Where do I get frame pump mount for a Zefal Solibloc?
Got this neat aluminum frame pump from a criterium bike that I flipped. Would like to keep it for my randonneur project.
Do you know where I can find any mounts?
Also, the attachment point seems to be a bit leaky once I push passed a certain PSI. It seems that the attachment end to the pump is leaky. Can I seal this with anything?
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
Bikes: Saronni Colnago 1982; Battaglin 1982, Centurion Lemans RS 1978, 3Rensho Katana 1978, C. Borghi Olympia 1980, 3Rensho Athlete 1980's, Holdsworth 1980's and more...
Quoted: 33 Post(s)
Liked 9 Times
You can buy from this eBay seller: https://www.ebay.com/itm/Vintage-CYC...53.m1438.l2649
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
I like these plastic pegs; they're much kinder to the paint:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
You can still get new replacement hoses for those if I'm not mistaken.
Connection - Presta - 15 cm
Old fart
Liked 3,401 Times
My current 'frame' pump is a Lezyne HP "road drive", which is essentially a modern miniaturized copy of the Solibloc. It had the same problem initially, but after a while the gasket bedded in enough for it to work pretty well.
With a bit of fettling and hot rodding, I suspect you could probably get it pumping much better. Maybe find a fresh rubber O ring in the same size. Also, there is such thing as gasket grease. Something to try.
illwafer
Classic & Vintage
8
11-17-11 04:51 PM
HouseAtreides
Classic & Vintage
9
11-08-10 06:22 PM
