The importance of bicycle weight for the fifty plus
#76
For comparison, look at stack and reach of frames to see how they might fit. Most geometry charts include these numbers and I think it can be more accurate than just top tube/head tube.
Also, you say your bike has a 160mm headtube. Are you using spacers under the stem? If not, a 130mm headtube could be fitted with spacers to achieve the same height.
Then again, if the stack is 30mm greater on the frame with the shorter headtube the height will be the same. Check the stack.
hsea17
#77
Quoted: 8280 Post(s)
Liked 9,041 Times
Compared to a Domane? That is significant. I think Trek has some of the highest stack and headtube dimensions in endurance bike geometry. A TCR is certainly more race oriented than a Domane. A BMC Roadmachine has similar numbers as the Domane, iirc.
#78
climber has-been
Quoted: 3432 Post(s)
Liked 3,566 Times
Their top end tri bike: 9.62 kg
Their top end aero bike: 7.22 kg
Their top end lightweight bike: 6.7 kg
My 12 year old Scott (with some component swaps): 6.3 kg
Likes For terrymorse:
#79
Tri bikes are normally heavier than road bikes, especially road bikes built for climbing. Many triathlons have no climbing. Most triathlons don't allow drafting.
The UCI weight limit for road race bikes is 6.8kg, or 15 pounds. Nearly all bikes at UCI governed events will be 6.8kg, although some are indeed a bit heavier these days with aero considerations, discs, etc.
Of course, you can buy a production bike in the 15 pound range or even lower. Just takes $$$.
For someone like me, 200+pounds who bashes around on bad pavement for 1000s of miles, super light stuff won't work.
#80
Liked 9,041 Times
He knows and several of us have said our bikes are close to the weight of his old bike or even heavier. The point is, for whatever reason, he wants a lighter bike. If that's what he wants, I'm fine with it.
#81
Compare: 2022 Giant Bicycles TCR Advanced TCR Advanced 2 Pro Compact M vs 2021 Trek Bikes Domane SL 6 54 - Bike Insights
#82
Thank you for moderating the thread.. I'm sure he's thrilled that you're fine with it. Phew.
#83
Liked 9,041 Times
No, it's for my current bike. Trek Domane SL 6 has + 30mm stack and - 14mm reach vs Giant Tcr Adv.
#84
Liked 9,041 Times
#85
Liked 9,041 Times
#87
Likes For JohnJ80:
#88
I just got back into biking (I'm 57) and I rebuilt a mid 90's Cannondale R300, 22lbs. Not the lightest, but very light to me. Night and day difference for what I used to ride. I'm in the market for a gravel bike now and I like steel, but I can't imagine anything heavier than what I have now! The Cannondale may be old but it is so smooth, agile, quick, and the gears are smooth too.
#89
climber has-been
Liked 3,566 Times
#90
If speed is the most important factor, then a lighter bike is important. If versatility and comfort are important weight is a secondary issue. I have 6 bikes, their weights range from 20-35 lbs, the ones I ride most often weight 25 and 30 lbs.
Marc
Marc
Likes For irwin7638:
#91
Update. I decided to stick to what I believe in and have experience with when it comes to frame size and geometry so for now it won't be a new bike, but had decided to change the crank arms from 172.5 mm to 170 mm and in that regard got a good offer about changing the entire groupset from the bike dealer, so now I have a bike that weighs 8.90 kg with pedals attached. As for the 170mm crank arms, I feel the pedal revolutions are somewhat easier/lighter and my arthritic knee at least welcomed shorter crank arms, but a little early to say for sure as I need a few more bike rides first.
hsea17
hsea17
#92
If a new lighter bike = more fun and is easier to lug up the stairs, I'd buy it if I were you. I'm 72, have PCa (Prostate Cancer) and ZERO TESTOSTERONE, biked yesterday 56 miles on my RANS V squared weighing in at 40+ pounds and worked my butt off in 16+mph winds. Had 1 short 1/2 mile section just 2.5 miles from home and end of ride with wind directly behind so was able to crank it up to 25.4mph. Was more fun than riding my Aero Giant Propel Advanced SL at 17lbs. hitting 36mph. Buy and enjoy 'cause tomorrow ain't guaranteed.
#93
Quoted: 18415 Post(s)
Liked 15,545 Times
Back in the late ‘80s I bought a used 660 built with 531. What a machine that was.
Likes For indyfabz:
#94
Liked 9,041 Times
#95
Liked 15,545 Times
Mine had a Campy Nuovo drivetrain and black Modolo brakes with aero levers. I had arrived as a real cyclist. I rode the crap out of that thing until it developed a crack in the head tube. Banished it to the trainer and used it to rehab from what is now my first valve replacement. Finally snapped the drive side chainstay.
Likes For indyfabz:
#96
Liked 9,041 Times
#97
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
Late to this party. I took my Cervelo R5 into a Specialized shop. Specialized sells premium bicycles that may be very light weight. When I picked up my Cervelo the salesperson lifted it and said, "OMG this bike is so light". It is about 15.5 pounds with 45 mm carbon clincher wheels. Also it has the SRAM red eTap electronic shifting and carbon handlebars and stem. Offsetting some that lighter stuff is an SRM power meter albeit with carbon cranks. The best part is that it is a fun bike to ride.
#98
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
First, some context. I'm 58, overweight, various physical difficulties. Very much an amateur, "not serious" bicyclist. I track my rides in Strava when I remember to turn it on, just to see how I'm doing. I try to do better, but I don't get competitive with myself or others.
I have a number of bikes that I've built, but none of them are what I'd consider to be truly light. All but one are at least 30 years old. All of them are steel of various types and qualities. When I built them, I tried to use the best components I could afford.
I can definitely feel a difference between the lighter bikes and the heavier ones. However, I don't think that the heavier bikes are any less pleasant to ride. I've only ever ridden my tandem solo, since my wife is afraid to ride...and in spite of its weight (a nice bike, but still pretty heavy), it's still very nice to ride, I just need to stay aware of its length. My commuter is a 32-year-old plain-gauge store-brand MTB that I put drop bars on, but it's a hoot to ride...I never feel like I need to baby it, it's dependable and nimble af.
I'm not saying that weight isn't important, but I guess it's not very important to me. I don't have stairs I need to hump them up and down, just a few steps on the front porch. I don't think I'd ever use a carbon frame or components...I value dependability, and I'm not inclined to risk catastrophic failure.
#99
Granted weight will vary with the number and size of spare tubes if not using tubeless. So with a fat tire setup and multiple spare tubes for goat head thorn country I might carry as much as 2 pounds multi day ride, but, I would more likely be going tubeless for that and still only carrying one tube in case of a tubeless failure.
My first coast to coast tour I carried as much in tools and spares as you are carrying and possibly a bit more. I felt like it was worth it since I was looking out for my group. I carried lots of other questionable weight and regretted my packing choices every day. On hindsight I decided to never carry anything like that again. I have trimmed and trimmed the overall load (not just the tools and spares) every trip since then. The trips became more and more enjoyable as the weight went down.
#100
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2581 Post(s)
Liked 5,639 Times
Weight is an important factor but then you can make a significant gain in speed using low rolling resistance tires set at a pressure dictated by a good pressure calculator - like on the Silca site. If you ride with tubes, go with latex to remove unsprung weight as well. Another thing that really benefitted me for climbs was getting lower gears. They are fantastic compared to mashing my old ones and being exhausted at the end of long steep climbs. You don’t have to spend big money to get a good gain in speed, or distance or both with just those items.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
