1x9 freewheel suggestions
Loving my new bike, hate the cassette . 45-11 is just too wide for my type of riding. Basically flat country roads with some gravel. I’m thinking more of a 40-15 but what are you guys running and how do you like the setup?
Semper fi
Semper fi
Quoted: 101 Post(s)
Liked 41 Times
I think you’ll have trouble finding a 15-40 9s cassette. It’s possible that you could buy two 9s cassettes and mix/match the cogs to get the gears you want, but this might require a bit of digging to find two cassettes that (1) have individual, loose cogs, not one or more “clusters” that are permanently attached and (2) have the right combination of cogs to get the gears you want. I have done this with 8s when I build an 11-18 cassette for my trainer…pretty sure I found literally the only two Sunrace cassettes that would make it work…but it did!
Downside (which I’m about to run into now) is that each time you replace a cassette you are now buying two cassettes. What size chainring(s) and what crankset are you running? If you can downsize the chainrings, you might be able to get a similar range out of a more common 11-32 or 12-36 9s cassette. If you have a double or triple, you might not even need to do that if you are willing to spend more time in the next smaller ring.
Quoted: 101 Post(s)
Liked 41 Times
I know it’s a highly individual thing, but since you asked about what gearing we are running: On my main bike I have a 50/34 double paired with an 11-36 cassette (11s). I could actually be fine with wider spacing…so much so that If I had to buy a new crankset today, I’d probably opt for 1x and an 11-42 or 11-46 cassette.
42t chainring
Semper fi
Semper fi
Quoted: 576 Post(s)
Liked 1,002 Times
Quoted: 101 Post(s)
Liked 41 Times
42x15-40 covers a very similar range to 34x11-32 or 11-34…not identical, but in the same ballpark. Both 11-32 & 11-34 cassettes are fairly common. Depending on the bolt pattern on your 1x crank (and frame clearances) there is a chance you can find a 34t ring that will fit.
Quoted: 1461 Post(s)
Liked 1,485 Times
I run a 42T or 40T with an 11-32 for "basically flat country roads with some gravel". I have 1x11, but the same principal would apply to 9 speed. I have no idea what kind of cassette sizes you can get for 9 speeds these days, so that is probably your limiting factor.
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
I'm kinda confused on the issue.
A 42t ring with 11-45 cassette is what you currently have and you want to move to a 15-40 cassette?
If that's correct, you are looking to reduce both the low and high gearing. So you don't use the first few small cogs or the last couple large cogs?
If that's correct, then wheelsmcgee ha a solid suggestion- get a smaller ring and smaller overall cassette range.
compare gear inch options on a website and go from there.
Liked 1,485 Times
A narrower range cassette solves this problem. Given that the OP is riding in the middle of their current cassette with a 42T chainring, I'm not sure what problem a smaller chainring solves. If the OP is really on flat roads only, a 42x32 is likely more than enough for any minimal climbs they encounter. A smaller chainring would just move everything down to the smaller cogs and limit top-end. For flat road riding, I'd rather have extra gears on the high-speed end vs low speed.
My biggest complaint is the big jumps in gears. I’m mainly on the 22t and one shift up or down is not a very smooth transition.
Semper fi
Semper fi
Not lost wanderer.
Quoted: 886 Post(s)
Liked 995 Times
Shimano's 12-36 is one of the best for minimal gaps. I run mine with a 45t for 1x9 or 48x45 for a great half step.
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x11,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 264 Post(s)
Liked 240 Times
I run my 1x9 with sora groupset. My set is particular as its 11-34x45 but of 20” wheel so on 700, it is equivalent to 11-34x32T which is plenty enough with the child carrier
but, when comparing the gearing with 45T it s the same as my gravel 11x1 10-42x38T minus the hardest and easiest gears (if i put a 43 or 44, i loose the 2 hardest gears) so as I dont use them much is not an issue.
either way, you may want to create a XL sheet with gearing comparisons to see how usual 11x1 are then look at what 9sp cassettes is available to you and derailleur and set the chainring accordingly.
i personally prefer loosing 2 hard gears rather than having big gaps between gears.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Good point. A smaller chain ring will bring you into the smaller cogs on the cassette, and that should give you smaller gear jumps. After you do that, you can get a tighter spaced cassette if you don't need the low gears.
Bicycle Gear Calculator
