Specialized Stumpjumper FSR XC
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
Trying to get better pics of this bike and find out what size frame it is. Does it look like it is mostly original? The shock looks...cheap?
Any idea of year? 98?
He also has this second bike for sale. Any ideas on what it might be. It has a RS Indy fork. I'm awaiting an answer about what brand the black one is and better pics
He wants $40 for both.....Do I need 2 more bikes...
Quoted: 332 Post(s)
Liked 742 Times
For $40, worth it for parts if you like to tinker (assuming wheels are good, etc.). I wouldn’t count on resale value as older full suspensions are tough to sell.
The black one looks lower end than the Specialized, and that seatpost and suspension will not play nicely together. It does seem to have some alright components though.
Likes For bboy314:
Likes For VtwinVince:
Bike Sorceress
Bikes: Yes
Quoted: 62 Post(s)
Liked 116 Times
Stumpjumper is likely 1999 or 2000. These things ride great for a vintage full squish. Rear shock is a coil shock, not necessarily low end. I've got an old Fox Vanilla that looks pretty much the same once you tear the sticker off. Your frame also has residue from a Fox sticker that was removed, so that points towards Fox being the most likely brand. Coil shocks are much lower maintainence, I've actually swapped out air shocks and forks for coil on bikes that I want to ride frequently. The mounting hardware does look a bit sketchy though, if you notice a bunch of play at the mounting points for the rear shock, I'd go through the effort of tracking down the correct hardware before riding it. If it seems solid, then perhaps the QRs they butchered to make that hardware are actually the right size to do the job.
Black one is probably a Gary Fisher Joshua. Not a great suspension design, but if you give it a set of biopace chainrings, the pedal bob is greatly reduced and they become ok to ride. Looks like it has some decent parts on it too. If you want to ride it with the saddle that that height, you will need to cut off the bottom part of the seatpost.
Likes For Arrowana:
Henderson, NV
Quoted: 322 Post(s)
Liked 596 Times
The seller responded with some vauge info. He says he's not a cyclist. He doesn't even know that the brand is Specialized
So the Specialized is a Rockhopper FSR XC. 2000ish?
The other bike just says Trek.Looks like a Y Frame series. Mid 90's?
I'm more interested in the Specialized if anything. Still worth the $40 for both if the front shocks aren't sacked out?
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
At $40 no brainer, assume you are just buying parts. If they end up being better than that, great.
Likes For wrk101:
