Bottom bracket woes
Bottom bracket woes
Old 05-19-22, 08:34 AM
ironhands
Quoted: 10 Post(s)
Liked 4 Times in 2 Posts
Bottom bracket woes
So FLBS is 3 weeks behind on repairs so I grabbed a new BB and set to work myself. Old one is toast. We're pretty sure it's a cartridge, but I can't get the old one out, ripped out the spindle to get a better look at what's going on. Using an 18" breaker bar, and the right tool, counter clockwise on the non-drive side. From what I can see, it's just seized and old, but showing a friend a photo, he believes there's a lock ring, but from what I can see, it seems to be just able to accept either the spindle tool or a wrench. Can anyone she's some light on this? If it is a lock ring and not just a cup, can you point me to a tool?
Thanks everyone, ride safe!
ironhands is offline
Old 05-19-22, 09:33 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,395 Times in 2,056 Posts
If it's a lock ring, channel locks. Turning correct direction for your BB threading?
Shoulda left the spindle in because you're going to have to bolt the tool in on tight ones. You can run a long bolt & washer or all thread & washer instead, but you really want the tool bolted in to not slip.
Some are really tight...
https://www.sheldonbrown.com/cribshe...mbrackets.html
This one the bearings were gone so the spindle was out and toll bolted in with washers and a long bolt.
Some are more stubborn than others.
dedhed is offline
Likes For dedhed:
Old 05-19-22, 09:37 AM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
The cup reminds me of an old Suntour VX bottom bracket, but the teeth aren't the right size. It had a lockring and allowed for an adjustable chainline, IIRC.
Rolla is offline
Likes For Rolla:
Old 05-19-22, 09:43 AM
ironhands
Quoted: 10 Post(s)
I hope I am! I'm not sure what's in it, flbs told me standard on non-drive side, reverse on drive side. Didn't really have much choice in keeping the spindle in, it was basically falling apart.
Would a locking typically be standard threading? Ordered a lockring wrench, should arrive tomorrow, thanks!
Old 05-19-22, 10:09 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4205 Post(s)
Liked 3,863 Times in 2,311 Posts
For some BBs we have used a pneumatic impact wrench and a BB tool with a 1/2 or 3/8 drive fitting on it. A very (thankfully) cups have had to be ground and broken out of the shell. Andy
AndrewRStewart
Andrew R Stewart is offline
Likes For Andrew R Stewart:
Old 05-19-22, 11:03 AM
andrewclaus
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times in 430 Posts
You can also remove the lock ring with a hammer and cold chisel, with tangential impact.
andrewclaus is offline
Likes For andrewclaus:
Old 05-19-22, 11:39 AM
roadcrankr
Thread derailleur
roadcrankr's Avatar
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times in 263 Posts
Some shops might let you borrow this old jobber
Mine came in handy for a bunch of pre-9speed BB's.
It's a big goofy tool that people give me grief over. Until they need it. lol
Otherwise, yeah, wail on it with a big chisel and hammer. Ya got like eight notches to destroy!
roadcrankr is offline
Likes For roadcrankr:
Old 05-19-22, 12:41 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
A little penetrating oil may make things easier.
Apply and tap the ring with a small wrench to "ring it". The vibration helps the oil to wick in.
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 05-19-22, 01:02 PM
ironhands
Quoted: 10 Post(s)
Just picked one up actually 🤣. If it doesn't work. I might just break out the dremel
Old 05-19-22, 01:04 PM
ironhands
Quoted: 10 Post(s)
Been spraying it with wd40, used some floss to open up the areas. And pulled my seatpost and sprayed a good 30 seconds into the frame. Never heard of ringing it, but I do have a small wrench and I don't feel bad about smacking it around 😂
Old 05-19-22, 01:11 PM
Bill Kapaun
WD-40 is a poor penetrating oil. Only thing I use if for is degreasing gummed up shifters.
Old 05-19-22, 01:28 PM
ironhands
Quoted: 10 Post(s)
What do you recommend?
Old 05-19-22, 01:41 PM
Bill Kapaun
Something called PENETRATING OIL.
There's various brands.
I use Liquid Wrench in the can with a spout so I can use tiny amounts in a hypodermic needle.
Spraying it all over hell & beyond just makes a mess and wastes product.
For your case, I'd just remove the lock ring with a cold chisel.
Old 05-19-22, 02:14 PM
ironhands
Quoted: 10 Post(s)
Haven't been able to find anything but wd40 locally, the only penetrating oil that would ship before July for me is $26 a bottle, so looks like I gotta use elbow grease instead
Old 05-19-22, 02:19 PM
Bill Kapaun
Ignore list since you are obviously unable to help yourself.
Ever hear of a store?
Old 05-19-22, 02:24 PM
ironhands
Quoted: 10 Post(s)
🤣 I did just say I haven't been able to find any locally, which would include stores, or did you assume I was just ransacking random garages? As my bikes not rideable, I'm pretty limited in the number of stores I could potentially visit as I don't drive. Not sure what the hostility is about, cheers, and thanks for the help 😁
Likes For ironhands:
Old 05-19-22, 02:55 PM
bboy314
bboy314's Avatar
Quoted: 332 Post(s)
Liked 740 Times in 385 Posts
Liquid Wrench and PB Blaster are 2 penetrants that should be available at any hardware store. But I agree that you might as well try a hammer and punch on that lockring.
bboy314 is offline
Old 05-19-22, 03:00 PM
ironhands
Quoted: 10 Post(s)
Unfortunately I've only seen liquid wrench products at my Lowe's, but lubricant not penetrating oil. We're having supply issues in the great white north. I did see some PB on Amazon, but it's not shipping anytime soon, so yeah, as I said above, rather than oil, gotta go elbow grease and hope that the new lockring wrench is sufficient in combination with the wd40. Appreciate the help!
Old 05-19-22, 03:48 PM
Crankycrank
Quoted: 837 Post(s)
Liked 1,061 Times in 745 Posts
If you have any acetone and Automatic Transmission fluid on hand you can make about the best penetrating oil available by mixing them 50:50.
Crankycrank is offline
Likes For Crankycrank:
Old 05-19-22, 03:58 PM
dedhed
SE Wis
dedhed's Avatar
Kroil is the best, PB blaster runner up. Acetone/ATF 50:50 mix if you want to make your own, but I just serviced 2 automatic transmissions this week and ATF is now $11/qt and used 10 quarts. Any auto parts or hardware store should have some sort of penetrating oil like liquid wrench or a CRC brand equal.
That's just Bill, ignore list a mile long. It's the internet, don't worry about it too much.
dedhed is offline
Likes For dedhed:
Old 05-19-22, 04:08 PM
ironhands
Quoted: 10 Post(s)
I do have acetone, I do a lot of 3d printing and miniature painting. Acetone and brake fluid make great paint remover. I'll pickup some ATF, thanks so much!!!
Old 05-19-22, 04:09 PM
ironhands
Quoted: 10 Post(s)
I'll have to make my own, there's literally nothing at Lowe's, appreciate the tip!
Ya, I've been on the internet since the 90s, there's always someone 🤣 have a great night!
Old 05-19-22, 04:16 PM
squirtdad
squirtdad's Avatar
Quoted: 2338 Post(s)
Liked 2,822 Times in 1,541 Posts
seriously anyplace that has ATF is likely to have a penetrating oil.
I like stuff called freeze-off but that is probably hard to find
the other thing in these situations is hard whacks, steel steel to help break things loose, I have often found hard whacks help get things started better than long levers,
good luck
squirtdad is offline
Likes For squirtdad:
Old 05-19-22, 04:25 PM
Crankycrank
Quoted: 837 Post(s)
You could always siphon a little ATF from your car since such a tiny amount is needed.
Old 05-19-22, 04:32 PM
spelger
spelger's Avatar
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times in 687 Posts
Really, I don't know what your problem is...you have iron hands, just grab that thing and crank away.
spelger is offline
Likes For spelger:
