Noob Loob tip
Noob Loob tip
so I’ve been trying to figure out when I had lubed all the links in my chain… turns out there’s a different looking master link (on my Shimano Ultegra setup anyway) so I can find it and start and stop there! I imagine I’m the second to last person in the world to notice this but I thought I’d post it anyway to help out that last person…
Likes For Overdraft:
Quoted: 18424 Post(s)
Liked 15,572 Times
You put lube on every link?
Quoted: 3241 Post(s)
Liked 2,512 Times
Thread Killer
Quoted: 3148 Post(s)
Liked 1,713 Times
Likes For chaadster:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I would try every lube that gets posted in this thread on individual links of my chains.
But none of my chains are that long.
Likes For Chuck M:
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
That's how I do it. I am lazy, so I only lube after a ride in the wet or once/month. I put one drop on each link. I don't go by the OP suggestions, I just know that 3.5 crank revolutions gets me a full chain cycle.
Liked 2,512 Times
The OP provided a link on the correct way to do it. Nice!
Liked 15,572 Times
Pro Tip: When you spin the chain the lube gets distributed. I use NFS, which is the best chain lube on the planet. 4-5 drops is all that is needed.
Liked 15,572 Times
Likes For indyfabz:
Liked 2,512 Times
This is what I use to clean my chains. I need to contact the 2nd company and see if they have a system I can adapt to mount on a bike like a disc brake system. It should only add 5-10lbs of weight to the bike. A small sacrifice for the benefits.
Quoted: 9653 Post(s)
Liked 6,365 Times
You guys are yanking my chain.
Likes For Mojo31:
Thread Killer
Liked 1,713 Times
As for NFS being the best— and I assume you’re talking about the original and not their newer Blue Devil, since you didn’t say Blue Devil and they still make both— I’ve never seen any testing of a wet lube which betters wax in terms of lower friction or lower wear. The newer wet lube Silca Synergetic— and remember that Silca offered their own version of NFS for awhile— tests better according ZeroFrictionCycling.com.au who call Synergetic “the best ever tested.”
In any case, when using a top wet lube, I reckon the differences are minimized when road riding in dry conditions and employing a diligent, thorough, and frequent cleaning and lubricating regimen.
I just remove the chain from the bike and put them on a new newspaper to lube. Eliminates the guesswork where to start and end. But that's not the reason I remove the chain to blue. The main reason I do it so the lube doesn't get into the sprockets, jockey wheels, and chain rings. It's even critically important you do it if you're using wet lube. Depositing excess wet lube on the sprockets is typically the reason you get dirty drivetrain.
Liked 15,572 Times
Because I don't believe that much is necessary.
NFS recommends using 12 drops, but I don't come close to using that much for a regular lubing..
From a review:
"Application is easy, and can be accomplished using what the NFS website calls the 12:12:12 method: with the chain on the largest chainring and smallest cog, apply 12 drops randomly on the inside surface of the chain, rotate the chain 12 times and then wipe the outside surface of the chain with a clean cotton cloth for 12 seconds."
From a review:
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
From a review:
From a review:
I use & like NFS. I use a pinpoint squeeze bottle to put a small drop on every link. The 12-drop method may or may not be adequate, I don't know, but I choose to distribute the lube myself, rather than rely on a transfer from the cog and chainring to the rollers and pins. Then I wipe down the chain, wipe off the cog, large ring, and the derailer pulleys. I also wipe the chain after each ride, but after the first one or two it's pretty well dry on the outside.
Regarding NFS's instructions on how to do it 12:12:12, the website also recommends this video
I don't mind paying $7.50/oz. to use a boutique lube, it's part of the fun of the hobby to try different things, but I'm not convinced that, for the recreational way I ride, NFS is any better than Mobil One at $.69/oz.
There are many ways up Mount Loob.
Likes For BCDrums:
Liked 8,928 Times
Likes For datlas:
Liked 6,365 Times
Will it break?? Possibly best cover version of "The Chain" ever.....
https://www.youtube.com/watch?v=jVLNB3d-2cA
I like that acoustic bass. Don't see that often.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1254 Post(s)
Liked 1,287 Times
Regarding NFS's instructions on how to do it 12:12:12, the website also recommends this video,
on which the narrator (at :57) tells you to "put a thin stream of NFS along the entire length of the chain," certainly a lot more lube than 12 drops. So NFS endorses both 12 drops and a thin stream of lube, both ends of the spectrum..
Likes For Bob Ross:
Switch to a master link(i.e Wipperman). Makes chain cleaning etc much easier.
I use melted wax and will never go back to the hassle of degreasing/lubing weekly.
You do you Indy, but I'm not buyin' it.... we're not trying to lube the chain/sprocket interface. They're hardened surfaces that don't slide on each other that much (relatively speaking). The action is the motion between the chain rollers and their axles, and I just can't believe that suggested method can work. You're asking each of those 12 drops to not only lubricate the link they landed on but dozens of others via the mechanism of wiping off of where you applied them onto the sprocket and then imagining that the now lubed sprocket is going to wipe it back on to the dry links in sufficient amounts to get between the rollers and their axles.
Quoted: 257 Post(s)
Liked 252 Times
Liked 2,512 Times
If we're talking about lubing nip tips, lubing alone is not enough to prevent chafing. It needs some type of protective covering. I sweat too much for Band Aid type products to stay on. I use Liquid Skin.
Liked 8,928 Times
That would be a noob loob moob tip.
Likes For datlas:
