Road bikes are just terrible. Please explain
I thought I posted this last night but see no mention of it on my account or an alert that it was deleted. I'll try again
As far as I can tell, there are mountain bikes and road bikes. Of course this isn't the case, but I'm not a big bicycle person. I'm comfortable on anything with straight, mountain bike type handlebars. Ive had a Schwinn, Raleigh, and Superior. No clue what type they were, but they could be called mountain bikes to the uneducated. I've ridden (tried to ride) road bikes- anything with "ram horn" handlebars. They were all terrible. The dimensions don't look much different than "mountain" bikes, but I just cant ride them. It seems almost as different as trying a unicycle.
The reason I ask is cause my wife got us a Burley Duet of the "ram horn" style. I've ridden tandems well in the past so I don't think it's that. The sporty seat is a big issue I think. I've always put on beefier, cushier seats. This one (common on all road bikes I've sat on) almost feels like there's no seat at all and I'm just sitting on the post.
Question: What should I modify to get this thing to fit? I'm incredibly comfortable on previously mentioned "mountain" bikes. I can wheelie, jump, and slide. It doesn't seem like I'd be so incredibly uncomfortable on any bike. I have zero ideas:
- handle bar drop? I had one bike (too small) set up with a solid 3" of drop
- Narrow handlebars? I can ride no handed, one handed, with a wrench instead of handlebars
There must be some geometry I'm not considering that's incredibly important. Pedal-seat vertical alignment? Fork rake?
Likes For spelger:
Quoted: 3243 Post(s)
Liked 2,091 Times
You are blaming a whole style of bike on your particular likes about fit on a bike. It's possible to change bars and stems to find a great fitting position on a drop bar bike, obvious as millions buy these and are happy. With a bike that currently has drop bars and wanting to convert to a flat bar you need to change a lot of stuff and it can be expensive. Better to have purchased a tandem that has flat bars from the outset. You need to change 2 stems, 2 h-bars, shifters and brake levers, likely the front derailer, rear derailer, hopefully not the brakes as well. You need to change essentially to a 2X mt. bike shifting system as the road shifters on the drop bar are unlikely to work with the derailers. Best bet is take it to a shop and have them advise. It can run a few hundred $$$.
Likes For Steve B.:
Maybe I came across to harsh toward the segment. I'm just wondering why it feels so incredibly alien to me. It seems that it'd just be uncomfortable, not a completely new learning curve. Do you think the handlebars are the main cause?
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
maybe it's you...send a photo of yourself sitting on the bike....nobody can tell anything unless they actually know how you look on the bike.
Likes For jadmt:
That may be a good point. Is there a "girth limit" associated with this style bike that is more restrictive than others? I don't think I ever noticed an offensive tackle type build on a road bike.
Quoted: 427 Post(s)
Liked 700 Times
Unless the road bike isn't the size you need, it may just be a matter of getting used to a different position on the bike. I rode mtn.bikes for approx. 35 years before owning a road bike. Luckily, I bought it from a knowledgeable and very helpful bike shop. All they did was to put a shorter stem on it to make a more comfortable fit. Now, I was 55 when I bought it and was most likely used to the more upright position, if I had been riding road bikes prior, maybe it would have been ok with the stock (longer) stem. I still ride on the hoods on the road bike, still don't like being too leaned over. I have gone through a number of saddles, the one now is fine, some were torture devices. Different leg muscles are used also (at least in my case). The riding I do on my mtn.bike has me off the saddle most of the time. On the saddle while on the road bike.
Probably just an "adjustment" phase, assuming the road bike is the proper size for you.
Quoted: 539 Post(s)
Liked 466 Times
I was once very obese. I had to lose weight even to ride a MTB. I tried drop bar bikes about 100 lbs later and at first, they seemed incredibly awkward. As my flexibility increased and my belly decreased, Drob bars (Ram horn) became my favorite.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
OP, your problem is...... you are sitting on the saddle as a seat.... and it's not a seat... it's a saddle..... there is a difference. ....and you are probably used to riding a "crank forward" bike.
You need a more aggressive bike fit.
Likes For trailangel:
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
In part, I think it depends a bit on where your girth is. The drop bar road bike generally has a more forward-leaning position than the flat bar bikes. If you have a big belly, this leaning forward can be unpleasant.
If you're looking for a flat bar bike that might be better for the road than a mountain bike, you might want to look at fitness bikes, which are a type of hybrid that is a bit faster on the road than a mountain bike.
I think your basic question is a bit like asking "I like chocolate, but I hate vanilla, how do I make vanilla taste like chocolate?"
Likes For livedarklions:
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 573 Times
It takes a while to work the learning curve on bikes that are new to me.
Likes For DonkeyShow:
Quoted: 4227 Post(s)
Liked 2,488 Times
There is nothing wrong with not liking certain type of bike or handlebars. Some people including myself just don't like drop bars...Just ride whatever bike makes you feel good.
Likes For wolfchild:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
The reason I ask is cause my wife got us a Burley Duet of the "ram horn" style. The sporty seat is a big issue I think. I've always put on beefier, cushier seats. This one (common on all road bikes I've sat on) almost feels like there's no seat at all and I'm just sitting on the post.
Good luck.
Quoted: 8287 Post(s)
Liked 9,064 Times
Take measurements of your most comfortable flat bar bike and try to duplicate them on the drop bar bike. Use the top of the drop bars as if it was a flat bar. There should be no reason why you can't find the same position.
Drop bars come in many shapes and sizes. I use a short reach shallow drop bar on my road bike. My back isn't as flexible as it once was.
And yes, there are offensive linemen on road bikes, but they do trim down a bit. My friend was offensive team captain in college and shrunk down to 265 pounds to ride road bikes and started racing at the velodrome and did well.
Another offensive tackle (college) rode with our club for years and varied between 265 and 280 pounds. Quite strong on the flats, he raced crits as a cat 3.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Tandems can be tricky to size correctly, because both ends of the bike have to fit people of different dimensions. Handlebars are relatively easy to replace, which might solve your issue, but are you sure the Burley is the right size for you? Was this bike a surprise, or did you test ride it first?
As for the saddle, "beefy and cushy" is a recipe for chaffing and discomfort, IMO. There is a middle ground between a cruiser saddle and a the current minimalist one.
Some people don't like drop bars because they're used to having more weight on their butts than on their forearms and hands. The saddle choice can play a role here (again, "beefy and cushy" wouldn't be my choice), but it's also something that people get used to by riding more.
So check the fit carefully before making cockpit changes, but handlebars and saddles can be swapped. Just be ready for some trial-and-error; you might not get it right on the first pass.
ignominious poltroon
Quoted: 2244 Post(s)
Liked 3,445 Times
It might be possible that someone mistook this earnest question, along with the accompanying phraseology, as an example of a phenomenon known as trolling.
Likes For Polaris OBark:
Liked 3,445 Times
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
A genuine post like this is certain to get abundant traction. Especially given the OPs tenure here.
Likes For Paul Barnard:
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 467 Post(s)
Liked 548 Times
I am more or less a middle linebacker build from days gone by: 6'3" 255 pounds, I have no problem with a properly sized drop bar bicycle.
Our tandem is setup with flat bars for touring. We have gone as far as 75 miles in a day with it fully loaded. The main reason it has flat bars is that when I built it up, the available brakes suitable for two large people with a lot of gear were from the Mountain Bike downhill racing world. That and the fact that I can't seem to adjust to Shimano or SRAM drop bar controls. There is nothing wrong with either, I just don't like them and I find them difficult to use. So because of those factors, I went with flat bars.
But enough about me. How can you make this bike fit?!? Because the most important thing is that the bicycle fits you and your stoker. The first bit of news is that it may not be possible to make this tandem work for you. There are a lot of bicycle fit calculators on line. I have found the one on the Competitive Cyclist web site to be good.
https://www.competitivecyclist.com/S...waAojEEALw_wcB
If the size of the bike you have is way out of range, sell the bike and find one that is close enough to be workable for you. If someone gave me a 58 cm or smaller bike there is probably no way I could make it fit.
Now, how many miles do you plan on riding per day? The "comfort" seat will become a torture instrument after just a few miles. If you plan on doing ten mile trips on a bike path with a break in the middle, then do what ever you want. My wife / stoker thought she wanted a "comfort" seat, so I replaced the touring saddle with one. We made it about two miles before she wanted to turn back and put the touring saddle back on the bike. There are just so many things wrong with those tractor seats for a bike once the miles go up.
Looking at the bars, how wide are the current drop bars? If they are too narrow or too wide, the problem may not be that they are drop bars. They may just be the wrong size. Or the wrong shape for your body type. Fizik recommend bars and saddles based on your flexibility. They divide them into three groups: "snakes" are very flexible people, "chameleons" are people of average flexibility, and "bulls" are people who are less flexible.
This is not about fitness level. I have a brother who even when he was young and extremely fit couldn't come close to touching his toes. He is a "Bull", I can touch my wrists to my toes. I am a snake even if I look like a snake who just swallowed an elephant. I like Fizik's system because it is easy to determine which will work for you, but they are not the only brand that have saddles and bars that fit different body shapes.
And finally, switching to flat bars is possible, but it may not be cheap. You may want to find out how much it will cost to do the conversion to see if you would be better off selling this bike and buying a flat bar bike. Also remember that you will not just be switching from drop bars to flat bars. The change will almost certainly require a different stem length.
Likes For DangerousDanR:
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
There is just so much to unpack here it's hard to know where to begin.
For starters: The steering of a mountain bike is going to be different than a road bike. Road bikes tend to be steered with your hips & counter-steered with the bars. This works because they are designed for high speed sweeping smooth terrain with a moreorless different weight distribution than perhaps what you are used to.
Legacy mountain bikes started similar but the handlebars were on long stems so that steering was stabilized by a sweeping motion. We would probably call them "cross country" bikes now. Road-mountain bikes are called "gravel" bikes & fill the next increment in the road direction of the spectrum. But are essentially designed for the same spot on the continuum as bikes of yore.
Newer mountain bikes: The weight distribution is much more rearward biased & the head tube geometry is much more slack. This means that the bars must be much closer to the rider for reach & wider for leverage over the 'flop.' This it done to lighten the feel of the front end because at the comparatively much lower speeds counter-steering isn't so much a thing as is simply pointing the bike the direction you want it to go & leveraging the bike to the proper orientation to stay upright.
All this in broad strokes of course.
That being said: You shouldn't feel any pain or numbness. If so, something is wrong. Handling characteristics aside, either bike should be as comfortable as the other.
Likes For base2:
Quoted: 1591 Post(s)
Liked 1,020 Times
I can't ride more than 5 miles on a hybrid. Very uncomfortable for me. The upright position is harder on my back and my wrists don't like the bars. But I've ridden road bikes for 50 years so it's what I'm used to. The position of the rider is very different on different styles and the unfamiliar style can often feel just too odd. With a good fit, you could probably adapt to a new style over time. If you feel the need.
Likes For jon c.:
Quoted: 4420 Post(s)
Liked 4,873 Times
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,384 Times
...people modify tandem bikes according to personal preference all the time. Just swap out the stuff that bothers you, (but not your wife.)
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Stuart Black
Stuart Black
Likes For cyccommute:
