What is considered a good FTP based on my age and weight?
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
This is fun.
Power is dependent upon a ton of things and isn't a singular measurement that can be used to predict performance.
I have personally trained a lot of racers that have had power/weight ratios that should have made them the most competitive in the region only to watch them fail over and over because...they were bad racers.
I have also watched "cagey old people" racers who wryly end up on podium after podium without "having the power" that the rest of their competition has.
Power, in and of itself, is not a predictor of racing performance, but unfortunately for a large number of individuals who are competitive by nature they sometimes feel that the only way to "compete" without actually "competing" is by comparing numbers in a vacuum.
What power CAN be is first and foremost an extremely effective training tool when used to personally set up your training and using it as strictly a personal guide and secondarily as what is referred to as a "hygiene" factor. Meaning a high power to weight ratio at FTP isn't in and of itself a predictor of performance, but the absence of a modest amount of it is definitely a predictor of "poor" competitive performance.
It truly is a balance of power to weight though that does net out your performance overall. After training at a high, focused level for many seasons the huge gains one sees from newly coming to the sport just simply disappear. You can "tweak" your power here and there, but the large increases and gains in FTP are at some point just really hard to come by and take a large volume of training load to affect. At the same time dropping weight is one of the easier things to accomplish that will result in the same sort of overall performance gains.
I worked with an ex-pro who has been coaching for 20-ish years. During a computrainer class we were running once one of our established clients was asking "what's the best way for me to increase my performance for 'x' event?". Her response was, "tape your mouth shut. It's your only hope."
It sounds harsh and it's stuff like that which gives us roadies a bad name, but it's true. You don't have to like it or even agree with it. You simply have to abide by it because that's just how the laws of nature: physiology and physics work. You can spend all your hours looking on the internet for someone who will agree with your own viewpoint on it or you can get faster. Your choice.
OP - you asked what a good ftp was for you. We all know what you are trying to ask. It should be a relatively "easy" thing to answer, but the reality is actually extremely dependent upon what you are trying to do. If you're trying to be competitive in a certain dicipline then it may be one thing. If it's to be healthy then it may be another thing.
After having been a dealer of power meters of all sorts as well as running a computrainer multirider studio for 5 years now I feel that I can state this with a bit of authority: every rider who has come to me and use the numbers they arrived at through the use of a trainer's curve and their speed has been woefully off the mark. Usually by 20% or even more. The funny thing is....it's meaningless. The point of having a "number" is to know how to train and to gauge improvement or decline so if you get your "number" from a trainer and you always use that trainer when testing against that number or training with that number then it's "absolute value" or "Accuracy" is meaningless. Luckily we don't decide races or other competitive events by the "numbers" we post. We do it by lining up next to each other and seeing who crosses the line first.
If you're training across a lot of different devices due to situation, travel, etc. then the absolute value of the measurement or accuracy of the device is an important consideration, but only in as far as how it impacts your own training.
As I mentioned before - while power to weight isn't a measuring device in and of itself as a predictor of performance we CAN usually say what is competitive in this area for the races we do. In essence if you're below that 3.0 W/kg ratio then historically we have seen poorer performance in our local competitive races. Not to say success isn't possible it just means that we tend to help the rider focus on improving at that Cat 4 level to improving into the 3's instead of throwing a kit on them and giving them wheels with the hopes of them dominating podiums.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Bikes: Roubaix SL4 Expert , Cervelo S2
Quoted: 85 Post(s)
Coggan says he actually did away with that w/kg chart due to the number of people who misunderstand it. He says that he brought it back when a large number of coaches begged him to. BTW, here's a link to a more current version of the chart (he is constantly updating it based on race results.)
https://www.bicycling.com/training-nu...files-cyclists
Quoted: 5 Post(s)
Good compared to what? Figure your watts per kilo then refer to this chart.
https://www.livetrainrace.com/wordp/w...ight-chart.png
Quoted: 5 Post(s)
Power-to-Weight Ratios: Bicycling Training | Bicycling Magazine
Quoted: 5 Post(s)
how many cyclist to Coggan survey to construct the table, and how does that impact comparisons to data one might glean from the tens of thousands-- hundreds of, maybe even?-- Strava users? Within that framework, what does the Veloviewer Score tell us that the Coggan chart doesn't?
Secondly, as a percentage of total cycling population, do USAC licensed racers constitute .1%? More? Less? And what percentage pros? If, say, 94% of all cyclists test an FTP of sub 2.5w/kg, a 3w/kg FTP rider, while placing amongst the top 10% of all riders, still barely breaks Coggan's lowest tier, Untrained.
My point being that, while the Coggan chart may be useful for comparing one's self to pro cyclists, it doesn't say much about how you'll stack up on the road against those you're likely to ride with and run across.
Power Profiling | TrainingPeaks
(Note that the chart linked from that article is out-of-date....it's up to version 8 now.)
Quoted: 5 Post(s)
Quoted: 5 Post(s)
The lower anchor point (i.e, center of untrained range) of each column is based on literature values for average, untrained, young, lean men or women. If you or someone you know can't match those values, then you/they must not be young and/or lean, and/or you are simply below average. (Of course, given that physiological capabilities generally follow a normal distribution, the latter would apply to ~50% of all individuals.)
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I think you need more levels underneath "untrained"
Quoted: 2952 Post(s)
Liked 3,106 Times
Anyway, it's interesting to see that I fall pretty much exactly on the all-arounder profile. I can work with that. The trick now is to push all the values up.
Quoted: 85 Post(s)
How on earth can you determine a perfect stranger's FTP by observing them on a ride? I ride in a place with a ton of roadies and there's no way I could eyeball somebody and determine their FTP. I have a power meter so if they were chasing me up a climb for at least 5 minutes I could get a rough approximation if I could guess their weight fairly close but that's about it.
Bikes: Nashbar Road
Liked 341 Times
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
Think of watts for rider as of hp for car.
Watts/hp alone will not tell you how fast rider/car is - only combination of both will.
On side it's pure human physiology - bigger rider should produce more total watts (assuming same body fat %: more muscle mass = more power).
So if you measure your own performance (as OP intended) it's important to know which category you fit in hence the whole watt/kg scale.
Applying this to cars hp/kg will tell you a lot about the zero to sixty time of the car, but hp/ frontal area x drag coefficient will tell you more about the top end speed the car is capable of.
You could get lost and die.
You could hit a tree and die.
Blast from the Past
At 58 I flirt with "untrained" at FTP (despite a fair amount of training) and can still almost touch "Cat 2" at 5s. The combination tells me something and is a pretty accurate description of my capabilities as a rider. And that profile has been consistent despite years on and years off the bike.
Liked 3,106 Times
After reading this thread, I can see why Dr. Coggan took out the category labels.
Bikes: Nashbar Road
Liked 341 Times
When looking at Strava don't underestimate the power of a stiff tailwind. I have not looked at a recent version of the chart but I think the word "untrained" is a little misleading and perhaps leaves a bad taste with some. In the PC world perhaps we should be aerobically challenged?
Thread Killer
Quoted: 3149 Post(s)
Liked 1,714 Times
The answers to your questions can be found here:
I just wonder to what extent, when you say, "In theory, tables of standards for power output for different durations could be generated by simply collecting data on a large number of cyclists of widely varying ability," that Strava does precisely that, and further provides a more real-world (i.e. amateur) comparative picture as opposed to benchmarking off professional athletes?
I eat carbide.
Liked 1,306 Times
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
EDIT: This is a zombie thread, but this might be of interest to some readers.
If you're really interested in knowing how your best power "stacks up" against others of the same age, Training Peaks app has a beta feature called StackUp that will show you your percentile.
Here's a screen shot from my app:
