Can you keep up with fast roadies?
Old 05-10-21, 03:28 AM
LarrySellerz
Quoted: 2700 Post(s)
Liked 486 Times in 351 Posts
How capable are fixies of keeping up with road bikes. I went to a local bike shop and the dude was pretty insistent that a nice track bike/single speed would be significantly slower than a road bike. Im considering getting a 700$ ish track bike, should it be much faster than my 500$ hybrid? Obviously gears are great for elevation changes I'm talking on the flats, the dude was saying the track bike wouldn't be a huge upgrade from my hybrid.... he must be wrong right? Thanks
LarrySellerz is offline
Old 05-10-21, 06:17 AM
TugaDude
TugaDude's Avatar
Quoted: 586 Post(s)
Liked 612 Times in 447 Posts
Is speed your main concern? By the way your question is worded it seems so. Are you looking to join a group? If so, you probably should invest in a bike more similar to what they are riding. Otherwise, no matter what, there will be times when you lag behind.
Common sense tells me that in the same gear, there is no disadvantage to a fixed gear and actually advantages. The bike will likely be lighter than geared bikes (assuming it is of comparable quality) and there is efficiency in a fixed gear drivetrain. In a geared bike, the chain must wind around the jockey wheels and that simply isn't the same.
But the "fast roadies" change gears and they do it often. So you will be at a disadvantage when it comes to hills, both up and probably down. They can go to a lower gear and leave you in the dust on steep ascents and then they can coast down. You may have to even walk up a steep hill at times.
So again, if speed is you main concern and you will be riding with a group of roadies, get a geared road bike.
TugaDude is offline
Likes For TugaDude:
Old 05-10-21, 06:23 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Quoted: 1465 Post(s)
Liked 1,542 Times in 806 Posts
If you have the power, endurance and guts to be in the wrong gear 85% of the time, but still hang with fast road riders, then respect for you. I'm never "faster" on a fixed gear than I am on the same route with a geared bike. On the other hand, I'm rarely bored and have both a greater level of enjoyment as well as a sense of accomplishment after a challenging fixed ride. So, there's that.
You ride a hybrid now? They why not try the track bike and prove the other fellow wrong?
Phil_gretz is offline
Likes For Phil_gretz:
Old 05-10-21, 07:03 AM
IAmSam
Quoted: 399 Post(s)
Liked 274 Times in 136 Posts
No
IAmSam is offline
Old 05-10-21, 07:42 AM
Speedway2
Speedway2's Avatar
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times in 246 Posts
No....but you might be able to keep up with yourself.
Speedway2 is offline
Old 05-10-21, 08:00 AM
rustystrings61
Quoted: 823 Post(s)
Liked 1,396 Times in 694 Posts
When we had a bike club in this town and I was an active member, I did a lot of group rides on one or another of my fixed-gear bikes. My memory is that I hung with them pretty well, but I was in shape then, too, and riding 2,00-3,000 miles annually.
In terms of my speed, for general riding around this area's rolling terrain there isn't really a significant difference between whether I ride fixed or multi-speed. I can have a lovely and enjoyable and even challenging ride either way, whether solo or with others who are seeking a comparable ride experience, and I bet you would find the same is true for you.
In terms of riding with others, if the goal is to go fast and hammer, no, you will want to ride something comparable to the pack. I've been there and done that and could happily spend the rest of my life far from modern roadie culture and its conspicuous consumption - but that's a big part of the appeal of a fixed-gear for me, it's an upraised middle finger to the constant consumption/obsolescence/replacement cycle.
rustystrings61 is offline
Likes For rustystrings61:
Old 05-10-21, 08:43 AM
AlmostTrick
Tortoise Wins by a Hare!
AlmostTrick's Avatar
Quoted: 1549 Post(s)
Liked 942 Times in 504 Posts
I've done the same group rides fixed and geared and always kept up. We have hills some hills but nothing both long and steep. While on fixed I often pass the geared riders going up, and they pass me going down, but we always catch up to each other.
Also, I don't buy that 85% wrong gear business. Maybe in the mountains it would be. I find my fixed to be the correct gear more than 85% of the time. If it's not I'm either riding mountains or a bike setup with the wrong gear.
AlmostTrick is offline
Likes For AlmostTrick:
Old 05-10-21, 09:03 AM
base2
I am potato.
base2's Avatar
Quoted: 1790 Post(s)
Liked 1,631 Times in 934 Posts
On a fixie or a single speed? I'd be pretty impressed if you could safely mesh into a group of motivated road bikes.
I'm not sure I'd appreciate the wildly different braking dynamics between the different classes of bike though. Without conventional lever operated brakes on both wheels, your braking capability will always remain a hazard to the others.
You are free to replace your friends derailleur hangers, buddy flaps, fenders, etc... when you knock them down from behind. It would be an interesting experiment to see how how long they will remain a welcoming & friendly group of non-"elitist roadies."
Define the term: "Fast roadies."
Car dependency is a tax.
base2 is offline
Old 05-10-21, 09:27 AM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
Fixed or free doesn't make a difference; it's all about the single speed. Put your geared bike in a single midrange gear, jump on a roadie's wheel, and see how long you last.
That depends on the terrain and who's riding the bikes.
Spending more money doesn't equate to more speed.
Gears are great for a lot of things, including riding fast on long, flat sections.
I love my singlespeeds, but if I'm riding with multi-geared roadies, I expect to get dropped. "Horses for courses," and all that.
Rolla is offline
Old 05-10-21, 10:03 AM
bykemike
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Quoted: 110 Post(s)
Liked 203 Times in 81 Posts
I've made the decision to ride single speed all the time I am in Florida. This has been about 5 months now and so far, so good. I had a bit of a break through this past weekend when I tried my first 65' waterway bridge. I'd estimate this one mile bridge is about a 4 % grade, maybe a bit less, and I didn't know what to expect. Honestly I shot right up to the top, never had to stand and then went ahead and did 4 repeats. I'm old and no physical marvel but I had changed the gearing to 46/20.
This event has freed me up actually. I had figured I was going to be locked into walking these bridges so I stayed away, now I have changed my daily ride to do that bridge 2-4 times each ride.
"ready to navigate"
bykemike is offline
Old 05-10-21, 10:09 AM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
My local Saturday morning race ride, the River Ride, is extremely flat except for a couple of overpasses and levee ramps, so climbing is not an issue. Very doable in one gear, and every once in awhile you'll see someone on a track bike. You need a big gear and brakes, of course. It's always been a rider who has road and track experience, so I've never seen a problem.
caloso is offline
Old 05-10-21, 10:54 AM
LarrySellerz
They seem fast to me, they destroy me up the hills. A favorite local climb takes me 29 minutes and I’m sure they are all sub 23 on it.
I don’t intend on pacelining or riding close on the fixie. Maybe just ride their route and see if I can keep them in eyesight or something. Maybe if I get really good then sure, but I’m not even thinking about doing a group ride. Just want to be fast
Old 05-10-21, 11:45 AM
burnthesheep
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times in 974 Posts
Totally depends on the local terrain. We routinely have guys who bring their flip-flop equipped fixies to the road hammer ride and do just fine. They just flop it over to the single speed side. It has a few hills but nothing ridiculous. They run it single speed to avoid any fixie issues in close quarters with folks used to having hand brakes. Not the fixie so much messing up, but roadies grabbing a handful and messing up the poor fixie person.
If it's pan flat up to I'd say 40 feet elevation per mile (800 feet in 20mi) then I'd say no problem. If it gets into the 80+ feet per mile (1600 feet or more in 20mi) then I'd say not do it. Not for not keeping up on flat or uphill, but the downhill spinout.
Flats? Dude doesn't know what he's talking about. The track bike will work just fine. As for the track bike versus the hybrid.........how you sit on the thing makes the difference. Narrower lower bars, more aero. So on the flats a single speed track bike is great for road riding.
I would do it myself to mix it up, but I live in a neighborhood that's only 100 foot hills of 6% or so one after the other.
burnthesheep is offline
Likes For burnthesheep:
Old 05-10-21, 12:36 PM
Mikefule
Quoted: 99 Post(s)
Liked 115 Times in 78 Posts
I have a fairly lightweight road fixed, and a pretty heavy 2 x 10 gravel bike with dropped bars.
The weights are substantially different, as are the aerodynamics. However, the 2 x 10 has the advantage of a wide range of gears and I have fitted it with 28mm tyres, the same type as the 25 mm ones on the fixed.
On my local favourite loops, the average speeds over a route are the same, whichever of the two bikes I am on. However, closer analysis shows that the speeds on each short section vary quite substantially.
A simple answer is that on my fixed, I can "keep up with myself on my geared bike". I could compete over 10 or 20 miles with someone of similar weight, fitness and ability if I were on the fixed and they were on the geared.
However, I would seldom be riding alongside them. Sometimes they would be well ahead, sometimes they might fall behind.
If they were on a geared lightweight road bike, they would leave me for dead.
Mikefule is offline
Old 05-10-21, 01:57 PM
Ymerej
FIXED GEAR
Bikes: 2019 tarmac pro disc 2020 allez sprint track
Quoted: 14 Post(s)
Liked 36 Times in 14 Posts
I rode the same route fixed and geared, fixed was about 5 minutes slower and about 1mph slower over the 34 mile route pretty much same conditions and some stop lights.
I pass geared riders all the time and they pass me as well, the thing is with fixed, you have to keep your speed up all the time and that disciplines you into hammering all the time.
punchy climbs and little rolling hills are fun.
Geared riders become complacent, they coast on the small downhills and down shift on the little climbs. I just try to hammer through the whole thing.
If you’re going to get a fixed and want to tear it up, set up your bike proper, no platform pedals no disco fixie shi+
You only have 1 gear so you have to make the most of it.
fixed gear is a great training bike to teach you to hammer and suffer.
Ymerej is offline
Old 05-10-21, 03:14 PM
LarrySellerz
strava claims it’s 1357 ft of elevation for 24 miles. Probably another 600 just to get to the ride
How sketchy is taking your feet off the peddles and coasting down hills on a fixie? If you have a brake it should be ok right, or is it not something you want to routinely do. The other fixie guys might make fun of me for coasting lol
Old 05-10-21, 03:24 PM
Lakerat
Quoted: 213 Post(s)
Liked 37 Times in 21 Posts
Geared bikes will go faster on uphills and downhills than fixed gear bikes. If you can make up for that on your fixed gear bike, " ... salut, DonCorleone."
Lakerat is offline
Old 05-10-21, 04:06 PM
Senrab62
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times in 147 Posts
I'm always faster on my geared bikes. Even my 3 speed fixed which weighs in at a portly 26.5 pounds is faster than my fixed only bikes on the same route. Planning to ride with some buddies this weekend, some faster and some slower, will see what I can manage on fixed. Will likely take my 3 speed to see if I can hang in the middle
Senrab62 is offline
Old 05-10-21, 04:43 PM
bykemike
Quoted: 110 Post(s)
BTW, anyone watching the State Bicycles video series on youtube "Riding Fixed up mountains with Pros"
Reminds me of the Rapha videos but, currently anyway, I'm hooked.
"ready to navigate"
bykemike is offline
Likes For bykemike:
Old 05-10-21, 06:18 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Liked 1,044 Times in 667 Posts
Yeah, I’ve been thinking of turning my roadish SS into a dingle, so I can add the big chainring and get a taller gear, partly for downhills and partly for interval work. Around here we have similar 100’ to maybe 150’ hills, so the SS gear wouldn’t cause me an issue keeping up (on the climbs).
Otto
ofajen is offline
Old 05-10-21, 06:29 PM
Rolla
Guest
Taking them off the pedals is easy. Putting them back on at speed is... well ... try it and see.
Rolla is offline
Likes For Rolla:
Old 05-10-21, 08:12 PM
jay4usc
Live Healthy
Bikes: Wabi Classic
Quoted: 183 Post(s)
Liked 137 Times in 92 Posts
nice bike, what brand is that
jay4usc is offline
Likes For jay4usc:
Old 05-10-21, 08:21 PM
bykemike
Quoted: 110 Post(s)
It's a Wabi lightning.
"ready to navigate"
bykemike is offline
Likes For bykemike:
Old 05-10-21, 09:20 PM
Russ Roth
Quoted: 1088 Post(s)
Liked 1,028 Times in 724 Posts
The proper term is how exciting is it, I'm gonna assume you have brakes front and rear before attempting such an exciting thing as pulling your feet off. Hope you have MTB SPD style or it'll head past sketchy and exciting to something even less fun real fast.
As others have mentioned, fixie will totally change your speeds at various times, I found it slightly easier to maintain a decent pace over small rollers due to the pedals wanting to turn and keeping the legs going although even then the downhill speed just wasn't the same. I'm limited to about 110rpm which I can't maintain for any real length of time so I'd find myself braking on even small downhills due to not being able to spin. At the same time I do best at about 75rpm and with my regular bikes and just tend to push harder gears to compensate while the fixie had to be set to lower gearing just so I could make the hills limiting my speed. Vs me on a road bike, the fixie will be slower, vs me on my hybrid over flatish terrain, I'd be faster on the fixie. The worst part, and what gets you over distance, is the inability to coast and rest in the process.
Russ Roth is offline
Old 05-10-21, 10:20 PM
TMonk
Not actually Tmonk
TMonk's Avatar
Bikes: road, track, mtb
Quoted: 2641 Post(s)
Liked 3,153 Times in 1,660 Posts
Depends on the course. Most often the geared bikes will offer an advantage. I'm a "fast" roadie, and track racer, and time trialist. In most courses (around here). the FG will put you at a disadvantage. Do some track racing! Then it won't slow you down
"Your beauty is an aeroplane;
TMonk is online now
Likes For TMonk:
