Why is tube leaking?
About 2 weeks ago I replaced the stock tire on my Aggressor Pro with a Kenda Kwick Drumlin. I took it for a ten mile ride, with no problems. A few days later it had gone down from 60 psi to 50; I topped it off and went for a twenty mile ride - again no issues. Today the tire is totally flat - even though it's just been sitting in my garage since the twenty miler. I thought maybe it was another slow leak, but no - any air I put in leaks right out near the valve. What could cause it to work fine on those rides, then develop a major leak just sitting in the garage?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
You obviously got a puncture on your last ride.
Likes For cxwrench:
Quoted: 1109 Post(s)
Liked 1,200 Times
Couple of ideas:
You had a slow leak and now have a different faster leak. Take the tube out and feel for leaks with your cheek or with water.
The valve stem was slightly loose and is now much looser - tighten it.
You had a small crack where the stem joins the tube and the crack worked itself larger because you rode the tire underinflated because of the slow leak during the ride. Again, see if you can feel or see the air leaking out of that area.
Regardless, either assess and fix the leak with standard measures, or replace the tube. It's just a leak, figure it out and fix it.
Likes For Camilo:
It doesn't seem like a puncture...if I try to inflate it I can hear air leaking out of the valve. Also, I made it back from the last ride okay...either it wasn't leaking at that time or maybe had a slow leak that I didn't notice...the fast leak only developed over the past week while it was just sitting in the garage.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
If the air is truly coming out of the valve, a likely suspect is the valve core:
If the valve core is loose, try tightening it.
If the valve core is replaceable, try replacing it.
If none of the above, then send the tube to your nearest landfill.
Likes For terrymorse:
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Did you fill the tire with CO2 by any chance?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Time to take out the tube and find the leak with a bucket or sinkful of water. None of our guessing, however close, will fix it.
Likes For ThermionicScott:
Quoted: 18415 Post(s)
Liked 15,553 Times
Likes For indyfabz:
Likes For Ttom:
Quoted: 1364 Post(s)
Liked 1,677 Times
My first guess is a loose valve core.
Next would be a breach by where the valve stem meets the rest of the inner tube. I've had those and even when submerged in water the bubbles didn't appear until pushed the stem off-center.
Next guess would be a thorn that has worked its way through the tire and is ever so lightly impinging on the innertube. When sitting still its a slow leak, when riding it leaks much more. Take off the tire and feel around the inside of it for a small, sharp point.
These have all happened to me over the years.
Likes For BobbyG:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
It sounds like one possibility is you may have tightened the valve nut too tight, which can pull on the tube and slowly tear it. But as mentioned above, pulling the tube out and inspecting it will lead you to an answer much more quickly.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 523 Post(s)
Liked 229 Times
Presta or Schrader valve? At least one reply here only applies to presta valves and that is tightening the nut too much.
My experience is that you would break off the top of the valve if you tightened the closure nut too much and you would see that right away. I've never lost a valve tightening the nut that may be there to fix the position of the valve in the rim hole.
You might have pinched to tube between the rim and tire when you mounted the new tire. That sometimes causes the tire to lift off and you shred the tube at that point. I agree the best way is to remove the tube and inflate it outside of the tire. I have a narrow 700C tire on my trike. It only requires topping off about every 10 days to avoid pinch flats. If it goes down any sooner than that I know I have a puncture.
Likes For VegasTriker:
Correct! I wasn't expecting someone to remotely diagnose where the leak is; I was just wondering if anyone might know why it got me through thirty miles without a problem, then developed a major leak while sitting in the garage!
Bikes: lots
Liked 2,932 Times
I didn't know that valve cores were a thing, so I checked that out - but it turns out the tube didn't have a removable core. So I put in a new tube and all is good. It turns out there was a very small puncture about an inch from the valve (not where the valve joins the tube, as I originally thought). VegasTriker may have hit the nail on the head...I'm thinking maybe I might have pinched that area when I mounted the new tire, and for some odd reason it took a week before it became bad enough to do any serious leaking. Thanks to all for the advice!
Mounting the bead at the valve stem last, is a good way to get the tube pinched under the bead, and make your tube explode. Then you can come back here and ask "why did my tire blow up?"
Liked 3,434 Times
The reason I asked was because CO2 diffuses through butyl rubber, so your tire gradually goes flat with no hole in the tube or defect in the valve.
Hmmm...so maybe the way to go is CO2 for a roadside fix, then refill with air once back home with a decent floor pump.
Likes For Mickmeister:
Quoted: 6194 Post(s)
Liked 4,810 Times
Air as well as CO2 will diffuse through tubes over time. CO2 just does it a tad faster. So don't expect your tire to be inflated to the proper level if you leave it for over a week.
Though larger volume tires with their lower riding pressures won't lose the same amount of pressure as my skinnier 25 mm road tires. I usually have to fill them every other ride. Or roughly every three to four days to have them up to their pressure for riding.
Likes For Iride01:
Liked 3,434 Times
CO2 diffuses through butyl tubes a lot faster than nitrogen or oxygen.
Likes For Polaris OBark:
