Another Stuck Seatpost, Latest Ideas Needed
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Well I picked up a Trek 560 along with several other bikes from a local guy. The Trek is in fair shape if a little small for me except the seat post is stuck solid in the seattube. The bike was left out in the elements so water probably went down the flutes in the seat post which I'm sure doesn't help. OK, I poured PB Blaster down the flutes (shown in the pic) a few times. I tried hitting that ratty seat with a 12OZ hammer on more than one occaision, nothing.
My next moves will be a little more drastic. I'm thinking of inverting the bike, removing the BB and spraying PB Blaster down the seat tube from the inside. If that doesn't work, I'm thinking either ammonia or Coca cola. Anyone agree with this or have other ideas? Recommendations welcome.
I'd hate to lose this nice bike due to this problem. I put the red tape on as a marker to let me know if the seatpost moved. BTW, the stem is OK so no problems there. Here are some pics:
Roccobike BF Official Thread Terminator
Do you have a bench vise? Did you see this video that Kurt posted recently?
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Bikes: Seven Cycles ID8 & steel Axiom; Bridgestones: MB-1, RB-T, XO-1, '85 Orange Gran Velo; electrics: Bionx, Swytch, Eflow Nitro; Merlin early MB; Raleigh Twenty & a lot of comings and goings
I have had good luck using cold temperatures. I put dry ice on the seat tube. The aluminum seatpost contracts more than the steel frame and it is like pulling the sword from the stone. I have heard it works with just cold nights as well. I may have just been lucky with two of mine.
Bikes: 90 Raleigh Chill MTB, 92 Trek 1200, 2004 Trek 2300, 67 Sports, 70 Sports, 71 Philips, Lotus Challenger, 74 Super Course, Univega Gran Tourismo, Nishiki Seral
Seeing you don't care about the seat, I would try a long pry bar between the seat rails and rotate being somewhat judicious wiith the force applied. Has the PB been applied at least over night?
Bike Junkie
Quoted: 68 Post(s)
Liked 37 Times
Thanks,
Yes I waited overnight, then several days re-applying PB. Good point auchencrow. I want to recover the bike. The saddle is junk anyway and the seatpost is expendable. Bending the stays is not what I want to do. The dry ice sounds interesting, but it's cold in my basement so I don't know if I can achieve the temp difference, but I may try anyway.
I've not seen that video before. If all else fails, that might be the way to go.
Tomorrow night I'm going to remove the BB and pour PB down the seat tube. I'll post here if I find a solution.
If anyone has another idea, please let me know.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Cold+Penetrant = "Freeze-Off" by CRC. Worked for some (inclucing me) here already to remove stuck seaposts, stems and BB cups when PB blaster, Liquid Wrench, Kroil and other penetrants did not work. Just make sure you a bit of "Strategerie" when you use it to get best use of the temp differential/expansion/contraction effect.
Good luck, I hope you find a final solution for your Trek soon.
Forgot to note, Freeze-Off, per what I read on their spray cans, IS HIGHLY FLAMMABLE and should only be used in well venitlated areas. Closed up garages and pilot lights and other sparky things (uhmm.....static??) should be avoided when using it. I suspect like most other chemicals, it's also not good to breath into your system. I always fully opened up my garage door when I used it, so my house is still showing up in the latest Google Earth maps.......
Chombi
Chombi
car dodger
Take it outside, put the seat in the crook of a tree (or equivalent), and twist the whole frame about the seatpost.
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Then, when you catch your neighbors staring yell, "Hey! What're you lookin' at!?"
Bikes on Flickr
Bikes on Flickr
Quoted: 150 Post(s)
Liked 34 Times
OK,...........you can also tie down a small metal cage full of bannanas on to the doomed saddle and throw the frame into you local zoo's Gorilla exhibit (make sure they have an Alpha male silverback in the group) for a few minutes. pull out and check and repeat...and rinse.....as needed......
Chombi
Chombi
Quoted: 765 Post(s)
Liked 660 Times
Maybe ftwelder will weigh in with photos of his amazing mega-leverage seatpost extractor. It was mentioned on another thread not so long ago. I actually saw it when I paid a visit to Frank's shop before Thanksgiving--it's a thing of beauty. I've actually thought about making one of my own--from wood rather than steel because I'm that's what I'm more set up to do, toolwise. To use it, you have to pull the bottom bracket, and the base of the seatpost has to be more strongly brazed to the bottom bracket shell than the seatpost is stuck to the inside of the seat tube, or the frame will be pulled apart. But I think you're more likely to pop the seatstays loose by trying to twist the seatpost loose with the ol' tree-crotch method (which I have admittedly used with success).
Frank! Frank! Are you out there?
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Ride heavy metal.
Bikes: '74 Raleigh LTD-3, '76 Motobecane Grand Jubile, '83 Fuji TSIII (customized commuter), '10 Mercier Kilo WT (fixed obsession), '83 Bianchi Alloro, '92 Bridgestone MB-1 (project), '83 Specialized Expedition (project), '79 Peugeot UO-8 (sold)
His method involves pouring a pan of boiling water on/down the seat post, and then letting it cool back to regular temperature. The expansion that takes place when the aluminum heats up followed by the concurrent shrinking when the heat is removed is usually enough to break the galvanic corrosion holding them together. The nice write-up on his blog is linked here.
car dodger
I would try the tree (or whatever) method up to a certain force point, also I would have a rear wheel (or hub) mounted for additional frame support.
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Quoted: 7352 Post(s)
Liked 2,479 Times
Keep us posted. You can do this. If you feel like giving up, we'll give you more advice and encouragement.
Quoted: 3811 Post(s)
Liked 6,717 Times
Ride heavy metal.
I still need to know if Moulton's boiling water method works. It has the right combination of simplicity+believability to make me supremely curious. I'd almost like to come across a stuck seatpost, just to give it a whirl...
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
+10 Put the seat or the top of the seat post clamp, in your favorite bench vise. I use the main frame triangle for leverage, turning it (hopefully) side to side. I am careful to avoid pulling on the back end of the frame (the stays), as I do not want to do damage there. My guess is that the larger main triangle tubes can take more abuse than the smaller stays. And the attachment of the seat stays in particular to the seat tube is pretty flimsy, compared to the top tube's attachment to the seat tube.
Larger Chainring
Bikes: 1988 Schwinn Circuit. Bike-Boom-Puegeot. First "real bike" Trek 720 Hybrid in gross disrepair.
Maddox, going to try this right now. I've tried everything but the Freeze-off.
Quoted: 150 Post(s)
Liked 34 Times
Liked 2,479 Times
I'd prefer to use brute force. It's not as scary to me as caustic chemicals.
Consider, Tom, that your mustache gives you powers of which the rest of us can only dream. The rest of us are often reliant on the crutches of "chemistry" and other "sciences".
Bikes on Flickr
Bikes on Flickr
holyrollin'
I like to use the PB Blaster, as you've already done. It's more effective if you are willing to first put a tapered punch into the seatbolt ears and gently tweak them apart, opening the seat tube slightly and (hopefully) breaking the corrosion seal.
I know this is utterly barbaric, still it always seems to help.
