DIY derailleur hanger?
Bikes: 2013 Boardman Sport. Just purchased a Raleigh SP Team frame I'm looking to build up from scratch.
Evening all
Has anyone every made their own derailleur hanger or modified one?
Got a Raleigh SP Team frame and can't get a derailleur hanger for love nor money. Can find some that are close though.
Wondered if anyone had ever made or modified one for an old frame? Possible with hand tools and pillar drill?
Cheers
Cheers
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
https://derailleurhanger.com/manufacturer/raleigh/
They seem to have Raleigh derailleur hangers pretty well covered.
Quoted: 529 Post(s)
Liked 255 Times
If you have the skills and are creative, you can make one.
To do it properly, you will need the appropriate tap to make a thread for the bolt.
Alternatively, you could use a bolt and nut. You need to ensure it does not interfere with anything.
Understand, the bit that hangs down at the very bottom, is there to prevent the derailleur from rotating forward. You need to include that, or have another method to prevent the derailleur from rotating forward.
If it was me, I would use a larger piece of steel, so you have something to hold on to, or grip in a vice, and cut it off at the end.
Thanks
Tried that site and numerous others but the correct one isn't on there unfortunately.
Was looking at 10mm aluminium sheet then sanded down to 5mm to creat that part which stops it moving forward. Its a two point fixing so doesn't need to be 100% perfect.
Would post a picture but not allowed until I've done 10 posts.
Only allowed to post urls after 10 posts as well. Fingers crossed I've found one close so will hopefully fit with a little modifying.
You want to use a malleable AL alloy as it needs the ability to be repeatedly bent not broken
Quoted: 966 Post(s)
Liked 1,629 Times
Yes... But not for a "Raleigh SP Team frame"...!!!
https://www.bikeforums.net/classic-v...lded-puch.html
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
The derailleur hanger is designed to be substantially weaker than the dropout and frame. A broken hanger is far preferable to a bent or broken frame.
Some 6061 aluminum sheet ought to suit just fine. It's fairly strong (as aluminum goes), very commonly available, and not terribly expensive.
A slightly bent hanger can be straightened. If the bend is substantial, it's time to replace it.
climber has-been
Liked 3,567 Times
No charge, just pay for the postage.
Thank you so much for this. I'll see how i get on with the one I've ordered but might get in touch if not. thanks.
Malleability is not the design purpose of an aluminum derailleur hanger, since aluminum won't tolerate much bending without breaking.
Likes For popeye:
Terry is correct 6061 is fine.
Derailleur hangers (dropouts) generally are made from relatively soft aluminum. There are few ways of manufacturing them: Cast, stamp, forge or CNC machined aluminium. The highest quality and precision has CNC machined derailleur hangers. CNC machined sos hangers are made from higher quality aluminium mark 6061 T651.
The new DI2 DA has a skeleton drop out. Looks scary.
Quoted: 18376 Post(s)
Liked 4,511 Times
Liked 4,511 Times
Oof...
Any chance you have the original hanger? There are quite a few that are similar, but it would be difficult to know the exact bolt locations without a detailed diagram.
Wheels Manufacturing has a fairly extensive list of hangers.
https://wheelsmfg.com/derailleur-han...list_limit=all
This hanger 123 looks close, but it is hard to tell.
https://wheelsmfg.com/derailleur-han...anger-123.html
I think that may be the 517 on the site above
https://derailleurhanger.com/product...ur-hanger-517/
There are also hangers like this 167 that may be close, but may need some file work to get it to fit right.
https://wheelsmfg.com/derailleur-han...anger-167.html
Thanks
Found one with the best hole placement. Then some file work will be happening. Will post update once it arrives.
Sorted
Mech hanger came through the post. Holes are spot on location wise. 5 mins with a file and it fits. Happy days.
Cheers for the info folks.
Likes For Drukas:
