What chain for my ‘20 Giant Defy?
Old 07-10-21, 02:56 PM
GBK233
Bikes: 2020 Giant Advanced 2, 2020 Giant Contend AR1
Quoted: 166 Post(s)
Liked 78 Times in 34 Posts
Bike has 1000+ miles on it. It has almost .5% stretch….so probably going to need to replace in the month or so. OEM chain is
a KMC X11EL-1.
Should I stick with OEM or is there another chain I should be looking at?
Couldn’t care less about weight. Would rather have quality/longevity
GBK233 is offline
Old 07-10-21, 09:51 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
Any Shimano 11 road chain. Or pretty much any KMC 11 chain. Hell, if the only thing I could get was a SRAM chain I'd put that on and not worry about it.
cxwrench is offline
Likes For cxwrench:
Old 07-11-21, 07:15 PM
veganbikes
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times in 2,665 Posts
What about the Campanoglios or those Cool Whipperman chains?
veganbikes is offline
Old 07-11-21, 07:46 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Absolutely, they're both great chains.
cxwrench is offline
Old 07-11-21, 07:56 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3004 Post(s)
Liked 2,433 Times in 1,187 Posts
Do you clean and oil it regularly?
I get around 3000+ miles from a Sram 1190 chain.
GlennR is offline
Old 07-11-21, 08:04 PM
GBK233
Quoted: 166 Post(s)
my chain is pretty much spotless. I degrease and clean it weekly. I use Smoove chain lube
GBK233 is offline
Old 07-11-21, 09:03 PM
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Why?
A chain lasting only 1000 miles is unusual. Degreasing and re-lubing every week is unusual. The two unusual things are probably related.
WhyFi is offline
Old 07-12-21, 02:22 PM
GBK233
Quoted: 166 Post(s)
Originally Posted by WhyFi
Why?
How would spraying some degreaser and cleaning a chain….cause it to “prematurely” stretch? I mentioned that in another month or so I would probably need to replace it. In that time I’ll have another 600ish miles on the chain. So even in that scenario the chain I would have about 1500 miles on it.
I weigh 200lbs….I would guess that the heavier a rider is, the faster a chain would stretch, but I surely could be wrong about that.
GBK233 is offline
Old 07-12-21, 02:36 PM
WhyFi
WhyFi's Avatar
It's called "chain stretch," but chains don't actually stretch - the elongation is because of internal wear that causes more play between the links. If I had to hazard a guess, you're probably not doing a good enough job of getting lube back in to the rollers each and every time you degrease, which would cause premature wear.
WhyFi is offline
Old 07-12-21, 02:41 PM
Iride01
Iride01's Avatar
Quoted: 6193 Post(s)
Liked 4,809 Times in 3,317 Posts
I just put oil on my chain. Being overly generous with degreaser just seems like you might wash the lube out of places the lube really needs to be. And when you re-lube the chain, how do you know the new lube displaced the degreaser that displaced the previous lube?
Iride01 is offline
Old 07-12-21, 02:45 PM
WhyFi
WhyFi's Avatar
I mean, if you're already *really* degreasing your chain and you want to keep your drivetrain clean, buy some Molten Speed Wax and a $10 mini crockpot from Target. My current chains (I buy/use two at a time so that I can do a quick swap every other time) have about 4k miles each on them and have less stretch than yours.
WhyFi is offline
Old 07-12-21, 02:53 PM
GBK233
Quoted: 166 Post(s)
I guess it’s possible.
I degrease and scrub the chain with a brush. I then lube each individual link….including the pins coming thru the side plates. I pedal the bike a bunch while it’s on the stand to get the lube spread around. I then leave it overnight.
GBK233 is offline
Old 07-12-21, 02:57 PM
WhyFi
WhyFi's Avatar
We *know* that your chain wear is premature; the mileage that you're talking about would have many people here buying a new chain every 4-6 weeks.
WhyFi is offline
Old 07-12-21, 03:01 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
"Degrease" how? For example, Overnight submersion in mineral spirits, or just wiping chain with a rag that might be dampened with something or other to get the visible crud off? etc
Sy Reene is offline
GBK233
Quoted: 166 Post(s)
no. I meant it’s possible im not getting lube deeply enough into the chain.
GBK233 is offline
Old 07-12-21, 03:03 PM
GBK233
Quoted: 166 Post(s)
Spray with degreaser(Purple Power) and scrub with a brush. Rinse. Dry chain with towel then Air dry in the sun. Then Smoove lube.
GBK233 is offline
Old 07-12-21, 03:42 PM
SoSmellyAir
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,469 Times in 1,018 Posts
From my personal anecdotal experience (which I readily admit is likely not statistically relevant) Purple Power may be too harsh for chains.
Bike Forums - View Single Post - Broken 105 Chain
SoSmellyAir is offline
Likes For SoSmellyAir:
Old 07-12-21, 03:46 PM
SoSmellyAir
From what I have read in these forums it seems that there may be some difficulty in getting more waxy lubricants like Squirt and Smoove into the rollers during cooler temperatures.
Old 07-12-21, 04:55 PM
sshakari
sshakari's Avatar
Bikes: Canyon Endurace, Merckx liege 75, Cinelli Vigorelli
Quoted: 167 Post(s)
Liked 114 Times in 61 Posts
+1 for Wippermann
sshakari is offline
Old 07-12-21, 05:04 PM
sshakari
sshakari's Avatar
Quoted: 167 Post(s)
best way is:
Leave it in Petrol = 4-6 hours after that
Degreaser = 1/2 hour, then washout degreaser with water.
Put in Methylated Sprits = 1/2 hour.
Let it dry and you will have a perfectly degreased chain. Dont leave it without grease for too long or it will begin to rust.
sshakari is offline
Old 07-12-21, 07:06 PM
GBK233
Quoted: 166 Post(s)
Well…now I’ve gone down the YouTube rabbit hole regarding chains and chain lube. I’m kinda liking the melted wax thing.
One video by “Oz Cycle” showed a recipe using refined paraffin wax and PTFE powder mixed in a crock pot.
unless someone has a good reason that this is not a good idea….I think I’m going to give it a try. Will probably soak my chain in kerosene and clean the heck out of it…..rinse and dry…..then once it’s spotless, go the melted wax route.
GBK233 is offline
Old 07-12-21, 07:19 PM
WhyFi
WhyFi's Avatar
If you're willing to put in the time and effort on the initial cleaning, wax is much, much lower effort. If you want to go through the trouble of the homebrew mix, go ahead, but it's a lot easier to buy a bag of MSW (and it's not expensive - it should last you a 10,000+ miles).
WhyFi is offline
Old 07-12-21, 07:44 PM
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
By the low numbers you might as well just wipe with a rag and lube on top. Thats what I do most of the time, only occasionally cleaning it with white spirit. I find the investment in time and cleaning agents to be dubious compared to the price of a, admittedly 10 speed, chain. I never get the silly miles ppl like to post, but mostly I can replace chains with no skipping or other issues. Not tracking my miles on most rides I guess about 2500 mi. Then again there is no knowing what your gauge considers "0.5%". It may be overly conservative. For some time I have used a digital calliper and replace the chain before the "between the rollers distance" have enlarged 0.75% (~132.25mm -> 133.20mm). At that point true elongation is in fact less than 0.5% but the chain is notably worn in the rollers and has obvious side play.
Racing Dan is offline
Old 07-12-21, 07:50 PM
GBK233
Quoted: 166 Post(s)
Originally Posted by Racing Dan
Then again there is no knowing what your gauge considers "0.5%". It may be overly conservative. .
Good point….mine is a cheap gauge from Amazon. Could be inaccurate. I’ll pickup a better quality tool…maybe a Park Tool gauge.
GBK233 is offline
Old 07-12-21, 10:15 PM
SoSmellyAir
Or you might consider the Pedro version:
Amazon.com : Chain Checker Plus II, Black : Sports & Outdoors
Slightly cheaper than the analogous Park model, plus it can (1) hold the chain for quick link installation and (2) serve as a chain ring nut wrench.
