best and easiest source for touch-up paint?
Should Be More Popular
Quoted: 22610 Post(s)
Liked 8,934 Times
Sorry if this is a naive question, but searching the forum suggests the best, easiest, and most inexpensive method to find touch-up paint is, ahem, nail polish.
Now for a modern carbon fiber frame this might make sense, but I am doubtful that a steel frame would be protected from rust, etc by nail polish....but what do I know? I don't use the stuff on my nails.
Please let me know if this is a good way to go....should I go to the hobby shop or the drugstore to get my touch-up paint?
Doug
1986 Alpine
Doug
1986 Alpine
Tilting with windmills
Bikes: Many
I'm planning on using Testor's model paint for a couple of touch ups. Automotive touch up pens are an option as well.
Veni, Vidi, Bici
Bikes: Colnagos (2005 Brera Art, 2007 President LdV, 2007 CF6)
Liked 8 Times
I like paint markers that you can get at just about any hobby store. They're about the size of a pen, but you shake them like a spray can. Some of them have very fine tips that are good for detail work. Like nail polish, they come in a wide range of colors. I think paint markers or nail polish would be fine though as far as keeping moisture out.
I was a little suspicious about Testors model paint enamel, too. (I mean, honestly, the stuff I used to paint my model of the USS Forrestal in the 4th grade??) But the Vintage Trek website suggested it—at least for Trek's Dupont Imron paint—so off I rode to the hobby shop. The guy—obviously into terribly intricate, impressive, difficult-to-assemble models in a big way—takes one look at my bike, an '85 "Race Blue" Trek, and says "wait here". He comes back with a small bottle of Testors "French Blue". "That's your color", he says. Looks a little dark to me, so I ask him if maybe I should get a lighter blue to mix 'em. "Nope… that's all you need." Took it home and, sure enough, it was a perfect match. I was impressed.
You would be surprised at how well nail polish of the appropriate colour works. I've used it for years, and some 10 years old touch-ups on my steel road bike are still very well-covered. But if you want more, just match as closely as you can with Testors model paint.
Liked 7 Times
I like clear nail polish because the bike does not look WORSE after I touch up little scratches and nicks. With paint, I always make it look worse, and simply draw attention to the amazing numbers of scratches and nicks on my bikes.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Hobby Lobby, model enamel, less than $2 per bottle.
Liked 8,934 Times
Thanks for the tips....i will have to find a good hobby shop near me and ride there sometime to see if I can get a good color match (it somehow seems "wrong" to drive for bike-related activities).
Doug
Doug
+1 I've had good results with both. Sometimes it's hard to get the exact color, though, and in my experience a slightly lighter touch-up will be less noticeable than one that's darker than the original paint.
Liked 8,934 Times
As a follow-up query, if one has small rust spots (like a few mm in size) how necessary is it to use a primer before using the touch-up paint?? I was hoping to brush down to shiny metal, add a dab of naval jelly, and then put on the touchup.....is that a good strategy??
Doug
Doug
Quoted: 443 Post(s)
Liked 27 Times
Doug
Doug
Liked 8,934 Times
Vintage French Bike Fan
Bikes: Peugeot UO-8, Peugeot 80's 12 spd
You want an etching primer. Testor's won't likely sell that. A good start would be Rustoleum's rusty metal primer (it's orange). The can is waaaaaaaaaaaaaaaay more than you need, but if you use a fine point model brush and cover with Testor's lacquer that should be a substantial repair.
Karl
Karl
Liked 8,934 Times
Update: On my ride home from work today, I stopped by a small hobby shop. I luckily found a color that is reasonably close to mine (probably "95%" match - not quite right but good enough for my purposes).
I tried it on a few scratches and non-rusted bare areas of my frame, and it looks ok.
And the good news is that for the 1/4 ounce bottle (testors high gloss enamel), the guy let me have it for $1. I am in cheapskate heaven!!
Now I have to find an inexpensive 1/4 ounce bottle of etching primer and naval jelly for the rust spots....any ideas?
Doug
Doug
Quoted: 378 Post(s)
Liked 1,410 Times
Wal-Mart has a rust remover, cheapo, in a white bottle. It works well with a Q-tip or toothbrush. Follow the directions. And remember all this is so much easier with a frame free of other parts.
If I use nail polish to touch up, I smooth it out and then mask off the section well and shoot some hobby clear acrylic over it, very little.
I've had good luck with Testor's, and also Duplicolor automotive touch-up paint (also at Wal-Mart and lots of other places). Burgundys, silver metallics, black and some whites, in particular. Good applicator makes me look more dextrous than I am.
And sometimes, like A. Winthrop and JunkYardBike have told me, sometimes, you let it ride and ride it.
Quoted: 443 Post(s)
Liked 27 Times
For anybody that has a white Peugeot, Duplicolor white wheel paint is a close match. It's acrylic enamel, not lacquer like their touch up paints. That means it's more durable. The stays, seat cluster, fork and part of the head tube on my PA10 have been repainted and nobody spots it. I use white rubbing compound after the paint cures for a few days to even out the gloss.
Liked 8,934 Times
Thanks again for the tips....if I use cheapo or an etching primer, can I skip the naval jelly step???
Liked 8,934 Times
Doug
Non Tribuo Anus Rodentum and off to the next adventure (RIP)
I'm assuming you didn't wipe the area down with spirits before painting either?
I'm not a painter, but I stayed in a Holiday Inn. Either way, chemical or mechanical the rust has to come off, the metal cleaned and preferably etched and primed (See self etching primer above) then painted in a low humidity environment with a compressor and paint gun. A quick scuff with sand paper, a dusting and a shot w/ a rattle can just won't do it.
BUMP - How should I do this frame?
Sorry, to revive a dead thread - but I am debating if I should touch up or do a full strip/repaint?
Bikes: 5 and counting
finger nail polish, cheap and comes in a whole lot of colors with free little brushes you never have to clean.
Lost at sea...
Bikes: Schwinn Paramount (match), Trek 520, random bits and pieces...
Reviving again in order to clarify a few things in this thread:
Self-etching primer is sold in a spray can for a reason; it's a great product for a full frame home paint job. It is absolutely unnecessary for a small touch up. If you are spraying it into a cup and then brushing it on, you are using it wrong. The product is meant to be sprayed on very lightly prior to using a standard metal primer. It will also absorb moisture in the air, and should be covered with a base coat asap if you do use it on a project.
Naval-jelly is an acid. Using naval jelly will "etch" the metal and help the paint to adhere. It serves the same purpose as self-etching primer. It's highly amusing to see one recommended while the other is discouraged... but hey, that's the internet for you!
Applied to the surface, the jelly does not need to be neutralized (but excess should be wiped off per manufacturer instructions). [I've coated the entire inside of a frame with the stuff and rinsed it out with standard tap water prior to applying frame-saver after the frame was dry; there is no need to wash out a frame with baking-soda or any other neutralizing agent].
There are better products than naval jelly available that are usually located on the same shelf. Grab a rust-reformer which is a white milky looking liquid that will convert the rust using the same action (phosphoric acid to black ferric phosphate) as the naval-jelly and will also leave a paintable surface which doesn't require a primer and is sealed against moisture. The excess can be cleaned off with acetone once it has dried. We used this product on pumps in a salt-water environment at the bottom of an aircraft carrier without any additional top coats of paint; it does the job. That said, naval jelly will be fine too, but, it is recommended to use a primer with it. FWIW, I find that the Loctite brand (sold at Ace, Home Depot, etc.) works better than the Rustoleum brand sold at Walmart.
@datlas, if you are able to seal out moisture after removing the visible rust, there shouldn't be a need for any additional rust-proofing. A good primer/paint will seal out moisture. Rustoleum makes a rusty-metal primer which can be used on a heavily rusted surface (visible rust). The benefit of a rusty-metal primer is that it has zinc added into the paint which is a sacrificial anode; the zinc will oxidize instead of the steel... stopping the rust cycle. For most cases, the "clean-metal primer" will be sufficient to seal out moisture without the added zinc. If you had rust after painting, it is due to moisture under the paint (or the paint itself was allowing moisture to pass).
Testors enamel or standard nail polish will adhere without a primer, this is not a necessary step (but it may be helpful to seal out moisture)... especially on a bigger chip. I probably wouldn't even bother on any chips smaller than a pencil eraser.
Speaking of pencil erasers: grab some 600grit sand paper and use a hole-punch to make small sanding discs. Use rubber cement to attach these discs to the top of a pencil eraser. Use that to prep your work area. For the most part, I just use rubbing alcohol to remove any light surface rust but I love the pencil trick.
The best applicator is a clean tooth pick dipped 1-2mm into the model paint. Place the tooth pick in the center of the chip and allow it to flow by capillary action into the chip. Several coats may be necessary (keep them as light as possible until the chip is filled). After it has dried for a few days, use a 2000 grit sand paper to level everything out (you can buy this in the automotive dept of walmart). Wait a month, then top with a wax finish.
@Dilberto, if you are happy with the color and want to maintain the decals... just touch it up. Otherwise, give the frame a good cleaning, scrape away any loose paint, and start with a few layers of filling-primer. On an aluminum frame, it doesn't matter so much. If it was a steel frame, I'd suggest a full strip if there was any possibility of hidden rust.
Again, sorry for another revival... my first post here too. Some of the bad info in this thread was rubbing me the wrong way.
Current Restoration Projects: 1998 Schwinn Paramount / 1977 Motobecane Super Mirage
Keener splendor
I've been known to bring a fork into stores, particularly drugstores and beauty shops, to find the right nail polish.
Thanks for the tip, I guess. I'm anal, but I'm not this anal.
