whilst in the 34 chainwheel upfront (and adjusted the B screw) would that work? Or am I just barking up the wrong tree?? Just trying not to spend a lot of money.
Jenson has an 11-32 cassette on sale for $36.99.
They also have a 10-speed chain for $20.79.
About the Tiagra rear derailleur.
If it's the RD-4700-SS (short cage), the max. cassette spec size is 28T.
But plenty of people use an 11-32 with a short cage derailleur.
Just avoid the "big-big" combination, and you'll likely be fine.
Likes For terrymorse:
Hi Terry,
Many thanks for the reply and advice. That's great, and thanks for finding the cassette, I was struggling! The video is very helpful!!
Very much appreciated
Cheers
Cheers
Likes For Walshinoz:
Quoted: 6195 Post(s)
Liked 4,810 Times
Pull up the hood on one of the shifters and the model number will be there on one side of the body or the other.
Likes For Iride01:
Likes For alcjphil:
Liked 4,810 Times
See you can teach me new things. <grin> Thanks.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
You can also look at the wolf tooth derailleur extender. I have one for 32 tooth cassette for my short cage Ultegra derailleur. Have not made a trip to the mountains so not used it yet.
Likes For biker128pedal:
