Technical questions for the retro grouches on here
climber has-been
Quoted: 3448 Post(s)
Liked 3,595 Times
Lots of new tech claims to solve a problem that doesn’t exist. I blame the tech bro echo chamber.
Liked 2,993 Times
a real purist will use the heel of the skateboard type shoe to stop.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 5801 Post(s)
Liked 2,619 Times
Answer is yes. It's not about whether one is "better" than the other, but about fitness for the specific purpose. Each has advantages and drawbacks, so its about weighing them based on your needs.
Keep in mind that rim brakes served well for well over a century, though there were also hub brakes just as long with each having it's place. The need for disc brakes came about mainly because of mtn bikes where the drawbacks of rim brakes became problematic.
In favor of disc brakes, excellent wet weather service & elimination of rim wear. Disc brakes also open the door to CF rims so that's a subtle plus. The drawbacks are greater complexity, initial & maintenance costs, and weight.
In favor of rim brakes, simplicity & reliability, low initial and maintenance cost, lower weight. The drawback is mainly poor wet service, along with rim wear issues.
For road use with narrow tires, the balance makes rim brakes the smarter choice, since the drawbacks are non issues for most, possibly excluding all weather commuters.
I'm a life long road rider, both sport and utility, and cannot see a need for discs. I've adapted to the poorer wet braking, which is manageable, especially because traction is also reduced. As for rim wear, it's never been an issue in almost 250k miles, though it might become one if there were enough urban miles in that mix. OTOH rim life in NYC area is lower anyway owing to potholes.
If it weren't for the marketing efforts, and the thinking of mountain riders starting to buy road bikes, I believe that high end road bikes would still be rim braked, and wouldn't be surprised by some return to rim brakes on sport/competition bikes.
In favor
In favor
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Expired Member
Quoted: 3688 Post(s)
Liked 5,479 Times
I was actually "in the business" way back when this happened. I can tell you that nobody with any expertise or experience thought it would work. Obviously it didn't and now we have the abandoned demented wandering the country. We've actually had a few cause trouble here on BF over the years.
Likes For shelbyfv:
Quoted: 696 Post(s)
Liked 910 Times
I wonder if anyone will come out with a road hydraulic rim caliper to allow us with rim brake road bike to use the latest groupsets like Shimano Dura Ace 12 speed which is disappointingly only hydraulic and di2.
Quoted: 4444 Post(s)
Liked 4,898 Times
Brake rotors only need to get much bigger if power, tyre grip levels or weight significantly increase. None of these things are going to happen on bicycles and certainly not to the extent of requiring 600 mm rotor diameters. Do you see any rim-braked motorbikes out there?
Liked 2,993 Times
If the modern rotor was designed to have the vented rotor, it might actually facilitate a longer material life & reduce the diameter sizes needed... So what if it increases the weight some, we all don't live a corner block to corner block in racing lives.
-Oh Hey!
-Oh Hey!
Old fart
Quoted: 3594 Post(s)
Liked 3,403 Times
Actually, you need a frame and fork designed to handle disc brake loads, and hubs capable of mounting a brake rotor.
No. Machined brake tracks are a relatively modern feature. Unmachined brake tracks were universal until only a couple decades ago.
N.B. there are/were dedicated rims for track use that do not have a sidewall that could function as a brake track, but those were the exception, not the rule.
Q: Do you need special modifications to wheel sets to use rim brakes?
A: Yes, you need to add brake tracks.
climber has-been
Liked 3,595 Times
Mad bike riding scientist
Quoted: 6223 Post(s)
Liked 4,225 Times
It amazing how someone comes in spoiling for a fight and is surprised to find one.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,898 Times
Isn’t that the definition of reluctance to change? I’m happy with what I’ve already got and so I’m reluctant to change it.
Veteran, Pacifist
Quoted: 3907 Post(s)
Liked 4,852 Times
As an occasional retrogrouch, I will move beyond the disc brake discussion, and say Technically that I cannot foresee:
1a. Using 13 cogs on a cassette,
1b. Neither a 10 cog nor one with 52 teeth.
2. I like tubes on my road bikes.
3. I prefer external cable routing
4. Custom, handmade frames are priceless
5. 40+mm road tires are for sissies (and maybe some self supported tourers).
6. If you can clear your handlebars, your mind will follow
I ride vintage & modern, downtube shifting/Ergo10/Di2, CF/Ti/Steel frames, tubular/clincher - just make the frame 60cm please, and the weather pleasant.
1959 or 2020 - or anything in between, doesn’t really matter to me, just give it nice tires and wheels.
Quoted: 4813 Post(s)
Liked 3,940 Times
Likes For 79pmooney:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2599 Post(s)
Liked 5,679 Times
For me it depends on what is more valuable, a bike that stops quickly, or one that climbs well. (Yeah, I know, one could save your life.). I have two carbon bikes with different setups. The Orbea has Ultegra rim brakes and aluminum rims with tubed GP5Ks. Even with Ultegra pads stopping is typical of rim brakes which is to say it’s meh. However, the Orbea is lighter with the rim brakes and man can that bike accelerate and climb. The Bianchi has aero carbon rims, is tubeless and Ultegra discs. The bike can stop on a dime but is slow to accelerate and is not ideal for climbing.
I spend far more time climbing than braking and that is where the scale tips. Sure I love a fast braking bike, but on a long climb, the lighter rim braked bike wins. If I could own a light disc braked bike, then it would be an ideal combination. I know they exist at stratospheric prices, so will have to weight 😆 until the prices come down. Call me a Luddite or Boomer or Retro Grouch but I know what works for me.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Well it was tried....Buell I think.
Quoted: 1250 Post(s)
Liked 1,328 Times
Grupetto Bob
Liked 5,679 Times
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1963 Post(s)
Liked 1,483 Times
Quoted: 3959 Post(s)
Liked 7,336 Times
0/2
Liked 7,336 Times
climber has-been
Liked 3,595 Times
Our city will pay us to dump our gas-fired water heater and replace it with a heat pump heater. But the power was out for a full day last week, and our old water heater continued to work. A heat pump heater would have been useless without electricity. Not a compelling value proposition.
Friendship is Magic
Bikes: old ones
Quoted: 26436 Post(s)
Liked 10,397 Times
Likes For 3alarmer:
I hope we can use this thread to query the retro grouch community on border issues pertaining to equipment, cycling performance, expectations, etc.
So here is my question/point of discussion:
If disc brakes had come before rim brakes, would RGs still love rim brakes as much as they do?
I mean imagine if disc brakes were there first and then the idea of rim brakes came along? A brake that sacrifices the rim you say? I’m sticking with my tried and true sacrificial rotor to protect the wheel!
Rim brakes are popular with retro-grouches because they are simple, effective, lightweight, easy to maintain and adjust, don’t require bleeding, and the pads are very long lasting. They are inexpensive, easy to install and set up, and, depending on the levers you use, you can precisely adjust the modulation.
I have a couple of bikes with hydraulic disk brakes. I like how the brakes work, great stopping power and modulation, great in the rain, and they look cool (an important point to some people). However, installing and bleeding is a messy and often annoying job, and for bike newbs who aren’t handy with a wrench, and don’t have a bleeding kit, they are much harder to maintain than a mechanical rim brake system. Mechanical disk brakes aren’t much different than rim brakes when it comes to maintenance, but I don’t much like the “feel” of mechanical disk brakes.
Most people won’t ride a particular bike anywhere near as long as it takes rim brakes to wear out a rim. I’ve got a road bike which is running old-school (thin) Mavic Helium wheels, I’ve put more than 100k on this bike, and haven’t worn down the rims yet.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 982 Times
Reluctance to change and obsession with weight (still both lingering). Maybe cost too at the lower end of the market. Mountain bikes really paved the way for bicycle disc brakes and it was inevitable that they would eventually find their way onto all other types of bike.
