l'eroica modern wheelset/tubeless tires?
Quoted: 38 Post(s)
Liked 40 Times
What are the odds you could get away with running tubeless wheels/tires for l'eroica? I have a set of Challenge Stradia Biancas mounted to relatively unassuming WTB dual duty tubeless ready wheels. The style seems on point but as with most consumables they are never going to be truly "period correct"
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Technically, nope:
e) Wheels must have at least 32 spokes laced to a low profile rim (20 mm depth or less); rims must be of either steel, aluminium or wood;
f) Both tubular tyres and clinchers with inner tubes are allowed;
Likes For ThermionicScott:
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
just tell people you have a tube in there
Quoted: 38 Post(s)
Liked 40 Times
I have a feeling the rules haven't been updated since the proliferation of tubeless road tires. If you can run a tube filled with sealant I don't see any unfair advantage from running tubeless tires. Then again it's not really a "race". I've heard of people running modern drivetrains linked to friction shifters and it's fine, you would think this falls in the same category.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I don't think whether or not you can get away with it is the right question, at least not to start with. I hear the California edition is looser than the others, but even there the questions I would ask are "Do you want to do this?" and "Why?"
I used modern (Tektro) dual pivot brakes at ECA. They aren't allowed by the rules. I used them because I didn't feel safe on one of the descents with vintage brakes. Not a single person commented on them.
My point is, if not using this equipment will keep you from doing the ride, maybe try to sneak it in. But if not, I think you'd enjoy the event more with a stricter adherence to the rules. Once you've settled that in your own mind (and for all I know you already have), then you can ask about local enforcement of the rules
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 38 Post(s)
Liked 40 Times
Bikes: Yes
Liked 3,868 Times
I have settled in my own mind that I will be using an 11-36 9 speed cassette which requires an HG freehub body. All of my HG freehub bodies are currently attached to modern tubeless ready wheels. I was hoping to avoid building another wheelset just for this event. This vintage dura ace crap is costing me an arm and a leg the way it is.
Your Strada Bianca tires are a great choice. Running them tubeless shouldn’t be an issue. The rims won’t blend in, but I’d be surprised if anyone said anything, especially if you’re riding an 80’s bike that might have had dark rims. Maybe ask people who have ridden the event at the location you’re riding to see if controls are tight. But also, think about the spirit of the event and decide if you want to go more vintage to enhance your experience.
My Bikes
My Bikes
none of the Eroica officials on the starting line will actually have a look at your wheelset. But......fat 30-622 tires on an old racing bike?
No, it's not a contemporary style for 70's bikes. Choose narrower tires and you are the king of the old roads.
btw: I use this Challenge tire in 30-622 on one of my gravel bikes.
Quoted: 38 Post(s)
Liked 40 Times
Quoted: 3015 Post(s)
Liked 3,804 Times
I can't imagine anyone will notice, or even care for that matter. Do what you want.
But then that begs the question, why do you want to do this ride? The objective of this ride is to experience things the way they were, not the way they are. You can take your current setup and ride any of the thousands of other organized rides. Yes, it is inconvenient to get a flat. Yes, you can't bomb down hills because your brake suck. Yes you have to grind/walk up hills because your gears suck. That's the entire point of the ride. So if you want to use modern conveniences, why do that ride instead of the countless others?
Likes For iab:
Quoted: 38 Post(s)
Liked 40 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
Likes For DiabloScott:
Liked 2,568 Times
But if the question is whether you'd get away with it... most likely. Especially if the wheels and tires look the part from a few strides away. You do you.
Bikes: Yes
Liked 3,868 Times
You've got the Italian Tricolore on the tires, so they're definitely OK. You need to relace the wheels with silver spokes though.
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 359 Post(s)
Liked 582 Times
From the moment L'Eroica CA began....
...people have been kvetching about the rules. I'm sure they have their reasons.
When people tell me they "did L'Eroica," I always ask if they followed the rules completely.
If they didn't, then I simply mention they rode the L'Eroica course, but they did not "do L'Eroica."
They either did or they didn't, and I, too, wonder why bother unless you get the total experience?
A person can ride the L'Eroica course any time they want. "Doing L'Eroica" is different.
I met a guy in Kentucky with a L'Eroica jersey, in all it's merino wool fineness.
Of course I asked. Of course he didn't. He said "they didn't check."
Of course I stated my point. He was not amused.
How dare I !! He had the jersey!
Righteous Indignation Ensued.
Likes For bamboobike4:
Quoted: 359 Post(s)
Liked 582 Times
If that's the only deviation, I suggest doing that.
Then, you'd know you did it right.
That's a thing, in some places.
Mostly a personal thing.
But you'd know.
Quoted: 38 Post(s)
Liked 40 Times
If I used a dura ace 7400 groupset with a modern 11-34 9-speed cassette, 52/39 cranks, on a Miyata 310 with those wheels/tires running tubes would that be considered "doing it right"?
If anyone has had the pleasure of mounting Challenge's "hand made tubeless tubulars" you will understand my reluctance to pop the bead off. They essentially ship you a flat piece of rubber and make you to finish the last part of the manufacturing process. Who ever named that company has a really good sense of humor.
Likes For chune:
Quoted: 4806 Post(s)
Liked 3,930 Times
Quoted: 38 Post(s)
Liked 40 Times
One cannot say they have truly "Done L'Eroica" until they have cast away all modern materials manufactured after December 31st 1987.
Liked 3,930 Times
By contrast, the Vittoria Open Corsa/Pave/G+ (haven't used many G2.0s yet) tires are just about as flat, mount easily and run trouble free
Liked 3,930 Times
When you did L'Eroica did you use brake pads and tires manufactured on or before 1987? Or did you buy modern production brake pads and tires that match the period look?
Electrolytes? Can we use the same ones we raced with 45 years ago? (And 45 years ago I spent hours on my bike dreaming of a system that would allow me to drape my palms over the brake hoods. No way will I ever go back to the old non-aero cable runs.)
Liked 3,804 Times
Well that's one objective... but people ride with modern helmets, modern lighting systems, GPS computers, cell phones, ClifBars, electrolytes, and sunscreen; I'd contend any of those is further from your objective than tubeless tires. Of course one should want the old-timey experience, but a concession here or there to make it safer or cheaper won't spoil that. @chune could drop a few hundred dollars on a legit wheel set and tires, but it wouldn't make his experience much different, and he might be the only one who even notices... unless he got some sew-ups, which would totally be worth it.
And I'll disagree about increasing puncture resistance as minor compared to the others you listed, all of which have their vintage counterparts.
Liked 3,804 Times
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
You could, but you won’t.
We also both know I’ve done it five times, from every possible direction and interpretation of the rulebook.
Once you’ve ridden the course you’re allowed to have an opinion.
Until then it’s just more armchair hot air.
Likes For rccardr:
