Help with frame ID.
Help with frame ID.
Any ideal what this might be? Bottom bracket shell is 68mm .
Semper fi
Semper fi
Semper fi
Semper fi
I’m guessing the for Tange fork isn’t original.
Semper fi
Semper fi
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Viscount/Lambert, repainted and with replacement fork. Those are nice riding frames. Check the bottom bracket spindle; if it's not tapered, you'll want to replace it.
Thanks
Semper fi
Semper fi
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
looks like the spindle has taper so a (sensible) replacement was made. The fork clearly is one (and not "deadly", so that's also good). The one thing not improved is the pinch bolt collars which can be sheared of if you go at them too hard so be careful with that. The plain gauge (but thin-walled) cro-mo tubing gives them a nice lively ride, can be slightly "whippy" for some folks.
Liked 1,062 Times
What does the owner say sloar ?
Can you fit a conventional crank on the spindle (Ital/Brit/ISO/FR) or can you only fit the dreaded Viscount crankset (TA copy) with sub-par no-taper square bore?
