Tires on mountain bikes
I've used old bar end friction and thumb friction shifters with 7 to 10 speed cassettes. Also old long cage derailleurs seem pretty versatile.
Will the bike be for trail riding? Lots of climbing?
Also, I have modern XT shifter on my 11 speed mtb and it shifts as well as anything I've ever used. It's as close to perfect as possible, I think.
Quoted: 8281 Post(s)
Liked 9,052 Times
A friend did something similar and called it his "urban assault vehicle".
Likes For big john:
I'm going with a blue and cream color scheme and silver or polished parts. I'm basically copying the look of a Rivendell. They changed the bike I wanted so I didn't order one and I've always wanted to do this with a mountain bike frame.
I don't really know what to do with the gearing. Is it possible to build a cassette? I know I wanted a 21 tooth cog on the rear, that will give me the exact gear inch number as my cruiser, which has the same size tires and is perfect for me most of the time. I'm planning on a 42 tooth chainring and 165mm cranks.
The pre-built cassette does not have a 21 tooth cog but has some close and I don't know if it makes much difference. As much as I read about gearing I never really understand it.
Liked 9,052 Times
I could see that in a matte black or grey color. Maybe on a fat tire bike.
PRIMATO 8 M (miche.it)
I use Miche cassettes with Campagnolo stuff. I think they will make anything you want but you might have to buy through a dealer, I don't think they sell direct.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Yep, the consistent, massive, game changing improvements of MTBs over the past 30 year have all been a cynical plot to get us to buy them.
Advanced Slacker
Liked 2,537 Times
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Rhapsodic Laviathan
There's still a vast selection of 559 tires, since various bikes still use them. Maybe specifically offroad ones may not have a large variety, bu as a whole; there are choices. I haven't really looked online, though, I just get whatever the bike shops have.
Advanced Slacker
Liked 2,537 Times
Selection of mid to high end MTB tires in 26” is rather limited compared to the other two sizes. If you are not particular about what you’re running then it matters less.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
I’m not sure what to use for 11 or 12 speed. I was going to go with an IGH but because of the dropout width I am using the silver hub and I’m pretty sure I’m going to use the 7 speed cassette they sell. I’m not sure which derailleur I will use yet but I plan on using the Rivendell friction shifter, it is good for up to 9 gears.
Likes For Ironfish653:
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Not that there aren't still "nice" 26ers out there, but most of them are at least 15 years old don't see much trail use; either the owners got old and don't MTB much anymore, or if they're hitting the trails a lot, they've moved on to more capable modern bikes
Thanks, I'll look at them.
Advanced Slacker
Liked 2,537 Times
The 2022 Canefield Tilt that replaced it is a phenomenally more capable bike overall. Mainly due to the geometry, in particular the fact that they finally figured out how to make 29ers nimble and fun.
Likes For Kapusta:
Location: '16 StumpJ, Salsa Mukluk, Soulcycles SS, Dean Colonel HT, BMC FourstrokeTrail, Dean Torres CX, Santana Visa Tandem, Trek T2000 Tandem, Cupertino MTB Tandem, FreeAgent26"Xtracycle, Dirt Drop Dingle, Jamis Dragon Dingle, Airborne Skyhag SS, SSDean Cols
Quoted: 70 Post(s)
Liked 116 Times
Every so many years they have to change the tire-sizes or some other feature so they can tell everyone that their current bike is outdated and they have to buy a new one to remain "competitive" and current. This is complete hogwash as 90% of riding a bike in fast or technical challenges is the rider, the bike makes little difference as long as it is in good shape. Records were set on MTB courses with 26" wheels back in the 1990s that 99.999% of the riding population will never be able to get close to even if they are riding a $15,000 E-MTB.
Yet I still have to try all of the tires sizes out. I love them all.
Likes For Sorcerer:
Quoted: 70 Post(s)
Liked 116 Times
Sorry if I fed any trolls.
I was in a bike shop going out of business. I just realized I saw 27 1/4 tires in there . I better get a pair while I can.
Now back to the 29x3.0 boost forum...
Bikes: 3
mountain bike tire sizes
Mountain wheel diameter is generally 26 inches, the limit wheel diameter is slightly smaller than 24 inches. If you are daily cycling, should choose 26 inch mountain bike is more suitable, this size is the most common, accessories are easy to obtain, cycling efficiency is higher. 24 inch except for show cars, generally only suitable for teenagers transition size.
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Bikes: 3
No,I'm not a bot,what you said confused me,I was just trying to be active to fit into this place.Maybe my point of view is not very practical, but it is also something I learned from the others and hope it helps.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,035 Times
Quoted: 822 Post(s)
Liked 1,961 Times
Phone is push-button dial on the kitchen wall, my van is an 85' GMC 3/4 ton cargo which some deceased friends of mine bought brand new, GM sold the same van-body from 71' through I think 1996, but I would not want one later than mine because it still has a Rochester Quadrajet carb and a distributor ignition, both of which I have many decades of experience with and can take apart and assemble blindfolded. When EFI/ignition computers go bad, there is no repair but throwing the computer out and installing a new one. My van does have HEI ignition, but I have procured a points distributor from the pre-74' model which will swap in easily so it will be 100% chip-free. I am no hurry, but someday if I am lucky I may inherit my father's 70' Impala. This is what I haul my MTB in if the single-track is too far away for a 60 year-old to ride to.
I had a 1995 Whirlpool Refrigerator that was still working great in 2020 without ever being serviced or repaired before I gave it to a friend in need who still has it.
My 2020 Whirlpool has already has had a few plastic parts and the motherboard replaced.
If it works for you, why replace?
Quoted: 2976 Post(s)
Liked 1,182 Times
I'd be afraid to drive that van across town let alone on a 3000 mile round trip fishing excursion out west that I do every year.
