I need to get better on the hills
#76
Bikes: yes, i have one
Quoted: 1139 Post(s)
Liked 1,182 Times
If you're in Las Vegas, you may need to head out to Mount Charleston and do hill repeats. Or do repeats of your local hills in a larger gear than you normally need to simulate steeper terrain.
Getting better at climbing is one of the most rewarding activities in cycling. You got this.
#77
To help with the wobbling don't stare at rhe front tire. Keep your head up so you can see the horizon.
#78
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2588 Post(s)
Liked 5,649 Times
i use a Garmin HRM but the OP is concerned about costs, hence my suggestion. Thank you for your concern.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
#79
Quoted: 446 Post(s)
Liked 1,045 Times
I've been dropped by men, women, old, young, fixed and geared climbers alike, but I'm always motivated to tackle hills and constantly improve. In my eye, a strong climber is the most impressive cyclist you can be. Also I find climbing can involve some strategy. For example a dedicated climber might not attack a steep section of a hill right after a fast descent, but I find sections like this good opportunities to go into high gear and power up the hill if you have the muscles to do so. Also proper breathing control to keep your blood/muscles oxygenated, mental pre-visualization of reaching the top can overcome body pain and I even like to smile on the strenuous climb sections which has been documented to help cycling performance during peak exertion. Also I find you can activate different parts of your leg muscles based on your saddle positioning. Lastly, make sure to be well-fueled. I've done bike rides during carb-cutting and it literally feels like my body is sputtering with no fuel in the tank. With a well-fueled body it feels like I'm running on high octane gas with all cylinders firing.
Likes For jonathanf2:
Likes For eduskator:
#81
Rider. Wanderer. Creator.
Bikes: Bike Friday Pocket Rocket, Cinelli Hobootleg, Zizzo Liberte
Quoted: 394 Post(s)
Liked 783 Times
Climbing will always be a challenge, but the "getting better" part, i.e., tackling a hill faster and/or easier than you've done in the past, is very satisfying. It's a very tangible measure of improvement.
#82
Quoted: 969 Post(s)
Liked 1,632 Times
So how far did ya ride today?
Well, I rode 14 miles but pedaled 7... Ha
Likes For zandoval:
#83
Klaatu..Verata..Necktie?
Quoted: 10442 Post(s)
Liked 11,918 Times
Ya. This is the stuff I'm still learning about. It's hard for me to get a good grip on what I need for these types of climbs since my current gearing is more than adequate for the modest hills in my immediate area. I have to drive a good 30 miles or more to get some place where I can duplicate the kind of grades I rode last Saturday.
#84
Liked 11,918 Times
Further to above...
Climbing is really the only way to strengthen yourself for climbing, so if you plan to ride more events like the one last weekend, it might be worth driving a bit twice a month to do a long ride with some serious climbing. Also, yeah, you need lower gears. Getting a 12-25 or 12-28 cassette would do wonders - I assume you're running a triple?
About losing weight - yeah, that'd be great, but it's also possible for us heavier riders to become better climbers. You just have to do it. And the more you do it, the better you'll become. You can find lots of videos with advice on climbing, but the key is finding your own pace. As a heavier rider, you'll probably want to stay seated, but also, for the steep pitches like inside switchbacks, standing up can help you power through them. Standing up is another thing that benefits from practice. If there are any 30 second steep pitches in any of your nearby moderate hills, start doing them standing, probably going 2-3 gears higher than you'd do them seated. 3 years ago, doing 10 seconds of climbing out of the saddle was really difficult, but I started practicing doing it for longer and longer stretches, counting the pedal strokes, and now I can do it for a lot longer.
#85
Quoted: 4420 Post(s)
Liked 4,873 Times
Even with a 11-34 cassette, OP's cadence would still be very low if he climbs at 4.2MPH. A gravel bike or MTB would be needed to accommodate this speed and reach a ''reasonable'' cadence (80+).
I use a 10x28 cassette on a 35/48 crankset and 10kph (6.2mph) is the slowest I can go if I want to maintain a reasonable cadence.
I have the same crankset as you, but a 10/33T cassette and on some rides that 1 lower gear makes all the difference between riding and walking the steepest hills. There are times when I would very much appreciate an even lower gear to increase cadence a little and reduce pedal force.
We are now starting to see pro riders using gravel gears on the very steepest climbs. Roglic at the Giro Mountain TT was a good example. I believe he had a 42T cassette, although he did run a 42 or 44T chainring. But when you are putting out 500W+ on the climb then it looks like a very low gear relative to what we would use.
To give some idea of the power required just to barely turn over the cranks on a 20% climb, I was having to put out a minimum of around 350W to keep moving without stalling. That’s with a 35/33 gear. That’s pretty close to my VO2 max power so only sustainable for around 5 mins and then I would be gasping for breath at the roadside. Any reduction in gearing would be helpful in that scenario, just to keep the minimum power requirement realistic.
Likes For PeteHski:
#86
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 646 Times
OK, guys. I didn't intend to abandon this thread, I just got caught up with work the last couple days. But I took a minute and went out to the garage and checked my gearing. Now this is ONLY the tooth count for the lowest (highest?) gear, but I have 30 teeth on the front and 23 on the back.
As far as the fitness, I don't think it's so much that I'm not fit, at least from an endurance or strength perspective. It's that I'm carrying too much weight. I got pics from the event tonight. I have virtually no fat on my arms or legs but I hate to admit I'm pretty soggy around the mid section. Don't want to give too much away but I'm carrying a whole extra bike worth of weight that's not doing any work.
OK, I don't want to come off like a ***** but I can tell you that will probably never happen. First, it sounds way above my pay grade. Sounds like a lot of investment in just getting that set up. I buy old, used bikes because I can't afford even entry level (quality) new bikes. Second, I am a loud and proud technophobe. I barely get online and post on forums, and you're talking about bluetooth and apps and connectors. Just too far beyond my capabilities. Sounds interesting and all, but just too overwhelming to me.
Glad you're being able to recognize where the most productive areas are for improvement. Dropping that torso weight is not only gonna make you lighter, but the overall body metabolism will improve - the extra weight layers do cause heat problems, internally, which the body needs to deal with at the same time as it needs to provide for your performance requests.
I sortta remember one of your bikes image - SPecialized Roubaix. If that's the one you're using, that era Roubaix came with 9 spd and 10 spd setups - depending on the model.
In either case, you could get a 12-27 or 12-28 cassette for quite reasonable costs - $40-50ish. Those will still have plenty of options where you most often ride, but also have gears that will help on steeper grades...
For getting in some real hill climbs, it's worth the drive 1x a week. Maybe find a good place closer to you, 6-7 miles from the 'climb'. Start your ride from there, using the approach to the climb as 'warmup'. do the climb and then the ride back to car as 'cooldown'.. I think you'll experience some real improvement, not just in climbing, but also on the 'flats'.
If/when you're able to spring for a good basic heart Rate device, strap which comms with a cell phone app, or dedicated chest device with handlebar
wrist watch' mount - will be one of the most useful, and cost effective things you can do to improve your riding, training and performance overall.
Ride On
Yuri
#87
pan y agua
Quoted: 1450 Post(s)
Liked 731 Times
I completed L’etap de Tour ( a full stage of the TDF), won a stage of Everest Challenge, finished 9th in the Brasstown Bald Buster Century, amongst other climbing events while training almost entirely in Florida.
Admittedly riding mountains makes it easier, hence the climbing I’ve done this year for Haute Route. There are guys here at Haute Route from the Netherlands who have only ridden in the flat Netherlands who are doing quite well.
Again, it is mostly about power to weight ratio, and that can be improved,without mountains.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
#88
Liked 11,918 Times
That is really not true. Sustained climbs at their essence are all about power to weight ratio. So intervals designed raise functional threshold power will definitely improve your climbing and can be done on flat ground or a trainer. So while lots of climbing definitely improves your climbing I’ve done almost 300,000 vertical feet this year getting ready for Haute Route Dolomites) it is not the only way.
Admittedly riding mountains makes it easier, hence the climbing I’ve done this year for Haute Route. There are guys here from the narthex lands who have only ridden in the flat Netherlands who are doing quite well.
Likes For genejockey:
#89
Given how most of this country is set up, that may be 30mi on highway, unfortunately. Not everyone is fortunate enough to have something like Foothills Expressway/Junipero Serra on the SF Peninsula to ride between nice climbs!
#90
Grupetto Bob
Liked 5,649 Times
HOWEVER, there are some hills that are absolute beasts that no matter how fit your become they are still horribly difficult (not to discourage the OP, just sayin’ - or you may be faster but you suffer just as much).
Likes For rsbob:
#91
Further to above...
Hi, Jen,
Ride On
Yuri
Ride On
Yuri
If you have a suggestion for a stand-alone HR monitor, I'm all ears.
#92
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Once you get onto sustained gradients >10% then a cadence of 80+ is a pipe dream for all but pro riders. It becomes more a case of just turning over the cranks, which is easier with a 1:1 or lower gear.
#93
Quoted: 394 Post(s)
Liked 783 Times
Part of learning to ride hills is learning how to meter your effort - to get right to the edge of blowing up without blowing up. Modern methods rely upon HR and power meters but even before those devices riders learned how to listen to their bodies and adjust their effort accordingly.
#94
Quoted: 2976 Post(s)
Liked 1,182 Times
HR varies a LOT from person to person. I’m 55yo. My threshold (max sustainable HR) is 170-175bpm. For me, 130bpm is a VERY easy pace. The top end of my Zone 2 is 150bpm.
Maybe 130bpm is your threshold, but you won’t have any real idea until you start monitoring it and getting familiar with how your body actually works.
As for improving climbing ability, it all comes down to power/weight ratio (watts/Kg is the commonly used unit of measure). Improving this number means…
1. Improve power
2. Decrease weight
3. Both of the above
1. Improve power
2. Decrease weight
Jen...what part of you gave up? Lungs or legs?
#95
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
#96
Liked 4,873 Times
In my 20s I had a max HR of 200+ (not measured very often) and now at age 55 it has dropped to 193. It has been at this level for the last 5 years since I started using a HRM for all my workouts. My resting HR is around 60-65 and the lowest I’ve seen in the last 5 years is 58. My LTHR is around 180.
I don’t think there is any inherent advantage to having a relatively high revving heart. I know plenty of stronger cyclists with much lower max HR and much lower resting HR. But it’s very important to know your own personal HR profile when using it to gauge your efforts on the bike. Generic HR max calculators are totally useless for athletes.
Likes For PeteHski:
#97
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I'm going with those who say VegasJen needs to do lots of workouts designed to increase her FTP and therefore her power to weight ratio. Weight loss could help too, but that can be a very difficult thing for some people. Actually, with the right training plan, she might achieve more power and lose some pounds.
I also agree she needs some bigger cogs. The 30 tooth chain ring is fine. That's smaller than a road compact; it's a gravel bike crank. But 23 tooth largest cog? Kind of weird. Go up to at least a 29, or maybe a 32 or 34, and the difference will be striking. We speak of power to weight ratios (usually in terms of Watts per kilogram), specifically referring to FTP, which is the power a rider can (theoretically) sustain for an hour. But we usually don't ride up hills for an hour. Climbs on something like the Santa Barbara Triathlon are considerably shorter; they're each about 2-3 miles and should take no more than half an hour. She just needs to improve her 30 minute power, which will be slightly more than FTP. And remember how a rider can put out more power. It's not just by increasing strength. It's by pushing harder (force on the pedals), spinning faster (cadence), or both. With the 30x23 gears, her cadence was only about 40 RPM at 4.2 MPH. I would bet that with a 30x32 combo she has the strength to turn 60 to 80 RPM, which would yield 4.5 to 6 MPH (twice her walking speed) while not getting gassed. In other words, I think she's overgeared.
#98
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Likes For Broctoon:
#99
Liked 11,918 Times
The discussion of max HR seems off-topic, given the OP doesn't even have an HRM. I do think she'd benefit from one, and they're WAY cheaper than power meters and smart trainers, though.
#100
Liked 4,873 Times
I use a Polar optical arm band monitor, which I find more comfortable than a chest strap and just as accurate - when worn above my elbow.
Likes For PeteHski:
