What's considered better? N600 or Campy Triomphe
Quoted: 1324 Post(s)
Liked 927 Times
Hi there. I'm going to thin out my bicycle herd. I have a couple of larger frame bicycles (large for me anyway) and one of them has a complete Campagnolo Triomphe groupset on it. I was thinking about keeping that groupset and replacing it with a Shimano N600 groupset save for the rear wheel hub. this is the groupset that came out after the Shimano 600 Ex but just before the 600 index groupset. This is not the Golden Arrow groupset.
So, which of these two groupsets is the more desirable or better performing one, the N600 (non-idex) one or the Triomphe one?
Thanks and cheers
Thanks and cheers
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Not a Shimano fanboy, but Shimano 600 derailleurs run circles around Campagnolo Triomphe. The other Triomphe components are pretty nice, but the Triomphe crank has a 116mm BCD which limits chainring replacement options.
Likes For JohnDThompson:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,490 Times
Triomphe is great except for the rear derailleur. It's just a little clunky. Instead, use a Victory in the rear.
I like the look of Triomphe hubs/skewers too, but the races aren't Record quality ... and they may be on the heavy side. Still, they'll probably last forever if you take care of 'em.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
I think the frame's pedigree can tip the scale too. What is it?
Quoted: 3464 Post(s)
Liked 2,831 Times
"save for the rear hub" , Hmmm. Not sure exactly the implication.
As stated, Campagnolo has uncommon chainring bolt circle. Nicer finish.
Better brakes, better levers.
Rear derailleur performance goes to Shimano.
Liked 927 Times
Cheers
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Campy Rear Derailleur Geometry
SR 4001
980 - Precursor to the 990, Triomphe and Victory RDs
990 Precursor to the Triomphe and Victory RDs
Early Triomphe RD
Early Victory RD
From the front side they look very similar. The rear of the Victory RDs have a very poorly designed part that works like the angle adjusting screw on some derailleurs. The part is made of aluminum and gets easily munged.
Frank Berto RIP got on Campy's bad side. One of his comments was to the effect that NR rear derailleurs were very well made and would shift poorly forever!
As JohnDThompson mentioned, Shimano RD run circles around Campy stuff until they finally gave in and started using dropped parallelogram designs.
Miele Man If it's just the rim that's split, why can't you just have it replaced???
In the mid 80's or sometime thereabouts, Shimano started using a somewhat transparent brown grease. If a Shimano hub is packed with that original factory grease and still spins smoothly, I leave it alone! It never dries out like the white grease Campy used.
verktyg
Chas. ;-)
Chas. ;-)
Liked 927 Times
Triomphe and Victory have the same pivot and cage geometries which are almost the same as the last NR and first SR derailleurs. Campy adopted the cage geometry of the 2nd generation 4001 Super Record with a published 28T FW cog capacity on the Triomphe and Victory RDs..
Snipped
Snipped
Victory and Triomphe cones cups and axles were the same as those used on Nuovo Tipo hubs... 2nd tier quality but the better NR parts will interchange.
Snipped
verktyg
Snipped
Snipped
Snipped
verktyg
I have this other Cammpagnolo rear derailleur that has that same type of toothed derailleur adjustment except that it broke rendering that derailleur useless. Are those toothed pieces available as a replacement part anywhere? Here's the derailleur. Note in this image that piece hasn't broken yet.
Thanks and cheers
Campagnolo fanboy here. This is my opinion, meaning that your experience is yours, and my experience is mine. The old NR, SR, etc. before parallelogram design shift well, and run very quietly provided the gear set is closely spaced. With the correct derailleur hanger length, the NR will accommodate a 28t sprocket. Just don't expect to run a 12-28, more like a 15-28 is reasonable, which is what I ran on my Habanero cross frame. Shifted well, and the gearing was just right. All of it shifts well on corncob clusters.
señor miembro
Liked 6,490 Times
My Victory RD cracked at that adjustable stop piece too, but I just used some JB Weld on it. Works great.
Liked 2,831 Times
Thanks.
Thanks and cheers
Thanks and cheers
and I will comment that my early 980 rear mech with the black bolts shifted really well, granted my largest cog was a 24.
if I did not like the appearance of the Nuovo Record so much, ( old admiration from when I was very young ) I would have left it on.
i vote fix the damaged rim too. Ensembles always fetch more as a matched set.
Old fart
Liked 3,401 Times
Not really, AFAIK. Looks like a candidate for someone with an intact piece and a 3D printer to replicate.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Financially, the Campy stuff will bring a lot more $$$ and overall, performs worse. Easy choice for me on a keeper. One place I like Campy are wheels, in particular, hubs. They always seem to be more durable. So I’d probably keep the Campy wheels.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
verktyg
Liked 1,238 Times
Campy RD Part
Thanks.
Thanks and cheers
Thanks and cheers
Here's one for the Victory RD on eBay, probably the same part as used on yours:
https://www.ebay.com/p/11014208707
verktyg
Chas. ;-)
Chas. ;-)
verktyg
Liked 1,238 Times
Campy RDs with corncob FWs
I'm running a 12-32T 8 speed cassette and 48-38T chainrings with this Shimano 600 Tricolor RD and it shifts like butter.
But, I've ran a standard Campy NR RD with this 13-31T 5 speed FW and 50-42T chainrings without any problem other than cobby shifting...
verktyg
Chas. ;-)
Chas. ;-)
Liked 927 Times
i do not have the parts pages but there is a fair chance the vulnerable part on the Victory mech will work on this unit.
Cheers
Liked 927 Times
With the exception of the Gran Turismo and Rally, until the mid 80's, Campy derailleurs were designed for competition. Bikes in the pro peleton rarely had FW sprockets larger than 22T-24T. On corncobs they shifted much better than trying to cover larger ranges.
verktyg
verktyg
Cheers
Quoted: 237 Post(s)
Liked 83 Times
