Expensive Components with Rust-Prone Bolts
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Expensive Component:
Steel mounting bolt after a few years, rusted:
Single bolt replacement cost (boltdepot.com):
Same issue with Ritchey stem mounting bolts. They become rusty after 1 or 2 seasons.
Why, Ritchey? Why?
WCS CARBON 1-BOLT ZERO OFFSET SEATPOST - $259.95
- zinc-plated steel: $0.42
- stainless steel: $0.62
Why, Ritchey? Why?
Likes For terrymorse:
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Do the zinc and/or stainless replacement bolts last longer?
Quoted: 4227 Post(s)
Liked 2,488 Times
My Thompson seat post and stem are 15 years old and still don't have any rust on the bolts despite being used during winter time and wet conditions. All the other bolts on all my other bikes and components have some rust on them. The disc brake adapter and caliper bolts have most rust on them even after after I've been greasing them during winter riding season. Axle nuts have no rust because they are zinc plated and i grease them regularly...It's just cosmetic rust and doesn't bother me.
climber has-been
Liked 3,567 Times
The zinc-plated bits rust rather quickly. The stainless ones don’t rust, unless they are in a very corrosive environment (like salt water spray) for a long time.
That Ritchey bolt was probably zinc-plated.
Quoted: 9653 Post(s)
Liked 6,365 Times
Likes For Mojo31:
Quoted: 506 Post(s)
Liked 639 Times
Quoted: 824 Post(s)
Liked 1,659 Times
If you're using a carbon seatpost to save some weight, why not go with titanium bolts? No rust, and lighter than stainless steel. Yes, they cost more, but if you're going with a $260 seatpost, well.....
Titanium Fasteners - Firmakes Titanium
I don't think any of my seat post bolts have ever rusted... but even if they did, I probably wouldn't swap to stanless or titanium. A seatpost bolt has to hold a lot of weight so that's one place I'd prefer 10.9 or higher grade steel.
Quoted: 3352 Post(s)
Liked 1,056 Times
It would seem to me that the really expensive components would have stainless steel bolts in the first place.
Likes For rydabent:
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
The problem is that titanium, or even stainless steel bolts, of the same size, are weaker.
The carbon/steel interface allows for an oxidation-reduction reaction to take place, due to their electrochemical potential difference.
Likes For Polaris OBark:
That's a zinc-plated bolt. Is it adjacent or contacting the carbon? Or does it bolt to an aluminum casting? With the presence of an electrolyte, a carbon/zinc assembly will produce an electrochemical reaction resulting in the erosion of the zinc anode (the bolt).
I would look for a Titanium bolt for this application. Titanium bolts are not weak, but they have two problems: galling, and flex. The lack of lateral stiffness isn't an issue in this application. To address galling, be generous with anti-seize when installing it.
Another good one is aluminum alloys with scandium. I've used a lot of aluminum bolts for less critical applicaitons like bolting side covers on engines. The quality of the aluminum bolts was abysmal, but it didn't have to be. There are some great aluminum alloys and while they aren't direct replacements for steel where the tensile strength is critical, they are strong and light. Specifying a larger aluminum bolt can be an effective substitute for steel but has design/build implications. Another trick I've seen are hollow steel bolts. Those have incredible strength/weight ratios, but they still require a compatible finish process.
I don't know where a person can get a small quantity of high-quality bolts and fasteners nowadays. Back in the day, I ordered from Aircraft Spruce. They're still around. The Titanium bolt makers I used 25 years ago are all gone, but no doubt there are others now.
Quoted: 2700 Post(s)
Liked 486 Times
From looking at their website I think it’s a stainless m5 bolt, can’t find the length called out anywhere https://ritcheylogic.com/bike/seatpo...plete-clampset
https://www.mcmaster.com/product/91292A194 something like this of the correct length and “collar” (the distance between the bottom of the head and the start of the threads.) is what’s on there now, it’s almost certainly standard 304 series.
if you want more corrosion resistance with 316 McMaster offers that too https://www.mcmaster.com/product/92290A258
i naively think that is sensible.. replacing with titanium or aluminum alloy sounds really weird, don’t try to reinvent the wheel.
Liked 486 Times
https://www.mcmaster.com/product/91292A194 something like this of the correct length and “collar” (the distance between the bottom of the head and the start of the threads.) is what’s on there now, it’s almost certainly standard 304 series. That’s assuming it’s actually ss.
climber has-been
Liked 3,567 Times
I replaced it with this stainless bolt.
Quoted: 967 Post(s)
Liked 1,631 Times
What a sham. Components on a $259.95 Seat Post should not rust!
Just another example of not getting what you paid for... Come On Ritchey. It's little things like this that make me sober when pointing out defects in in some cheap ChiCom knockoff that doesn't rust...
Yep... This post deserves a Titanium bolt.
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,871 Times
Why, Ritchey? Why?
Why, Ritchey? Why?
Likes For MoAlpha:
The unthreaded portion of an M6 bolt has a cross-sectional area of about .044 square inches. High-strength 316 stainless hardware is usually rated for a minimum ultimate strength of around 110,000PSI, which over .044in^2 gives about 4,800 pounds.
But the threading also eats up a ton of the effective diameter. Realistically I'm not sure anyone should be counting on a coarse-thread M6 bolt to have an effective loaded cross-sectional area of much over .03 square inches, which gives 3,300 pounds.
Furthermore, stainless hardware often yields at far below its ultimate strength, so even "3300 pounds" is probably an optimistic perspective for most applications.
Liked 3,443 Times
Liked 3,443 Times
I just noticed the bolts in my carbon stem aren't looking too hot.
Likes For Pratt:
climber has-been
Liked 3,567 Times
I'm skeptical of your math.
(I misread the table)
Still, pretty beefy.
Liked 2,488 Times
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 212 Post(s)
Liked 356 Times
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
