Roadies with platforms & toe clips: what shoes to you wear? (when not commuting)
High Plains Luddite
Road bike newbie here - just got an old steel-frame Allez and it has MKS Syvan Touring pedals and matching chrome toe clips and straps.
I commute on a MTB and wear whatever on it, but if I'm going to be out on the weekends riding the road bike, I'd rather not look like a fool.
I need to buy some padded cycling shorts and probably a jersey too, but I'm not ready to spend well over $100 for "clipless" pedals and matching shoes just yet.
Can I just wear regular running shoes and look respectable?
Thanks.
Thanks.
Bikes: Fiori Roma, Currently building a Bianchi, Trek 330, formerly Monshee Nomad, Favorit, Bianchi Sport SX, Frankenbike
If you are going to use the toe clips, you can use any shoe you like. A cycling shoe is very stiff, so you would be best off with something similar, but unless you are hauling up large hills or trying to fly fast, you don't need a cycling shoe if you wear the clips tight. I usually kept one foot looser so I could get out quickly if needed.
I wouldn't worry what you look like.
As for padded shorts, I buy liners with the padding so I can wear regular shorts and not chafe. These are typically cheaper than the shorts.
Quoted: 67 Post(s)
Liked 83 Times
If you are gonna go any real distance, the running shoes are gonna start to hurt a little, because the sole is not stiff. Despite previous advice to the contrary, this is probably gonna be worse if you really crank the straps down. That said, use what you got for now, spend the money when you have a better idea of what you want. Also, lycra shorts have advantages besides the chamois. Primarily, they don't flap in the wind and they don't get soaked with sweat.
Quoted: 52 Post(s)
I wore running shoes when I used toe clips. It was a perfect match.
I never cinched the strap all the way tight. I left the clips just loose enough to get my feet in and out with no problem but still tight enough to be effective.
They helped make my transition to "clipless" pedals and shoes seamless.
Pearl Izumi makes a nice padded liner you can use with regular or gym shorts. It's an easy way to slip in to rode cycling without taking a major thump to the wallet. On the other hand they also make some quality lycra shorts at a budget price.
Quoted: 27 Post(s)
I'd buy the cycling shorts first, then the pedals and shoes. Cyclig-specific jersey would be one of the last things I'd buy.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
You'll be ok with tennis shoes.
Cycling shoes will 2 things for you though: 1) as previously alluded, make your feet more comfortable by the stiff sole taking stress off your foot, and 2) allow you to be properly connected to the pedals.
The way those toe clips, and pedals are designed to be used it with cycling shoes, and a cleat that slots over the back of the pedal. It's an as efficient system of pedaling, but its not as convenient as clipless.
So one option if you want to go old school is buy just the shoes, bolt on the old style cleat, and keep your current pedals. Of course when you switch to clipless, you can still use the shoes.
You could get lost and die.
You could hit a tree and die.
Bikes: Novara Strada 5D (road/touring); Fuji Cross 3.0 (trail/cyclocross); SE Stout 29er (mountain, single speed)
Most of my biking is short touring routes on local and regional trails, so I wear running or hiking shoes for the frequent stops to take in nature and hidden spots. Works OK - you're not going to get top performance out of anything this way really, so go with what's comfy. One important thing that should be mentioned: running shoes may have long laces that can get caught in the gearing - very dangerous! Pay attention to this and tie them so they're safely far from the chain. Also, I agree with getting padded shorts first - that's the part you will definitely feel before anything else. And not in a pleasant way, if you don't have the right padding...
Administrator
Quoted: 11971 Post(s)
Liked 6,655 Times
I never tightened my straps at all when I lived and rode in a busy urban area (nyc). There's only so much hammering you can do on the city streets, and it's imperative to be able to get your favorite foot out quickly in that environment.
Now of course when I rode in more open areas I would tighten them a bit more, but still not bear trap tight.
But that's just me.
But that's just me.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
I generally like standard running shoes (not minimalist style ones) for clips-n-straps. Nice thick sole compresses a bit when strap cinched down so kinda helps lock you in without cutting off your circulation.
If you wanna try clipless it's likely cheaper than you imagine with SPDs.
Nice comfy, walkable shoes for $31.50
Diadora Globe MTB/Trekking Shoe at WesternBikeworks
Pedals and cleats for $34.19
Shimano PD-M520 SPD Pedals at WesternBikeworks
Bikes: everywhere
Liked 7,695 Times
The worst for me is Chuck Taylors with stock laces. I've long, skinny feet so those laces wind up being WAY too long. Gotta double knot and they still drag on the ground when walking.
Quoted: 52 Post(s)
Bikes: '09 Trek 2.1 * '75 Sekine * 2010 Raleigh Talus 8.0 * '90 Giant Mtb * Raleigh M20 * Fuji Nevada mtb
10 Wheels: I like the Velo Orange chrome Half Clips - those should be great on my MTB to get my foot positioned the same. Might have to put a counter weight / toe flipper on the back side of the pedal to help keep them horizontal 'cause of being off the pedal frequently on the trail or dirt road.
FB4K - Every October we wrench on donated bikes. Every December, a few thousand kids get bikes for Christmas. For many, it is their first bike, ever. Every bike, new and used, was donated, built, cleaned and repaired. Check us out on FaceBook: FB4K.
Disclaimer: 99% of what I know about cycling I learned on BF. That would make, ummm, 1% experience. And a lot of posts.
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
.... just got an old steel-frame Allez and it has MKS Syvan Touring pedals and matching chrome toe clips and straps. ...... I'm going to be out on the weekends riding the road bike, I'd rather not look like a fool.
I need to buy some padded cycling shorts and probably a jersey too, but ........ Can I just wear regular running shoes and look respectable?
I think... [maybe because I started with cages in the mid-60's]... I like cages more than the clip-in/clip-less pedals/shoes I normally use. But modern clip-less pedals offer a much better shoe choice/selection than the running or tennis shoes I use with cages.
So when I ride my "normal" road bike.... I use clip-less pedals and shoes.
Bikes: everywhere
Liked 7,695 Times
I used to have that happen all the time before I started religiously tucking them away, enough so that I could unwrap it by back pedaling, then just tuck them into my shoe without stopping the bike.
pan y agua
Liked 727 Times
I still have a set of shoes with cleats for the Super leggera pedals on my track bike.
Just ride.
Thanks.
Thanks.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Last year I actually got my left shoelace wrapped on the pedal spindle and it kept wrapping and tightening until I stopped.
Fred "The Real Fred"
Liked 12 Times
If you actually like toeclips and straps, you can use moder cycling shoes with these: Bicycle Shoe Cleats for Toeclip Pedals $29.95 at Yellow Jersey
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
When I rebuilt my olde 73 Holdsworth that was custom made for me when I was 16 a few year ago I put the olde superlegger pedals on and rode it a few times. It was awful because there is no float. I had no memory of anything but joy when I use to ride them so many years before.
The slots on the old metal cleats could be filed to provide some float, but the plastic ones look like it's not possible.
NOS T A J Anquetil Vintage Shoe Cleats Modele Cross | eBay
IMHO clipless pedals are easily the single best innovation in cycling since derailleurs were invented.
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times
My Lowa Renegade boots have a polyurethane midsole. I cut out a square of the rubber tread and installed some eggbeater cleats. They aren't as stiff as a cycling shoe when riding, but I'm not sprinting on the way to work. I put a 1/8" aluminum plate between the midsole and cleat for the pedal arms to interface.
Beats toe clips. Those things suck.
Bikes: Motobecane Road Giant Mtn
somewhat off topic but, a saddle is also a good investment. Find out how to measure your saddle to fit you here How to Measure Sit Bone Width For Bicycle Saddle Selection - YouTube
Chris
ride safe
Chris
ride safe
Newbie?
I've had the laces wrapping on my fixed-gear commuter... let's just say I learned a lesson that day.. I'm still thankful the laces broke before my leg...
