Tire pressure
Old 07-19-22, 07:00 PM
maclane.reid
Quoted: 7 Post(s)
Tire pressure
Hey all, I’ve been cycling for some years now and decided to take a statistics course. Part of this course requires a project to compare two groups and I chose to compare tire pressure of road bikes vs. mountain bikes. Hoping I might get a wee bit of help from everyone, if possible, by answering two questions… all of the information will remain anonymous as well.
Do you ride a road bike or mountain bike?
What is your tire pressure upon inflation?
Thank you for any replies.
maclane.reid is offline
Old 07-19-22, 07:26 PM
smd4
Quoted: 3511 Post(s)
Liked 2,926 Times in 1,775 Posts
This should be fun!
1) Road bike
2) 140 psi.
smd4 is offline
Old 07-19-22, 07:32 PM
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times in 348 Posts
You do realize the number of variables involved in that question is infinite. Do you want the tire sizes also? Or brands and models? Or maybe the elevation they'll be used at? Not trying to be difficult, it's just such a broad based question it's almost impossible to give it any credence. But here goes.
On my road bikes I run 80+ PSI depending on tire width. On my MTBs I run anywhere from 20-50PSI, again depending on the tire width and the expected terrain that day.
Of course this will remain anonymous because we're all anonymous here haha. Good luck with your class,
SpedFast is offline
Old 07-19-22, 07:33 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
Originally Posted by smd4
This should be fun!
1) Road bike
2) 140 psi.
140psi?
Have you considered solid tires for more comfort? … lol!
John
70sSanO is offline
Old 07-19-22, 07:35 PM
smd4
Originally Posted by 70sSanO
140psi?
John
Nope. Pneumatics are plenty comfortable. And lighter, of course!
smd4 is offline
Old 07-19-22, 07:36 PM
Daniel4
Bikes: Sekine 1979 ten speed racer
Quoted: 1481 Post(s)
Liked 639 Times in 437 Posts
Road bike.
80psi
Daniel4 is offline
Old 07-19-22, 07:39 PM
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 884 Post(s)
Liked 2,307 Times in 1,117 Posts
1: Road bike
2A: Modern bike, about 95 psi for my current 25mm tires
2B: Vintage bike, whatever the sidewall states the max pressure is because back in the day I thought they had to be as high as pressure as possible
Chuck M is offline
Old 07-19-22, 08:01 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
140psi?
Dear god, don't get him started again.
Rolla is offline
Old 07-19-22, 08:05 PM
Rolla
Guest
Mountain bike (27.5" X 2.8", tubeless): 19 psi rear, 17 psi front
Road bike (700c x 28mm, tubes): 95 psi front and rear
Rolla is offline
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Awesome. Post 1...**** post. Good job OP, I'm sure you'll end up being very popular around here.
cxwrench is offline
Old 07-19-22, 08:12 PM
Chuck M
Happy With My Bikes
Chuck M's Avatar
Quoted: 884 Post(s)
The OP was thankful for that.
Chuck M is offline
Old 07-19-22, 08:17 PM
veganbikes
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times in 2,665 Posts
Generally I go somewhere within the range of my tires.
My bikes are road, mountain, touring and a hybrid in a pear tree. Loads of bikes loads of different pressures your question is rather useless. Tire pressure has little to do with anyone else and is more to do with you and your riding, weight, tires, yada yada yada.
veganbikes is offline
Old 07-19-22, 08:30 PM
maclane.reid
Quoted: 7 Post(s)
It’s an elementary statistics class. Definitely agree with you, just need to work with what I have. I already simplified it more then I would like but yes, there are many a variable like wheel size, tire width, you name it etc.
Old 07-19-22, 08:35 PM
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,484 Times in 3,208 Posts
Do you ride a road bike or mountain bike? What is your tire pressure upon inflation?
Required pressure for road tires is generally a function of total weight (bike+rider+rig) and tire width, with the latter being an inverse relation. The rear tire requires more pressure than the front.
I weigh 160lbs; my bikes are around 20lbs + rig. So ...
​​​​​​28mm rear with groceries = 90 lbs
25mm rear road = 90lbs
25mm front road = 85lbs
23mm rear road = 100lbs
23mm front road = 95lbs
SurferRosa is offline
Old 07-19-22, 08:41 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Yeah, that was a little harsh. If it's for a class it's legit. Therefore:
Road: (40mm tires) 34frt/38rr
Mountain: (2.4-2.5" tires, tubeless) 18-19frt/23-24rr
cxwrench is offline
Old 07-19-22, 08:43 PM
Atlas Shrugged
Quoted: 1248 Post(s)
Liked 1,323 Times in 674 Posts
There is strong logic which says that front and rear pressures should be roughly the same.
https://www.renehersecycles.com/myth...gher-pressure/
Atlas Shrugged is offline
Old 07-19-22, 08:53 PM
Koyote
Quoted: 6963 Post(s)
Liked 10,963 Times in 4,688 Posts
I ride a road bike.
95 psi front, 85 psi rear.
Koyote is offline
Old 07-19-22, 09:04 PM
koala logs
Quoted: 347 Post(s)
Liked 170 Times in 140 Posts
140psi?
John
Or ear protection in case of unexpected explosions.
koala logs is offline
Likes For koala logs:
Old 07-19-22, 09:05 PM
70sSanO
70sSanO's Avatar
Road: 25mm 95-100psi
Urban/Commuter: 28mm 75psi
26er Mtb: 2.1 Tubed F28psi/R32psi
John
70sSanO is offline
Old 07-19-22, 09:08 PM
drlogik
drlogik's Avatar
Bikes: '87-ish Pinarello Montello; '89 Nishiki Ariel; '85 Raleigh Wyoming, '16 Wabi Special, '16 Wabi Classic, '14 Kona Cinder Cone
Quoted: 699 Post(s)
Liked 409 Times in 255 Posts
Road bike, 700x28c PZero tires at 90 lbs.
drlogik is offline
Old 07-19-22, 11:37 PM
JohnMorgan
Quoted: 5 Post(s)
Liked 6 Times in 5 Posts
Road bike, 100lb pressure, 28mm tyres.
Touring bike, 70lb pressure, 32mm tyres.
JohnMorgan is offline
Old 07-19-22, 11:54 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,928 Times in 2,553 Posts
Road. 95 rear, 90 front. (Even simpler - 92)
79pmooney is offline
Old 07-20-22, 12:01 AM
terrymorse
climber has-been
terrymorse's Avatar
Quoted: 3432 Post(s)
Liked 3,566 Times in 1,792 Posts
Road bike
90 lbf/in^2
Ride, Rest, Repeat. ROUVY: terrymorse
terrymorse is offline
Old 07-20-22, 12:33 AM
Aardwolf
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times in 341 Posts
Road bike
74 front, 76 rear
Aardwolf is offline
LarrySellerz
Quoted: 2700 Post(s)
Liked 486 Times in 351 Posts
Man I really should have finished college or atleast took an easier major than chemistry, no offense OP but this question is so silly
LarrySellerz is offline
