Pedalling weirdness
Pedalling weirdness
I just took my new bike for a test drive. It's been decades since I've ridden a bike...and the first time I've been on one that required shifting, so I'm wondering if what I'm feeling is normal: I'll be feeling resistance in the pedals, but then for a second I'll lose the feeling of resistance and the pedals feel like they're turning freely for a few degrees - as if they're not connected to anything...then all is back to normal. It's not something that happens during shifting, it's while I'm in gear. I bought the bike at Dick's, and I was totally sure they mis-adjusted something, but I took it back in and they checked it out and said everything's fine. Is this the way a normal functioning bike should feel? It seems like it would get annoying pretty fast.
Quoted: 4227 Post(s)
Liked 2,488 Times
That almost sounds like pawls in the freehub or a freewheel are sticking and not engaging...If that happens the freehub or the freewheel needs to be cleaned up and lubed.
Likes For wolfchild:
Quoted: 6969 Post(s)
Liked 10,966 Times
Did the tech person at Dick's take it for a test ride in order to experience this phenomenon?
Quoted: 822 Post(s)
Liked 1,961 Times
If there are wide gaps in the cogs' teeth count you may feel while pedaling a momentary gap where it will take a full crank turn or more to get the chain engaged in the next cog.
Le Crocodile
Quoted: 370 Post(s)
Liked 787 Times
Quick "fix" is to get some light oil in there to dilute things a tad and get the pawls to stay engaged. You can do that without taking it apart. Not 100% the correct fix, but to get underway until the real fix gets implemented.
More than likely this is your issue, but it could be a defective component too.
ETA- Can be from wear, too heavy/excess lubricant, too little or no lubricant, or simply not manufactured/assembled properly.
And NO. Not normal at all!
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Likes For cxwrench:
Quoted: 1069 Post(s)
Liked 787 Times
Might not be keeping up with the pressure required for power. Apply hand brakes lightly and pedal like when it happens for a quick check.
Liked 10,966 Times
Are you "slacking off" a bit in your pedaling (like a mini-coast) just before you notice this?
Liked 10,966 Times
Your rear hub has only so many pawls…it is normal that there is a bit of slack when you start pedaling after having coasted.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2584 Post(s)
Liked 5,642 Times
Are your chain rings (the ones in the front) perfectly round or are they slightly ovalled (elliptical)? If they latter, you will want the round ones.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Quoted: 6195 Post(s)
Liked 4,810 Times
Sounds like the DR's aren't adjusted correctly and it's trying to shift gears even when you aren't.
I've had that happen to me before. More likely I'd think than a slipping free hub which I've never had happen. Though I have had some very rusted up freewheels do that, but the bikes had more issues than just that.
Quoted: 1819 Post(s)
Liked 1,695 Times
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
I've ridden several elliptical. Old Biopace and even messed around with new absolute black. I don't care for them and have switched to round, but oval rings absolutely do not cause the issues he's having. At all, ever.
Likes For rosefarts:
Frame: All new 6061-T6 Aluminum Triple Triangle Frame, w/ Replaceable Derailleur Hanger, and 1 1/8 Head Tub
Fork: MTB suspension fork, 80mm travel
Crankset: Forged Alloy 42/34/24T
Bottom Bracket: Cartridge Sealed
Pedals: GT Slim Line Flat Pedal
Front Derailleur: MTB Type
Rear Derailleur: MTB Type for 21spd gearing
Shifters: MTB Trigger type, 8spd right/3spd left
Cog Set: 11-34T, 8-Speed Cassette UPC
Chain: 8spd type
Rims: Alloy Double Wall, 32H 27.5, disc specific
Liked 1,695 Times
Ah...my bad. It's a GT Aggressor Pro. The forum won't let me link to a page with specs, but here's some info:
Chain: 8spd type
Chain: 8spd type
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
I've had this sensation when the cassette lockring was not tightened properly. Check that.
Likes For redcon1:
I just took it in to a (hopefully!) reputable shop so they can give it the once-over and look into this issue, as well as check for anything else that may not have been set up correctly (the face he made when I told him Dick's did the setup told me he wasn't too sold on their reputation!). He agreed with those on this thread who say the problem can't be diagnosed on a workstand...he said they test ride all bikes they service. They're backed up, so I won't have it back til probably early next week...I'll keep you posted.
Did not he mention the "tech at Dick's"? We might assume it is a Dick bike!
Liked 10,966 Times
Quoted: 2236 Post(s)
Liked 1,314 Times
Sometimes if a chain link or two sticks, from rust or reinserting a pin after using a chain breaker, that sort of thing can happen. If you get it back from the shop with no answer, try running the chain through your fingers to see if the links flex smoothly.
It's a brand new bike though...it's only logged about twenty minutes of me cruising around a deserted parking lot to try it out...
Quoted: 539 Post(s)
Liked 44 Times
Chain: 8spd type
Chain: 8spd type
https://www.dickssportinggoods.com/p...ggrssrprxxxprf
