Headlight For Daytime Riding
Quoted: 200 Post(s)
Liked 65 Times
I only cycle during the day. I am looking for a headlight with a strong strobe that would attract attention during the day. There are many offerings on Amazon. Some have fantastic claims of 9,000 lumens. Any advice would be appreciated.
Quoted: 1364 Post(s)
Liked 1,678 Times
Whatever you get mount it on your helmet so it can be seen above the hood of cars and through their windows. And when you turn your head it will be pointing at what ever car you are looking at.
I noticed a huge difference since putting my flashers (front and rear) up there.
I use a Lezyne 400XL which has a double flash mixer which is plenty bright. It's usb rechargeable and plugs tight in to a usb socket.
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 572 Times
I use a blinking white light forward during the day.
All the models I have from Cateye (available) and Cygolite (I’ve found durable) have been discontinued, but I expect current models would be suitable. Based on me seeing other cyclists during the day, lumens don’t need to be high. Moderate “be seen” models suffice.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Quoted: 2496 Post(s)
Liked 739 Times
I think the o.p. is ________ (rhymes with rolling) for negative reaction to their thought of putting airport runway landing marker level illumination on their bike as they ride around town. 9,000L. As if. Amazon is just a vast options market where everything from good to bad to worse can be obtained. If you stick with known purveyors of lighting equipment you won't find any claiming 9,000L. My newest light is a 1200L Cygolite and I don't run it during daylight. There are plenty of more effective ways to be seen in daylight.
Why does it matter? Because it really does take a LOT of lumens to stand out in the daytime, even strobing, and battery packs only have so much capacity. My MagicShines are 800L and the battery packs weigh close to a 1/2 pound each. The status light is going from green to blue in 20 minutes at high power. It's solid red at 40 minutes on high power. An hour and something at medium power. The Cygolite 1200 is self contained. I doubt it would run longer than 20 min on high power. I never run it at full power. I'm usually at half power. That's more than enough time for daylight to take over.
Quoted: 4227 Post(s)
Liked 2,488 Times
Quoted: 968 Post(s)
Liked 1,631 Times
Cateye with rechargeable AAA batteries...
Liked 2,488 Times
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I eventually moved to Dinotte lights front and rear. I prefer the form factor, which is not like a flashlight. And it's amber, not white, which may or *mayn't matter at all.
Dinotte Quad Amber front light
*I didn't know mayn't was a word, but SpellCheck seems to like it.
Quoted: 768 Post(s)
Liked 1,745 Times
I been using the Bontrager Ion 800 for many years, very bright, has a bright flash and several other modes. Also used it when I was commuting into the office at 2 am. I recently picked up a second one that is 700 lumen.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Super Bright on Strobe.
buy Warm Light Cree XML-T6 1200-Lumen 3-mode LED Bike Light Set - Warm Light Bike light online lightmalls
Red Color Head Bicycle lights/Headlight With Cree XML-T6 Emitter 1200 Lumen 3 Modes Bike light Kit (lightmalls.com)
Fred "The Real Fred"
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
I've been using tactical style headlamps that have a slow strobe. They weren't expensive and they came with handlebar clips. @200 lumens and use either AA or 3.7V 14650 style rechargeable batteries that last @2 hrs on a charge. I carry spares and throw them in the charger when I get home. I've had cars during the day tell me my lights are too bright. I use them for night riding on unlit roads on low and they last @5 hrs. I think I got a 3 pack for 10 bucks from AZ. My rear tail light is a 120 lumen Entity with 8 different functions. On slow flash/high it lasts more than 5 hours. I feel the rear light during the day is more important but really want people pulling out of side streets/driveways to see me coming too. I put the rear light on my helmet and have a steady beam light on the front for add'l light at night. Along with the camera on the helmet sometimes it feels a tad unwieldy so I only pop the headlamp on up there for night rides or when I head out later in the eve.
Quoted: 800 Post(s)
Liked 512 Times
Bontrager Ion200 RT has not let me down yet. Small. Light. Casts a bright enough light. No complaints.
Squeaky Wheel
I'm another Dinotte fan. The Amber daytime running light is very distinctive and really stands out even in bright sunlight. The lights are expensive, but the build quality, reliability and support make them worth the money if you ride on the streets a lot.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I’ve had several Metro’s as well. The mode with the low steady light with intermittent triple flashes seems really good. Gets attention without disorienting drivers like some strobes do.
climber has-been
Liked 3,567 Times
Now that it's quite sunny and bright, I've switched over to the strobe flasher. I think it's more visible, and the battery lasts much longer.
When I was stopped at a light the other day, a motorist commented on my lights. I thought he was going to say they were annoying, but instead he complimented me on how visible they made me.
Quoted: 5224 Post(s)
Liked 3,585 Times
this one seems fine Planet Bike Blaze 150 SL Bike Headlight
