Does a product like this exist?
Old 04-24-22, 11:06 PM
qwaalodge
Quoted: 211 Post(s)
Liked 79 Times in 61 Posts
I want something to rest the elbows when hunched low in TT posture and be able to easily swivel the elbow pads out of the way when not using it. Something really simple and cheap.
Please don't recommend me aero bar because it's not a good option for me. I need access to the brakes all the time, something you can easily swivel out of way (even while riding), and I want the simplest and cheapest option possible. An aerobar with brake levers is just too complicated, cumbersome, and if you don't need it, the only way to take it out of the way is to remove it which can be inconvenient and not always possible.
Something like this:
qwaalodge is offline
Likes For qwaalodge:
Old 04-25-22, 09:03 AM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
Yes it exists; no it does not exist in the 'simple and not expensive' category. Aero bars and 'interrupter' brake levers are the only thing I can think of.
ClydeClydeson is offline
Old 04-25-22, 09:31 AM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
Cobble something together out of PVC pipe, inner tubes, and hose clamps. Post pics.
Rolla is offline
Likes For Rolla:
Old 04-25-22, 10:01 AM
qwaalodge
Quoted: 211 Post(s)
Could be done but making it swivel, the swiveling mechanism may require machined / moulded parts.
Old 04-25-22, 10:17 AM
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Core strength - very simple and inexpensive.
WhyFi is offline
Likes For WhyFi:
Old 04-25-22, 10:30 AM
njkayaker
Quoted: 4260 Post(s)
Liked 1,364 Times in 945 Posts
Why? Use the drop you already have.
Nothing like what you want exists. Certainly, nothing that is "really simple and cheap".
The thing the TT position gives you over existing alternatives is being narrow (having your arms in front of your torso.
njkayaker is online now
Old 04-25-22, 10:31 AM
njkayaker
Copper tubing or GTFO.
Likes For njkayaker:
Old 04-25-22, 10:44 AM
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
Not cheap.
https://www.baryak.com/new-products/flip-flop-arm-rest
seypat is offline
Likes For seypat:
Old 04-25-22, 10:55 AM
base2
I am potato.
base2's Avatar
Quoted: 1790 Post(s)
Liked 1,631 Times in 934 Posts
Profile Design has (or had) aero bars with spring loaded elbow pads that would flip up. I'm not going to research a link for you.
Use the pad rest, fail to install the bar. Simple.
Car dependency is a tax.
base2 is offline
Old 04-25-22, 10:56 AM
qwaalodge
Quoted: 211 Post(s)
Technically, that's still an aerobar, albeit, one that folds partially.
Old 04-25-22, 11:01 AM
qwaalodge
Quoted: 211 Post(s)
Never had good experience with springs I prefer using some sort of resistance with stoppers and just moving the pads manually by hand to stow them away when not needed. Springs might throw you off the bike if you hit big bumps.
Old 04-25-22, 11:08 AM
seypat
There's also these things. I don't know if the pads move or not, though. I'll leave the jokes for others to come up with.
https://www.triathlete.com/gear/bike...rfin-aerobars/
seypat is offline
Likes For seypat:
Old 04-25-22, 11:16 AM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
You could potentially use an old stingray stick shift and mount them to the bars and put pads on them. That would give you the ability to rotate them.
I’m guessing they would be strong enough as many a boy lost his manhood on one.
John
70sSanO is offline
Likes For 70sSanO:
Old 04-25-22, 01:10 PM
spelger
spelger's Avatar
Bikes: yes, i have one
Quoted: 1139 Post(s)
Liked 1,182 Times in 687 Posts
i have this and you are wrong about them. they work fine. but they fail your two requirements, cheap and break access.
spelger is online now
Old 04-25-22, 01:13 PM
spelger
spelger's Avatar
one hinge seems bad, but two? seems two nice weak spots in this design.
Old 04-25-22, 01:43 PM
njkayaker
It doesn't seem like they'd work in the way the OP wants. And, at $155, they aren't cheap.
https://images.squarespace-cdn.com/c...pg?format=750w
https://www.morf-tech.com/
$1000 (not cheap) and being aerobars means they don't really match what the OP is asking for.
Old 04-25-22, 01:50 PM
tomato coupe
Quoted: 3957 Post(s)
Liked 7,310 Times in 2,950 Posts
Yeah, I've got a set of those - they would be a simple solution to the problem.
tomato coupe is offline
Old 04-25-22, 02:59 PM
spelger
spelger's Avatar
do you find that they make noise when riding on rough surface when you are not on the arm rests? mine do. really quite annoying. looking for a proper solution to that, right now i have a rubber band that holds the rests tighter than the springs can on their own. works but a bit ugly.
Old 04-25-22, 07:39 PM
qwaalodge
Quoted: 211 Post(s)
I could probably improvise using cheap flat bar extensions with padded rest epoxy glued to the bar extension if I get some free time. The swiveling part would be the biggest challenge to figure out without relying on custom machined parts.
Old 04-25-22, 09:52 PM
tomato coupe
I've never noticed it.
Old 04-26-22, 03:43 AM
sean.hwy
sean.hwy's Avatar
Quoted: 426 Post(s)
Liked 274 Times in 201 Posts
that's pretty cool. I want to get that for my mountain bike :-)
sean.hwy is offline
Old 04-26-22, 11:30 AM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
https://www.speeco.tech/abb-aero-break-away-handlebars/
Elvo is offline
Likes For Elvo:
Old 04-26-22, 12:13 PM
qwaalodge
Quoted: 211 Post(s)
That may be multiple times more expensive than my bike.
Old 04-26-22, 12:29 PM
GhostRider62
Quoted: 2333 Post(s)
Liked 2,097 Times in 1,314 Posts
Haero H380 has the pad built into the top of the standard drop bar with two different attachments that can be easily removed to run the bar standard drop.
Go0gle it.
GhostRider62 is offline
Old 04-26-22, 12:33 PM
Reynolds
Passista
Reynolds's Avatar
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 868 Post(s)
Liked 721 Times in 396 Posts
Who designed that, H. R. Giger?
Reynolds is offline
