A lot of the recent "innovation" is a bad bargain for anyone not pushing a competitiv
#876
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Yes, it is one of SEVERAL faulty premises. It has been pointed out to him numerous times that modern racing bikes can easily be set up to replicate the riding position he advocates (and is shown in all the photos of the good old days he has posted), but he just keeps plowing on with his same tired line.
Other doozies include.....
2- His wacked-out premise that beginner riders are being turned off by being set up with road bike with riding position that are not aero enough.... when in fact the opposite has been true for a long time (new riders being turned off by riding positions TOO aero and uncomfortable for them) and that the move towards more relaxed endurance geo (and gravel bikes) has been a great benefit to new riders and increased access to the sport.
3- His premise that most people riding bikes on the road (including beginners) are myopically concerned with speed. Which begs the question of what he thinks the difference is between competitive and non-competitive (what this thread is about) riding.
4- Riding in an aero position somehow makes you more fit (as if speed is what burns calories, rather than effort).
Throw these 4 alternate universe realities into a pot and bake for an hour, and you come up with some of the most entertaining nonsense I have read on these forms in a while.
Oh, let's not ignore the histrionic "make these modifications to your diet or die" stuff appearing in the same post as a casual mention of his active alcoholism. I believe the phrase was along the lines "I drink a lot of carbs because I'm an alcoholic."
#877
Quoted: 167 Post(s)
Liked 291 Times
I missed that! So he's an alcoholic too?
An alcoholic with no friends who imagines his students want to emulate him...aw, no wonder he is here attention-seeking, poor guy.
So the Sake is indeed strong with this one. Explains a lot.
#878
Quoted: 8280 Post(s)
Liked 9,041 Times
Your entire thesis comes from a misconception - it's not the head tubes being taller that leads to sloping top tubes. It's seat tubes being shorter. Head tubes are the same length, for the size of bike, that they always were. Indeed, the stack height on headsets is also less than it use to be in the days of threaded headsets, and stems also are generally lower rise. Saddle-to-bar drop on pro bikes is a lot more than it used to be BITD.
So, having started from a faulty premise, you've built an entire edifice on that mistake.
I prefer a head tube of at least 220mm and stack in the neighborhood of 65cm, so what do I know? Maybe that's why I haven't lost the weight?
The other thing I was thinking is, if aero trumps all, and TT seeks the most aero, and he admits recumbents are the most aero, why doesn't he ride bent?
Likes For big john:
#879
Liked 9,041 Times
As I wrote that I realized it is another of his contradictions. If they are pressured into a $12k S-Works Tarmac they will be on an aero bike, and not an endurance sled.
#880
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,898 Times
Not to defend all of his assumptions but the taller head tubes he's thinking of may be those of so called "endurance" frames. A 58 Trek Madone has a head tube of 17.1cm and stack of 58 while a 58cm Domane is 19.5 and 61, respectively. So, yeah, the endurance frames are a little higher, at least in the Trek line, which seems to be the highest major brand.
But remember, his big thing is calling aero bikes 'unaerodynamic', so he's not talking about endurance bikes.
#881
Liked 9,041 Times
As unaerodynamic as I am I guess I must be an outlier since I haven't quit in frustration after suffering in slowness for 40ish years.
#882
Liked 11,898 Times
Yes, but did you die?
#883
Liked 9,041 Times
#884
Bikes: Trek Madone 5.2 SL 2007, Look KG386, R022 Re-framed Azzurri Primo, Felt Z5, Trek F7.3 FX
Quoted: 404 Post(s)
Liked 85 Times
Head tubes are the same length, for the size of bike, that they always were. Indeed, the stack height on headsets is also less than it use to be in the days of threaded headsets, and stems also are generally lower rise.So, having started from a faulty premise, you've built an entire edifice on that mistake.
I asked about this earlier in the thread, since I had been failing to find bikes with short head tubes, and was given the example of the Specialise Roub.... bike which a "Future Shock." The size of the head tube including future shock resulted in a total effective head tube about 2.5cm taller than my look and Trek which are less than 14cm in 54cm size.
Passing the buck a little, I also believed John Cobb when he said that makers have increased the size of head tubes.
Are headtubes in fact the same size as they have always been?
If the bikes are all as aggressive as they would always been then that would surprise me, and I would be wrong. If so I apologize in advance. I am sorry if this is the case.
Tim
#885
Quoted: 4257 Post(s)
Liked 1,357 Times
You really should have checked this out before going off into deep weird conspiracy theory territory.
#887
Liked 11,898 Times
If this is true then I have made a big mistake and as you say my premise would be wrong.
The Specialized Tarmac SL7 is a Aero/Race Bike (Specialized having combined the two categories recently) with a HT length of 131mm in the 54cm size - shorter than your Look and Trek.
Similarly, the Canyon Aeroad, an Aero bike, in S (which seems to be closes to 54cm, with a 54.9cm TT) has an HT length of 126. Their Ultimate - a Race bike - has an HT of 130mm.
Trek's Madone and Emonda both have HTs of 131mm in their 54cm frames.
#888
Liked 11,898 Times
Much Ado About Nothing.
#889
Quoted: 9653 Post(s)
Liked 6,365 Times
#890
climber has-been
Quoted: 3432 Post(s)
Liked 3,566 Times
I've always assumed it was the hip angle, since it feels hard to put force into the pedals when your knee is very close to your chest. The TT bike position moves the saddle forward and higher: to maintain the hip angle while lowering the chest.
The folks at BikeFit aim for a 100º hip angle:
#891
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Is it the low torso angle with the ground that reduces performance, or is it the low hip angle?
Otto
Likes For ofajen:
#892
Quoted: 404 Post(s)
Liked 85 Times
I am not sure why I think that getting down low and riding in an aero position is such a good idea.
First of all it is my experience, especially recently. I read this thread, get on my bike, go lower and lower (the Trek stem was quite by chance but I am enjoying it) and faster and faster. Thank you. It is my experience that to get the most out of solo road bike riding, it is a good idea to get to as near to horizontal backed as you can because the speed (near to that of motorised transport) is really exhilarating and this encourages me to keep at it.
I think it is to do with self-efficacy. People like to feel that they are making an effect on the world. Infants like to move their arms and legs and those pendulum things suspended above their cots even more because one bash of the pendulum sends it swinging even more than they can move their arm. It provides leverage.
Someone mentioned going to a gym and using a block and tackle and it sounds like a counter argument (to mine) but it seems to me that perhaps, if someone set up Platinums Gym with life size/weight replicas of cars, trucks, sumo wrestlers, small dwellings, ships, large blocks of steel and stone attached to blocks and tackle this might be more motivating than simply pumping or lifting iron. The ability to leverage ones strength to hoist a truck etc into the air might result in more effort.
While many do enjoy the scenery and comfort, I find that warming the atmosphere with my chest parachute produces no perceptible change in the world, so I find it less motivating than going down low and going faster (even though more constricted, both in terms of movement and sight) to be more motivating and I recommend this to others.
Thank you also for the ad hominem regarding my consumption of alcohol. It is something I am ambivalent about. Perhaps bf will encourage me to drink less. Ooh, that would be good.
Tim
Tim
#893
Liked 1,357 Times
#894
Liked 11,898 Times
To be fair, he will eventually be correct about them dying. Eventually.
Likes For genejockey:
#895
Liked 9,041 Times
There would have been no drinking less for me. All in or nothing.
If you're ok with it, party on Garth!
#896
Quoted: 404 Post(s)
Liked 85 Times
The Specialized Roubaix is not an Aero bike. It's an Endurance bike, with slightly more upright geometry. In addition, the Future Shock is just what is says - a shock absorbing fork/stem. Not directly comparable. Apples to apples,
Is Cobb misguided? He clearly says "these days" companies these days want you to be comfortable (or words to that effect).
Do those bikes have any bits that make the effective frame height taller?
Entry level road bikes tend to be more relaxed. I hope that purchasers are being told of the dangers.
Something is happening in America, the UK and less the rest of the world that is encouraging people to get fat and die.
As a non-drinking alcoholic, one thing that helped me quit drinking was the love of friends. I was sick, bleeding inside, etc. but I was always one of the "I don't care if I die" drinkers. When I got sick, it occurred to me that I might not want to die but it was the caring of friends that made me feel like I should live. It was difficult but worth it for me.
There would have been no drinking less for me. All in or nothing. If you're ok with it, party on Garth!
Don't forget that ignorant newbies with wads of cash are going into bike shops with dreams of the TDF and they are steered to the highest priced bike in the store by the pimply faced kid working there. Don't get me wrong, that may happen on occasion but I think most people are going to do some homework.
Recently I read about someone, on the forum, who got so low to their bars that their nose might hit it. I tried that this morning and it seemed to be really good advice!
#897
Liked 9,041 Times
My thin 21 year old student went into a bike shop and was served a parachute bike.
What is Robbie's bike? It looks like a Tarmac. Cobb is putting the bars a lot further down. It works for me, Cobb and Robbie, but not for those posting to this forum.
I don't know what Robbie is on but it doesn't really matter if he can achieve the position he desires.
I think most of us understand the role of aerodynamics with regard to speed. We know a flat back will give the best results. The question is does it matter to most of us? It doesn't to me partly because I cannot achieve the flat back position. Never have, and now at 68 I am less flexible than ever.
I think recreational riders rarely get the flat back position and I think most of them don't care.
I also think the other posters here understand position more than you give them credit for and most of the crap they are giving you is about the Frankenbike you posted earlier.
#898
Quoted: 404 Post(s)
Liked 85 Times
I think it is a shame. It made me sad when he got it. I have tried to get in contact with him to ask about how his cycling went but I have received no reply.
Great that you know.
I did not know. It took me a long time to work it out. It was not until I saw John Cobb's video, and he put the bars down by about 6cm that I had an epiphany, that I have been attempting to share with others because it worked for me so well. I don't think my student knew. I see loads of people riding around alone on bikes that seem to me to be made for airless group rides-- yes with that chest parachute. Frankenbikes. It seems to me that on these forums, people are recommending the bikes that the pros ride (because the pros know best, because of the prize money) when they are group bikes which are unsuitable for many (but not all) solo riders.
This 13,000 bike below however, looks to me like a Frankenbike. Why is their space between the drops and the front wheel? Using only bent elbows in the drops is possible but one nice comfortable fast position is semi arms resting on the drops. With this bike the only way to get low is to use bent arms into the hooks. The head tube is the same apparently, so perhaps all it needs (?) is some deeper handlebars but the forks look taller.
Why all the air?
Frankenbike, apparently.
My Ride by Timothy Takemoto, on Flickr
#899
Liked 9,041 Times
Not everyone wants their drops at the top of the front wheel. In fact it's probably very rare for recreational riders. On larger frames it's more rare, I'm sure.
Here is my Seven years ago. I have since changed the bar for a shallow drop model.
Likes For big john:
#900
Quoted: 1397 Post(s)
Liked 1,877 Times
