water weight and the scale
I guess I always knew water weight is a significant part of body weight but had never really quantified it, just had a rough idea could account for up to 5 lbs after a hard workout . . . so the other day, after a hard 20 min workout on the bike trainer, went to weigh myself and, sure enough, my body weight was 4-5 lbs lighter than usual, which I like to see, but then was very thirsty so filled up my water bottle and before drinking, thought, "I wonder how much weight I will gain back if I drink this water" so took it to the scale, hopped on the scale and sure enough the scale read x+1.5 lbs where x was the body weight without the full bottle. then just to confirm, I got off the scale, drank the entire bottle, hopped back on, and it read x+1.5. yay, water in the bottle was now water in my body, and the scale read the same. Then I hopped off, set the empty bottle down, hopped back on the scale, and it read x+1.5 still . . . so evidently, the bottle itself did not weight enough to tick it up to x+1.6 lbs. anyway, maybe all this is obvious, but it's nice to know how water replenishment relates to body weight. and that my scale records the water weight accurately.
as an aside, I read somewhere that you should weigh yourself before strenuous exercise, then afterwards, drink fluid to bring your weight back to pre-workout levels. then you know you have replenished fluids. but I've lost as much as 5 lbs in a long bike ride, so that would be about 3 liters of water (4.5 lbs by the above measurement), which is a lot to drink.
Drinking enough water to bring your weight back up is "kind of" true. If you drink too much at once you will urinate out some of it as the body can't process it the way you want all at once. How long you should drink it over isn't something I know but I do basically put it back in over time.
Also if you drink enough DURING your exercise then that's the magic spot.
SuperGimp
You've got your weights wrong too - a liter of water is 1,000 grams = 1kg = 2.2 lb.
I don't know what you're calling a long bike ride but I routinely drink 24 oz of water an hour when riding, and if it's hot enough, I'll drink as much as 48 oz of water an hour.
Texas Tornado
Bikes: '14 Specialized Roubaix SL 4 Full Ultegra 6800
Water weight is something best not overanalyzed. Your weight is gonna fluctuate from day to day depending on sodium intake and other things. I can weight myself daily and not get discouraged by the fluctuations; other people lose motivation when they don't see losses EVERY day. Most people will tell you to just weight in once a week because you'll generally lose a good amount in that time and not become discouraged by the water weight fluctuations.
Long story short, just relax, eat well, bike plenty and it will come off.
Bikes: 2010 Felt DA, 2012/6 Felt F5, 2015 Felt AR FRD
Quoted: 27 Post(s)
If you like that, weigh yourself right before bed, and first thing in the morning. Goblins steal the weight at night!
Commuter & cyclotourist
Bikes: Boulder All Road, Surly Long Haul Trucker, Bike Friday New World Tourist, Breezer Uptown 8, Bike Friday Express Tikit, Trek MultiTrack 730 (Problem? No, I don't have a problem)
better yet . . . weigh myself . . . in the morning . . . after the hard workout . . . for the lowest possible number on the scale. it motivates me, what can I say.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
When will people catch on that weight in and of itself is pretty meaningless. Body composition is a far better indicator of fitness than the number on the scale.
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
I've found my weight drops as much as 5# on a long ride, and that's even with drinking a bottle an hour. I don't consciously try to 'drink it back' after the ride, but I drink water pretty freely over the next 8 hours.
I didn't see the OP say it was a liter, just a bottle. And the water in a 24 oz bottle weight 24 oz - 1.5 lb.
Liked 11,914 Times
Most of us aren't set up to measure specific gravity at home. I, for example, don't have a 300# hanging scale and a swimming pool.
Quoted: 143 Post(s)
Liked 23 Times
The good news is you don't need one. Honestly, you don't need to pinpoint the exact bodyfat percentage or exact lean mass, what you need to be able to do is a reasonable estimate and, more importantly, be able to determine if you are trending in the right direction. A good full length mirror and a simple tailor's tape measure will get you in the ball park. Properly used calipers or even bioimpedance scales will also provide useful information if you don't obsess about fractions of percentages.
Thanks to people relying on simple weight measurements and the horribly inaccurate BMI, we are seeing an epidemic of "skinny-fat" people, aka people whose body weight falls within the BMI's healthy range for their height but who still have above average bodyfat percentages due to low lean mass numbers. Losing "weight" is not always a good thing. Losing excess fat is. That's why many strength athletes and bodybuilders may have a BMI above 30 (obese according to the BMI scale) but bodyfat percentages under 12 (a very healthy and fit number). Six feet tall, 200 pounds and 30% bodyfat is far different from six feet tall, 200 pounds and 12% bodyfat. Weight only has meaning when put in context by reasonable estimates of body composition.
Bikes: 2012 Cinelli Xperience
SuperGimp
I did my first metric century last weekend (been on the bike for about a month) after a 10+ year lay off. The ride had 4500 feet of climbing and temperatures started in the mid-70s and ending in the 100s with the heat index. Long story short, my scale was 9 pounds lighter when I got home. Over the next two days (rehydrating, eating, resting) I regained 7 of those lost pounds.
Needless to say if I had to repeat that ride on a regular basis, losing weight isn't worth it.
Joking aside, I've found that calorie counting and balanced meals has been FARmore effective at healthy weight loss than big effort days on the bike. But that's me.
SuperGimp
You probably don't have a full body Dexa Scanner either
Your example of body fat measurement might actually combat some of the fat-skinny I hear from time to time (I'm just big boned, I'm built like a line backer, I'm 5'10" but any lighter than 250 and people tell me I look skeletal, that sort of thing)
This is a cycling forum, weight is half the equation as far as going up the hill faster. Sure the 200 # bodybuilder might be "healthy" but he isn't going to be a good cyclist.
Liked 11,914 Times
First, weight, because in order to reach a healthier composition, I have a LOT of fat to lose, and I don't want to be 240lbs of muscle mass!
Second, the fit of my clothes. I no longer can wear my 38" waist pants without a belt, nor do I have to stre-etch them out to convince myself I don't need the next size up.
Third, my performance on the road. Each week, the same degree of suffering allows me to go farther. Hills get easier, even spinning on the flats is easier.
But yeah, if it were JUST weight dropping off, one could end up being one of those people who still are out of shape, but not fat. OTOH, if it were JUST performance, I could be a still-fat but more fit guy.
Liked 11,914 Times
Quoted: 143 Post(s)
Liked 23 Times
I seriously doubt we've got any skinny fat people posting in this board. For a person (I'll use me as an example) who KNOWS he's fat, weight is a perfectly good tool to use to monitor progress towards skinny, if that ever happens. My body composition is not changing dramatically from year to year but the fat content may.
GeneJockey said
"Second, the fit of my clothes. I no longer can wear my 38" waist pants without a belt, nor do I have to stre-etch them out to convince myself I don't need the next size up.
Third, my performance on the road. Each week, the same degree of suffering allows me to go farther. Hills get easier, even spinning on the flats is easier."
which is an indirect measurement of body composition indicating that he is losing fat while maintaining or possibly even gaining muscle. He mentions that he doesn't want to be 240# of muscle mass. That's not what I'm promoting at all. What I am saying is that you don't want to be sacrificing muscle, connective tissue, bone or even normal hydration levels for the sake of decreasing the numbers on a scale. What you want to do is get rid of excess fat, not weight at all costs, so you need to consider more than just what the scale says.
I myself am still a good 30-40# of excess fat over my ideal (way down from where I started). One of the big changes I made when I actually started making real progress was to quit worrying about the scale and starting to focus on how I looked (from a fitness, not narcissistic standpoint), how my clothes fit, how I felt, and how I performed. There have been several points in the journey where I could see, feel and measure improvements even when the scale denied any progress.
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 913 Times
is beer weight classified the same as water weight?
Rule #10 // It never gets easier, you just go faster.
Liked 11,914 Times
HA! I no longer consider beer to be the perfect recovery beverage. Too tempting! Nor are donuts the perfect carbo-loading food!
