Back pain on longer rides.
First off, by "longer rides" I'm saying 20+ miles. I don't ride centuries, or even halfs. A really long ride for me is pretty much anything greater than 30 miles.
I did a 27 mile ride today and about the time I got around 18-20 miles in my back was absolutely screaming. It's all lower back pain and I've noticed that this pain limits my rides far more than energy or endurance. Any pointers as to what I can do to relieve this pain?
For the record, I'm 52, 5'4" and ride either a 49 or 50cm bike.
Quick pic of my basic bike fit.
Quoted: 986 Post(s)
Liked 1,652 Times
Jen - Nice set up. I also suffer with back pain from injuries. I was able to resolve back pain from ridding by raising my Bars 3cm and lowering my seat about 2cm. Now that is after several years of making very slight adjustments. Do not do it all at once. Every few years I have had to adjust them just a little. Bit I am not getting old... Ha
You may need to go to another Stem...
climber has-been
Quoted: 3500 Post(s)
Liked 3,642 Times
Did you happen to do the whole ride on the saddle? That can tire out your back muscles, especially on uphill sections.
If you get out of the saddle every few minutes, that will rest the muscles in your lower back.
It also helps to click up a gear or two when you pedal out of the saddle.
Quoted: 528 Post(s)
Liked 230 Times
I used to get back pains say on a two hour ride on the flat, during the second hour I would feel it. The stronger I got the less that became, but it essentially went away with a fit and a new saddle. Now I just get sore when I do a lot of climbing, pain only when I climb and do too much so that I am tired and the body just cramps up. So I would assume that something about your fit/saddle is not 100% so that it puts your back muscles to more work than they should.
This is likely the problem. I had the same lower back pain when I used to have the same back posture as you did and the problem went away with training in improved back posture. I did not have to do any core strength exercises. Just reducing the reach and getting into the right back posture fixed the problem. Basically, you need to rotate your lower back in a more upright posture and in consistently convex curve. Such back posture reduces the workload on your core muscles which eliminates pain and potential injury. Reducing reach is the key.
To get the same back posture as the pro rider in the picture, you'll have to reduce your reach. First by trying to move the aerobar closer. If you can't adjust the aerobar closer, then get a shorter stem. Try to switch to 20 to 30 mm shorter stem. You don't have to get that close knee to elbow position as the pro in the picture. It seems you have relatively longer torso so you don't have to get that close but you do need to reduce reach based on your back posture.
You'll feel cramped at first but do try to get used to it and consciously make an effort to try to assume a back posture as the pro rider. Check your posture beside a big mirror so you can see your back. Even better if you can do indoor training beside a big mirror to train yourself in the new posture. That's what I did.
I used to suffer from lower back pain around the 35-40 mile mark, I shortened my stem by 10mm and fixed it, never had an issue since!
Likes For sw20:
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,447 Times
I am in agreement with the adjustment of the reach and saddle height. I have been making small changes when necessary over the last number of years. Positioning is all important. For me, aero bars are absolutely a no go! I have 2 bikes that I have switched to Velo-Orange Porteur bars and they have been a huge help, not just with my spinal issues. They have also allowed for much relief from hand numbness and tingling, and the biggest improvement is the relief of stress on my arthritic thumbs.
Quoted: 2333 Post(s)
Liked 2,097 Times
Repeating my comment on your fit thread......your cockpit aka reach to the bars is excessive, contributing to your back pain
Your upper body and head is high and you are really reaching on the aero bars.
Your saddle is slightly high (by looking at your foot and knee bend)
I would move your saddle forward as much as possible. This will effectively lower your saddle and bring the aero bars closer. I would experiment with reducing the spacers to lower the bar more. Closing the gap from your arms to your torso might also improve aerodynamics. Lowering your head just a little will make you faster.
Shoulder and back pain? If so, getting the bars closer would help.
Liked 3,018 Times
while I agree that your reach is a bit too much, I would take note of foot position too. The more "center" I had the pedals, the quicker the discomfort set in. Moving to have the pedal be more towards the frontish-center, right before the arch ended, gave me positive results right out of the gate & for those longer rides.
Note* For some reason, the change in foot placement effectiveness was applicable to the road bicycle. I didn't feel much if any positives for the MTB.
-Oh Hey!
-Oh Hey!
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,447 Times
I did not even notice the foot placement. I agree with Troul regarding getting the pedals centered on the backside of the ball of the foot. That alone will change the positioning of the lower half of the body. I see a whole of people riding with the pedals at the instep or the heel. I am not being critical, I just do not get it. Especially the heel position, which seems to me like it causes the foot to be significantly angled to prevent toe lap. Ball of the foot, I believe, is much more efficient, and puts less strain on the rest of the leg, which maybe reduces stress on the lower back.
Liked 2,097 Times
https://www.triathlete.com/gear/bike...eat-placement/
https://joefrieltraining.com/more-on-cleat-position/
https://www.stevehoggbikefitting.com...leat-position/
It might solve the lower back pain by opening the hip angle
BUT the adjustment could cause increased pressure on the arms and cause shoulder pains, hand numbness. Only riders with slim build like pros can find such adjustment comfortable with their high w/kg and proportionally low torso weight.
You can also rotate the lower back to open the hip angle by reducing reach of the aero bar or both aero bar and drop bar by reducing stem length. It has the advantage of not only easing the lower back pressure but also unloading your arms even more. You need to get used to a shorter reach, it takes a bit of adjustment period. Fortunately, it's not that long. 1 to 2 weeks of getting used to shorter reach will often be enough.
Quoted: 480 Post(s)
Liked 277 Times
What are your "off-bike" workouts like? How often do you do upper body and core work? Also, and this is totally and unfounded question/observation... It would seem spending a lot of time on aero bars with your elbows supported, takes your triceps out of the equation. Triceps are a huge (!) part of our "suspension" system - supporting the weight and acting as shock absorbers.
Maybe ditch the aero bars for a while - just go with a good fit using the traditional road bike bars. In addition to eliminating the elbow support, you'll move around more - hoods, drops, center/flats.
Likes For Zaskar:
Quoted: 208 Post(s)
Liked 109 Times
Moving the saddle forward is the last thing I would do, that pitches your weight even more forward and will make matters worse. Try a entire ride with your hands on the hoods as an experiment, allowing your weight to be more balanced over the saddle and see if that helps. I suspect it will, and if so and you still insist on those areo bars shorten that stem. Lower back pain is my nemesis as well, and even with dialed in fit I sit up in the saddle and stretch out every 15 miles or so, do core work on non-riding days, and try to remember to spin not mash. Good Luck!
Liked 2,097 Times
Edit: also important to remember that Jen is a triathlete interested in speed. The big gap from her arms to torso is not helping in the aero department. In an ideal world, she would be properly fit and sitting on an aero TT bike with a steeper seat tube angle, slacker head tube angle, and an easily adjustable cockpit. Pushing the saddle forward will also effectively lower the seat, her saddle is too high and she is reaching too much. Exercise will help but a better fit will help increase speed with better comfort, better aero, and probably more power.
Quoted: 3032 Post(s)
Liked 1,198 Times
Trying doing some planks during the week and some lower back exercises. Your back pain will disappear. Lack of core muscle strength is showing up in your back.
Likes For prj71:
climber has-been
Liked 3,642 Times
I don't see anything glaringly bad with the bike position. The hip and shoulder angles look fairly close to optimal for a triathlon position.
I suspect it's core weakness in a cyclist who hasn't had enough bike time to develop strength on the bike.
Here's an article with some exercises that should improve core strength.
Likes For terrymorse:
Quoted: 3251 Post(s)
Liked 2,537 Times
https://www.youtube.com/watch?v=DWmGArQBtFI
To me, the fit looks good. I would try, as others have noted, hands on the tops or hoods instead of the aero bars. Who cars if it is faster if it hurts.
I am also guessing that you are doing mainly flat rides. Try something a little more varied so that you change positions often. And stop every so often. Unless you are in a race, and looking to win, a little relief will do you some good.
Jen's lower back posture doesn't compare favorably to a posture that minimizes core workload, hence, the lower back muscle pain.
The purpose of reducing reach is to make it easier to assume a posture that reduces core workload which basically a lower back with higher degree of convex arch. It also moves upper body weight closer to the "fulcrum" or the pivot point (the hips), further reducing work load for the core muscles.
A lower back pain can be symptom of weak core muscles but can also be due to poor fit / poor back posture causing increased workload for the core muscles.
Bikes: Shmikes
Quoted: 10190 Post(s)
Liked 5,897 Times
There are some plausible fit suggestions above, some of which might help. However, riding for long periods in a TT position is not an easy or natural thing and considerable conditioning is necessary in order to make it tolerable. Regardless of fit, I would recommend working with a knowledgable trainer to acquire the combination of strength, flexibility, and muscular skill required to perform the job.
Quoted: 4843 Post(s)
Liked 3,968 Times
My thought is that your seat looks a lot higher than I would want Your leg is going near straight at max extension. I like to keep a lot of knee bend. I rode seat heights like yours before racing. The vets in my club immediately had me lower it and it kept going down over the next couple of years. I now have a very simple test that dials in that seat height exactly. I sit on the bike next to a hallway wall barefoot, pedal down and heel on the spindle of the upside down pedal. There is exactly one height where I can either bent my knee or lock it straight without rocking my hips. (Others like seats a little higher than I do and do the same test with low heeled house slippers or cycling shoes. Once you have "the height' keep those shoes! Makes setting up new bikes for set height brain dead easy.)
The lower seat allows me to rotate my hips forward without needing to rock side to side over the saddle, therefore allowing real weight on my soft parts. (Yes, men and women are different, but if you look at the women pros, they do exactly the same thing on almost identical saddles.) Being able to comfortably rotate your hips forward means straightening out your lower back. Right away, this should give you some relief.
I also find relief when I set up bikes for more reach. Sounds totally backwards but hear me out. More reach means I can be pulling slightly on the bars, stretching my back, pulling those vertebra apart, not compressing them. It also feels like I get better blood flow and more oxygen throughout my torso muscles so everything feels better, especially on long climbs and hard efforts. So after lowering your seat, you may find you can remove a spacer of two from below your stem and maybe even go a touch longer with a new one.
Likes For 79pmooney:
Quoted: 208 Post(s)
Liked 109 Times
As for the seat height comments, it looks to me that the OP is not fully seated in that snapshot. If she were that saddle height may be about right.
Quoted: 7058 Post(s)
Liked 11,111 Times
I initially made the same visual error that (I think) you are making: that thing sticking out from under her bum is a saddle bag, not the saddle itself. I think she is seated in the photo.
