Zipp 404 rear wheel failure
- Hi all, I had a problem with my Zipp 404 rear wheel this week.
- when climbing a steep hill, near the top I lost drive completely.
never had an issue before. I couldn’t get and drive going up hill or when pressure applied to the pedals it just pushed through with no traction. Don’t think it is the freehub, it feels like something has stripped.
any ideas? Have i posted this in the right place?
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Liked 322 Times
Suggest you post it to "Bicycle Mechanics" subforum instead. Does the gear cluster turn when you turn the pedals?
Never try to teach a pig to sing...
Liked 322 Times
Probably is a faulty or gunked-up ratchet mechanism in the freehub then, but folks on the Bicycle Mechanics subforum are likely to have more expertise than I.
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista Vitus 979 Duralinox
Liked 6,950 Times
Thread moved from Introductions to Mechanics.
Liked 2,964 Times
Freewheel ratchets are binary. They tend to either engage solidly or not engage at all. However some freehubs don't use ratchet systems. Some designs, like roller clutches, can hold at low loads and slip at higher loads.
That said, I doubt it's a slipping freehub clutch. If you only experienced this once when climbing, it's possible that the particular sprocket has cut through the freehub body and caused the problem.
Otherwise, ir might be where the freehub attaches to the shell.
I'd start by pulling the cassette and examining the splines, both freehub body and sprockets. If they're OK, I'd improvise a torque test by, for example, protecting the FH body, and turning it with a large pipe wrench.
The results will point you in the right direction.
