Spokes breaking on old Motobecane
Quoted: 92 Post(s)
Liked 20 Times
I had my old Motobecane that is vintage around 1975 serviced recently at the shop that trued a wheel. A spoke broke, it got serviced last week, I rode it a few miles and noticed another spoke broke. Are these hard to do myself? The shop may do me some type of favor or discount, but I don't want to spend another $47 or so.
Quoted: 3813 Post(s)
Liked 3,344 Times
most common spoke breakage location is the drive side pulling spokes of the rear wheel
in order to replace these it is necessary to remove the gear block
so one must be able to do that should it be the location of the broken spoke(s)
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
At this point, the rear wheel may best be sorted by replacing all of the spokes, assuming that the wheel components are good for your needs.
I've been through this with Nishiki, Centurion and other brands from that era, and there were wheels being sold to OEM's like Pro-Flex even in the 90's that still featured short-lived, brittle stainless spokes.
I also had a front wheel in use on my cyclocross bike for a dozen years that suddenly started breaking a front spoke at just about every race. Those were DT spokes that simply aged out from the fatigue of hard use on a 28-spoke front wheel.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
If it’s the latter it might be simpler to buy a replacement wheel. However if it a Maillard Helicomatic hub you will need a new freewheel too.
Sugar "Kane" Kowalczyk
Quoted: 656 Post(s)
Liked 469 Times
I had a similar problem with changing a single spoke and then having another break repeatedly. In my case, I re-tensioned all the spokes but was not sufficiently stress-relieving like I would normally do on a new build. Took the time to do that and seems to have fixed the issue.
The other thing I've come across is having multiple spokes chewed up from the chain going off the big cog and breaking one at a time.
Good luck!
Good luck!
Liked 1,296 Times
Good luck!
Good luck!
As for the chain damaging the spokes, it's one of the most easily-missed kinds of damage to one of a bike's most costly-to-repair parts, especially when shopping for used bikes.
I always check if the rear rim runs true, but sometimes miss the "chew" on the spokes.
Quoted: 92 Post(s)
Liked 20 Times
Do you have any pictures or more information for us? It would be helpful to know if this is a high end model with high quality hubs or a lower end model with inexpensive hubs.
Quoted: 92 Post(s)
Liked 20 Times
Broken spoke is at apex of wheel.
I stopped at a flea market today thinking of getting a 27 inch wheel and someone had a Raleigh 10 speed not in bad shape for $10 but it would probably complicate things.
Bianchi Goddess
Liked 2,926 Times
TLit I seriously consider a replacement alloy wheel. The shop can swap your current freewheel over and adjust your derailleur.
Those old galvanized spokes will keep breaking and I’d never recommend to anyone simply rebuilding a steel rim wheel.
Quoted: 1951 Post(s)
Liked 2,012 Times
Go get the Raleigh. 10 bucks is not complicated.
Bianchi Goddess
Liked 2,926 Times
I believe the OP was thinking about the Raleigh wheel for the Moto, but yeah if the Raleigh fits and is a better quality bike that’s $10 we’ll spent.
Quoted: 92 Post(s)
Liked 20 Times
Actually the bike said Carlton with some Raleigh parts on the bike; It was a little small for me though t had a 27 inch 10 speed style.
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 679 Times
Carlton? Maybe you are pulling our legs, but an old Carlton is a potentially collectible bike. Grab it quick if you can.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,488 Times
No. But you have to have a little time, patience and be able to follow simple instruction:
https://www.sheldonbrown.com/wheelbuild.html
Oh, and you'll need a spoke wrench.
Likes For SurferRosa:
Quoted: 18378 Post(s)
Liked 4,512 Times
That isn't a super valuable model of Motobecane, so I can imagine reluctance to keep dumping money in. But, on the other hand, if it works, that may be good for your needs.
If the hub is good, I'd probably go ahead and replace all the spokes.
A full set of straight gauge stainless steel 2mm spokes, plus nipples aren't that expensive.
Building a wheel is rather tedious, and takes some work to get the wheel true and properly dished (centered). For the rear, the right and left spokes are usually a couple mm different in length.
But, it is also a good skill to know. A truing stand is nice, but it can be done on the bike.
Likes For CliffordK:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Or find a co-op. I routinely donate wheels to our local co-op, I've probably donated 200 over the years. You will continue to break spokes, and on a 45 year old wheel, its time to replace. Get something with an alloy rim and stainless spokes. That $10 Carlton should be long, long, long gone.
Likes For wrk101:
Quoted: 92 Post(s)
Liked 20 Times
https://www.amazon.com/Wheel-Rear-1-...a-568999014205
Would this one be compatible? I went back to the bike shop and they said it would be another $50 or so for them to fix the weel and something about twice is a coincidence but still they advised against it.
Quoted: 92 Post(s)
Liked 20 Times
Also I'm thinking that in truing the wheel the bike shop got it "right" technically but the other spokes couldn't stretch so when I rode it so one had to give.
On the Carlton, if the guy shows up it will probably be there again. Are these that rare and desirable? I'm not looking to collect, just ride.
señor miembro
Liked 6,488 Times
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
Liked 4,512 Times
https://www.amazon.com/Wheel-Rear-1-.../dp/B000AO3GK2
The one specification that I don't see is the Over Locknut Dimension (OLD).
On your bicycle, remove the rear wheel, and measure the distance between the dropouts, inside to inside.
You should get one of the following distances: 120mm, 126mm, 130mm, or 135mm.
Your new wheel should be purchased to easily fit in. Slip in with maybe ½mm to 1mm to spare.
Depending on how the axle is assembled, it can be adjusted, but then you may need to adjust the bearings, and adjust the wheel dishing.
A bike co-op can help with finding either used wheels, or perhaps new wheels. Also they should be able to help with fitting the wheel to the bike. Any adjustments necessary.
And hopefully can give some instruction.
Or, if one is ambitious, get a pile of spokes, and some help to rebuild the wheel.
Or, of course, just sell one a couple of spare spokes, and give instruction on how to replace the spokes should they break. It is a bit of a pain of spokes break on the freewheel side because the freewheel has to come off to fix them, but not the end of the world either.
Quoted: 966 Post(s)
Liked 1,629 Times
First of all having a back up wheel set is a real gem. A good steel wheel set may not cost allot and should be easy to find.
Truing a wheel is not a hard task to learn and after you get proficient in truing your wheels replacing a spoke is not a hard task at all. After all once you have your backup wheel set installed you can take your time, peruse the many Youtubes and go for it...
For less than 47.00 USD you can get:
It very well could be your spoke failures are simple normal wear and tear. I did have a machine built wheel set that had poor quality spokes and after popping many of them just replace all the spokes. Note my personal favorite supplier of spokes is: https://www.bikehubstore.com
By the way a Vintage 75 Motobecane... That's a nice ride...
- Spoke Wrench - 7.00 UDA
- Zip Ties - 3.00 USD
- Freewheel Removal Socket - 5.00 USD
- Spoke Tension Meter - 19.00 USD
- Spoke Nipple Tool - 5.00 USD
- Dishing Tool (Card Board) - https://www.roadbikereview.com/attac...t1-jpg.314783/
Likes For zandoval:
Liked 1,296 Times
That Amazon/Wheelmaster wheel is spec'd at 130mm for up to a 7s freewheel.
It would be a good bit of work to narrow it to 120mm, if the original freewheel was 5-speed.
Likes For dddd:
Quoted: 92 Post(s)
Liked 20 Times
I found a larger 68cm bike on CL, a Le Mans from the 80s, and the seller, Zach from NJ was able to replace the problem wheel with a good one, though it is 10 speed. https://cnj.craigslist.org/bik/d/new...541909563.html
Likes For TLit:
