tires and sun
Quoted: 1279 Post(s)
Liked 1,393 Times
tires and sun
the most secure, least obtrusive place to store one of my bikes is directly adjacent to a south facing window.
the window is 100 years old, monolithic clear float glass with no low-e coating. presumably 90% transmission across all spectra.
obviously tires are meant to be used in the sun - but they’re spinning (so any portion is only “up” a third or so as much) and cooled by the wind - and only for however long one is riding for. is this kind of sun for 6-8 hours every other day or so going to have an impact on your typical road bike tire, as shown?
Likes For 05 fuji:
Quoted: 569 Post(s)
Liked 583 Times
RVers used Aerospace 303 on their tires which sit outside, works well done in Southern Arizona. Keeps them looking nice as well.
Quoted: 1819 Post(s)
Liked 1,695 Times
Plain glass blocks some UV wavelengths. I looked this up, but lack the time or inclination to determine which ones might affect your tires. So, just google "plain glass UV transmission"
There are many interesting links if you are determined to research this topic.
Anecdotes and opinions from this forum may not be as reliable
Liked 1,393 Times
Likes For mschwett:
Likes For m.c.:
SE Wis
Quoted: 2747 Post(s)
Liked 3,398 Times
go to goodwill, buy a bed sheet, cover bicycle
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
If your tires get UV rot (dry rot) before you wear the tread off just from sitting in the sun then you need to rethink owning a bike. OTOH, I was told by a tire mfg rep that the rubber in tire compounds today has a chemical that needs flexing to keep a tire soft and pliable. But nothing can save a tire from the harmful rays of daylight. I like the sheet idea. Keep dust off the entire bike while it sits for (ever?) Just kidding.
Likes For SpedFast:
Liked 1,393 Times
it gets about 500 miles a month, 2 days out of 3. i’ll probably throw a sheet over it, i guess. looks nicer sitting there in the sun 😂
Likes For mschwett:
Quoted: 643 Post(s)
Liked 1,526 Times
If the bike is getting ridden 500/month, the tires are not going to last long enough to matter.
Likes For Ogsarg:
Bikes: 2021 Salsa Warbird, (Specially Love my) 2021 Salsa Cutthroat, 2012 Surly LHT, 2015 Surly Cross-Check, 2008 Giant OCR A1, 2005 Leader 735R, 2005 Gary Fisher Montare, 1991 Nishiki Pueblo,
Quoted: 84 Post(s)
Liked 57 Times
Do you wash the shirt you rode in? You should, just use that for covering your tires while the shirt gets dry. 2 birds with one stone,
The window will last another 100 years.
Just ride the bike often enough, you'll be replacing the tires sooner than you start seeing cracks.
Old fart
Quoted: 3589 Post(s)
Liked 3,400 Times
Quoted: 506 Post(s)
Liked 639 Times
Short answer is yes. The heat will have an effect and so will the sun. However, if you are riding 500 miles a month, then you will wear out the rear tire before this becomes an actual concern. Just as long as you move the front tire to the rear and put a new one on the front, then you'll wear out tires every 6 months or so and won't have to worry about these effects. If you just left the bike there, the effects would accumulate even though the rubber has both free radical scavengers and UV absorbers compounded in. They don't last forever.
Liked 1,393 Times
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Quoted: 2604 Post(s)
Liked 1,933 Times
As @KerryIrons notes, if you ride 500 miles/month and rotate tires, you'll wear them out before they start cracking.
The other thing nobody's mentioned is that the sunlight may fade the paint job on your bike. After some years, you may notice a piebald paint job. Can you find another place to store the bike over the winter, when the low sun angle will light the bike even more strongly?
Quoted: 506 Post(s)
Liked 639 Times
Good point. I spent two summers touring and the paint on my bike really faded. In those days we had clamps for the shifters and cable housing and when I took them off to clean the bike, the paint was MUCH darker where it had been covered by the clams. Likewise under the down tube and BB shell.
Liked 1,393 Times
Quoted: 1034 Post(s)
Liked 1,290 Times
Most cars sit outside longer than your bike tires will be exposed to the sun through the window. Ride and don't worry about it. If you were storing it long term without riding, then I woukd cover it or find another place. As it is, it is a non-issue. Use your bike, enjoy it, repeat.
I thought it was always cold and foggy in San Francisco? Or maybe that's just the other ten months of the year.
Liked 1,393 Times
but on balance, it’s sunny about 70% of the time, and between 60 and 70 degrees most days. other than the wind (which can be unforgiving) it’s pretty much the definition of a mild climate. year round, all day riding weather for me, at least.
