Components could have bigger impact than frame
I now own a canondale caadx with ultegra comonents and it is buttery smooth. I am loving it. I used to have a carbon synapse with apex components. The caadx is so much more enjoyable to ride. The shifting is just so smooth. At one point I had a carbon spec roubaix with ultegra components and it was also a great bike that i loved, but was twice as much. No way do I think that bike was worth twice as much as my caadx. The diiference mainly was the frame. Just makes me beleive that with the way frames are built these days that the difference in a bike off rack is more in the components than the frame. As long as the bike fits you properly, the components to me are more important.
I read so many posts that people recommend getting the best frame and upgrading components later. I say get a bike with that fits well with the best components. I think that the components play a bigger role in how enjoyable a bike is to ride than the material the frame is made out of. I would rather have an aluminum bike with high end components than carbon with lower end components.
Also the whole carbon is smoother thing I think is way over hyped. Tire width plays a much bigger role than frame material. If you want a bike tahat is comfy for long rides then get a bike that can fit at least 28mm tires. That will make a much bigger difference in ride quality than carbon vs aluminum.
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Do you believe your aluminum CAADx with 28c tires has as good if not better ride quality than a carbon Synapse with 28c tires at the same pressure?
I find that hard to believe if the case but want to see if you are comparing apples.
I would agree that once you get up a certain price point for a complete new bike you reach a point of diminishing returns. Especially with the frame.
As far as the components go. I think from about the 105 level. Most people would have a hard time feeling the difference in performance.
Quoted: 6556 Post(s)
Liked 58 Times
Would somebody please define smooth. It seems to be terribly overused here. Kind of reminds me of a "bold" wine. If everything is so buttery smooth (ugh, I hate that phrase), OP should not have to pedal at all and be able to just slide down the road.
Quoted: 63 Post(s)
You sir are a troglodyte.
Texas Tornado
Bikes: '14 Specialized Roubaix SL 4 Full Ultegra 6800
Having ridden aluminum, then carbon on the same roads, I can't completely agree. carbon sucks up more of the road buzz, a lot more actually. And I can feel that it's far more stiff than aluminum was (Allez vs Roubaix SL4 here).
Yes, the components will help with weight, shifting, etc., but it sounds to me, OP, that your Roubaix didn't fit you as well and this bike is just right for your body type, hence the perceived "better bike" feel.
Liked 58 Times
You should be aware already that racial slurs have no place on this forum. If you persist in insulting my ethnicity, I will be compelled to report you to the authorities.
My Argon 18 Krypton is flamboyant with hints of chocolate and mulberries.
My Mercier Draco AL is assertive with mild cat piss.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
What tire pressure are you using? The only way this makes sense is with 28 tires at low pressure so everything is squishy smooth.
Quoted: 63 Post(s)
Quoted: 8313 Post(s)
Liked 9,108 Times
Liked 58 Times
I didn't know Mercier came from New Zealand. Oh wait, you said mild. Never mind.
pan y agua
Quoted: 1456 Post(s)
Liked 733 Times
I.
I.
So most of what you're experiencing may well be that the Caadx fits you better, and the geometry fits your riding style and objectives better.
You could get lost and die.
You could hit a tree and die.
Liked 58 Times
I've been meaning to build up a pair of old time wooden wheels. I just can't decide if I want American or French Oak. I am leaning toward French. It would be neat for my bike to ride like a "Limousin".
Liked 58 Times
See, I think so too. And that fits with whether the oak should be new or used. The ride would surely be mellow with used oak, but the new would likely be toastier, don't you think.
pan y agua
Liked 733 Times
Bikes: Cannondale SystemSix Carbon
This is very interesting since I rode with a guy last week that upgraded the exact opposite. He went from a Caadx to a new synapse with disc and was loving it. I asked him how it felt position wise to the caadx since I ride a systemsix and he thought the position was more enjoyable but not so aggressive.
Quoted: 550 Post(s)
Liked 325 Times
Perfect match for a Renovo frame
Bikes: Ax Lighntess Vial EVO D (+ Paduano Fidia)
Would be interesting if titanium was added to this list. I've seen claims carbon can be made as the smoother option, but i've seen same claims regarding titanium. Supposedly much better at damping the frequency of vibrations. Personally i am not swayed by the larger tire dimensions, and not too stiff frames either for that matter.
