Which Single-sided Power meter?
Preferably one that can be upgraded to dual-sided in the future. I don't need to transfer it between bikes so I'm thinking a crank arm.
Bike is a Specialized Tarmac SL6 with 105 groupo.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
I recently bought and installed the Favero Assioma UNO pedals (UNO = single-sided).
Very easy to install and set up, and they are working flawlessly. Look keo compatible cleats.
https://cycling.favero.com/
Likes For terrymorse:
I would second the assioma pedals. They're brilliant. I switched over from Shimano pedals and have no issues. I swap the pedals between my road and TT bikes with lout issue. Takes about 2 minutes.
I think the Garmin Rally come in SPD-SL, but they're not cheap.
if you really don't want to swap your pedals out, 4iiii single sided is an option, but to upgrade to dual sided might be more expensive.
Likes For rivers:
climber has-been
Liked 3,567 Times
Then you’re probably stuck with the Garmin Rally. More expensive, not rechargeable.
https://www.dcrainmaker.com/2021/03/...-look-keo.html
Likes For Doomrider74:
Quoted: 4411 Post(s)
Liked 4,862 Times
I have a Specialized Power Crank (Shimano 105 version) on my endurance bike. The sensor is actually made by 4iiii, but has better weather proofing. It’s been faultless for over a year and very consistent. It was also a very good price on sale when I bought it.
Likes For PeteHski:
Bikes: Nashbar CR5 Ultegra, Trek 2300
Quoted: 14 Post(s)
I have a single sided 4iiii that works well so far but I've only had it for about two months. Installation was painless and it syncs immediately with my Garmin.
Quoted: 9653 Post(s)
Liked 6,365 Times
The Stages 105 arm (latest version) has worked well for me on my Domane.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
With the 105 group, I wouldn't bother going to a dual-sided in the future. There are known issues with instrumenting the right side crank arm for that design. If you're set on a left-side crank arm, you should probably consider that a non-upgradeable purchase. Which is fine, if that's what you want and it meets your needs.
Quoted: 6194 Post(s)
Liked 4,810 Times
4iiii let's you get one sided now and move to two sided later. I think stages does too. I'm still waiting for 4iiii to get my cranks in stock so all I have to do is swap. I used to want PM pedals but crank based is so much cheaper currently.
Looking at a local store, I can only get Stages at the moment. Apparently, 4iiii are having problems sourcing cranks/arms.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
The issue is with the asymmetrical 4-arm right side cranks, so that means Shimano's current 105, Ultegra, and DuraAce cranks. It doesn't apply to the older 5-arm cranks.
Oh, noted. Thanks. Would you suggest pedals are a better option then, if future upgrading to dual-sided is considered? Or just not bother with upgrading to dual?
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
That said, we can't always know what we might be interested in doing a few years from now. Sounds like you have good reasons not to go with pedals. *if* you think you might need total power in the future, you might want to consider a crank spider PM, like the Power2Max or Quarq or SRM. I often recommend the used market for someone first starting out so they can get in at a lower price point and figure out what they'd do with the data. I just bought a spare Power Tap hub that was being sold by someone who was switching to (dual-sided) pedals: I paid $125. Power Tap hubs have been discontinued so as used power meters they're really kind of a bargain.
It really depends on what you hope to do with the data. For many purposes, single-sided is fine; for a few, it isn't. I happen to do some of those things, so I need as much accuracy (not just consistency) as I can get -- but I'm in a minority and many many riders are perfectly fine not doing those things.
Maybe I'll stick to single-sided as a starting point and see where I go with it.
I'll have a look around for second hand stuff as well.
Liked 4,862 Times
I think a single sided crank power meter is fine for most people and obviously a lot cheaper. Pedal based systems seem to be more hit or miss in both reliability and consistency, but handy for swapping between bikes.
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
So not this one https://www.google.com/shopping/prod...bTnBhEQ9pwGCAc
Well, it makes me feel even better about my purchase. It wasn't just a bare hub but came in a wheel, and I did a static torque check to validate that it's working properly. I still use rim brakes and lots of bikes are going to discs, so that's another reason why you can find bargains in used Power Taps if you're not in a hurry.
I might add for people worried about longevity and serviceability I occasionally ride hubs from the wired and 2.4khz era that still work fine and pass a static calibration test.
Likes For asgelle:
Quoted: 229 Post(s)
Liked 327 Times
I have a 4iiii 105 single-sided. It basically just worked. Though if you can get a Stages then that should work well, too. I'm not sure I've read of anyone having any problems with one. A pm was one of the best things I got for my bike. Allows for some consistency between indoor and outdoor riding.
Likes For guachi:
