shimano 105 8-speed / tiagra 4600 10-speed compatibility
Old 07-15-21, 02:54 PM
jh_
Got a road bike 2nd hand w 8 speed shimano 105 groupset and had it serviced to find out the rear shifter is messed up and needs replacing. My mechanic hasn't been able to get their hands on a new replacement for a while so i'm looking 2nd hand. I have 2 options in my area:
  1. shimano tiagra 4600 10-speed shifters, like-new (person is upgrading to 4700)
  2. shimano sora ST-3300 8-speed shifter, older & seems pretty battered
I called my bike mechanic and they suggested I stick w 8 speed shifters to give smoother shifting... But, don't most/all of the older shimano 8-10 speed shifters have the same cable pull? Which of these would be more compatible? TIA
jh_ is offline
Old 07-15-21, 03:53 PM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,809 Times in 3,317 Posts
If you are going to put all Shimano Tiagra 4600 or better yet, find you some Tiagra 4700 DR's and shifters, then I don't see why not put them on your 2d hand bike. Though a lot depends on the bike. You'll also need to upgrade the hub to a 10 speed freehub. But if you have to pay to have it done then maybe not much bang for the buck spent. And a half assed job by a newb DIYer won't be a good deal either.
Don't try to run 10 speed stuff with a 8 speed or even 9 speed cassette. Tiagra 4600 is probably okay for a 10 speed group, but the cable coming out the top just dates it as old stuff. But if it's free or close to it, then why worry about what I might think.
But if that 8 speed is a 3x front, then maybe you really do have the better option already installed on the bike. Even a 2x front with just 8 speeds might be decent if you don't have a lot of hills or have needs for specific gear ratios.
Iride01 is offline
Old 07-15-21, 04:56 PM
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
An 8 speed Microshift shifter will work.
seypat is offline
Old 07-15-21, 06:32 PM
hubcyclist
Quoted: 471 Post(s)
Liked 632 Times in 337 Posts
I'd concur with above, microshift r8 are actually pretty darn good shifters, from my experience, and I've used them with shimano derailleurs. But older tiagra 10 speed (pre 4700) would work too, just upgrade the cassette to 10 speed (the hub should be the same for 8/9/10 speed).
hubcyclist is offline
Old 07-16-21, 12:14 AM
canklecat
canklecat's Avatar
Quoted: 4560 Post(s)
Liked 2,802 Times in 1,800 Posts
Ditto, MicroShift, if you can find 'em -- even those are in short supply now. I've been swapping a set of MicroShift R7 7-speed brake/shifters between a couple of road bike for the past two years, no problems. They sound a bit clacky compared with my Dura Ace 8-speed brifters, but work well.
Currently it's part of a temporary setup on a Diamondback Podium frame I'm trying to decide on for a final setup. I think I'm going to convert the Diamondback to use with aero bars and older Dura Ace 10-speed stuff, including DA 10-sp bar-end shifters. Meanwhile it's a mish-mash of old Ultegra 8-speed derailleurs, 7-speed cassette (it's the only spare wheel I had around while I'm waiting to have the aero wheelset rebuilt), Ultegra 6700 crankset, 9-speed chain, and the MicroShift R7 shifters. Odd bunch of Frankenbike spares, bits and pieces but it all works. If the MicroShift 10-sp integrated brake/shifter units are compatible with my Dura Ace 7800 RD I might get those rather than the Shimano stuff.
Be cautious about the MicroNew stuff that often appears when searching for MicroShift. They appear to be very similar but user reports indicate the MicroNew stuff might not be the same quality. I've seen several reports of MicroNew shifters breaking soon after installation, while most MicroShift users seem to be satisfied.
And check the China Cycling YouTube channel for reviews of less familiar component brands that might be suitable. His reviews aren't just noncritical hype and he'll often criticize stuff that doesn't perform well or is built to unacceptable standards.
canklecat is offline
Old 07-16-21, 04:08 AM
ARider2
Quoted: 94 Post(s)
Liked 151 Times in 105 Posts
Your local bike shop should be able to get the Shimano Claris 8 speed brake/shifter (presently available from QBP), or you may be able to get it yourself from online sellers.
ARider2 is offline
Old 07-16-21, 10:00 AM
Maelochs
Maelochs's Avatar
Quoted: 7652 Post(s)
Liked 3,473 Times in 1,834 Posts
No reason the Tiagra shifter wouldn't work but you might find yourself clicking for shifts which aren't there. If you aren't interested in upgrading to 10-speed, I wouldn't go that route. If you can buy the guy's whole 10-speed setup ..... but the 10-speed chain is narrower than the 6-7-8 chain. If you want to go with a 10-speed cassette you might find the 8-speed chain doesn't work, so you'd need to buy the derailleur, chainrings, and chain as well as the cassettte.
Honestly, I wouldn't trust used .... I have bought a bunch and only a few bad ones, but the prices are so high now, go Microshift or even Claris.
I have a Micronew 7 on one bike and it is fine, but I don't ride that bike enough to say the shifter would really hold up over time.
Maelochs is offline
Old 07-16-21, 10:18 AM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3432 Post(s)
Liked 3,566 Times in 1,792 Posts
Yes, according to bikegremlin.com, Tiagra 4600 10-speed shifters work fine with an 8-speed Shimano derailleur. Just swap out the existing 8-speed cassette for a 10-speed, and you should be good to go.
Shimano 10 speed road shifters are compatible with Shimano MTB RDs from 6 to 9 speeds and with shimano road RDs from 6 to 10 speeds...Exceptions are Shimano Tiagra 4700 road shifters
Ride, Rest, Repeat. ROUVY: terrymorse
terrymorse is offline
Old 07-16-21, 10:26 AM
seypat
Where are you located at? I converted one of my wife's bikes from DT shifters to 3X Claris 8 speed. She doesn't ride that bike anymore. Shy prefers goofing around on her vintage mixte with friction shifting. I need to break it down and sell it. The shifters have low mileage on them. PM me if you're interested.
seypat is offline
Old 07-16-21, 02:21 PM
BradH
Catching Smallmouth
BradH's Avatar
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times in 79 Posts
Unlike Shimano's newer shifters, those eight speed 105 STIs were designed to be serviced. These was a guy rebuilding them at one time, might still be. Ask over on the C&V forum and someone there will probably know. There was a set of Ultegra eight speed shifters for sale in the C&V for sale forum.
BradH is offline
