Headset press
Guest
Posts: n/a
Quoted: Post(s)
hey i was wondering which head set press was better than the other:
Axiom this Axiom looks nice and im sure it's better than a rubber mallet
Cyclus this ones 5 bucks cheaper and looks cheaper, but who knows how it peforms.
park tools this park tools one kinda looks cheap and home made, but it's park tools
Guest
Posts: n/a
Quoted: Post(s)
Originally Posted by phantomcow2
Or you could just make one using threaded rod, two large washers, and 2 nuts.
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
Why do you think you'd ruin it?
If you're worried, try buying two thin rubber washers as well and place them between the metal ones and the cups.
Bikes: Puch Luzern, Puch Mistral SLE, Bianchi Pista, Motobecane Grand Touring, Austro-Daimler Ultima, Legnano, Raleigh MountainTour, Cannondale SM600
I have the Cyclus press. Used it probably 5 or 6 times and it works very well.
Quoted: 2026 Post(s)
Liked 1,096 Times
The Park tool seems to be a commercial, somewhat more refined version of the homemade threaded rod with washers rig. The washers are shaped and perhaps padded to avoid distorting the cups. For one headset, I'd use the homemade version and, as recommended, put some soft washers on it.
Si Senior
Bikes: Too Numerous (not)
Quoted: 23 Post(s)
Liked 10 Times
I use brass washers next to the headset on my homebuilt press. But I also look far any excuse to buy a new tool.
Easily distracted...
Bikes: Surley Cross Check
I've got a new headset sitting on the work bench. I'm stopping on the way home to pick up a bolt, nut, and a couple of washers. Can anyone recommend the dimensions for a good homemade press? I'm thinking a 3/4" x 9" bolt with 1.5" washers. After the homemade cup remover worked so well, I'm feeling confident about my mechanical skills to put them back in.
Guest
Posts: n/a
Quoted: Post(s)
Consider This:
https://www.bikeforums.net/attachment...id=49121&stc=1
https://www.mindspring.com/~d.g1/headset.html
I made a similar version with 3/8" allthread, nuts, washers, and pvc couplers(instead of brass bushings).
I've used it many times without any problems or headset damage.
Videre non videri
Here's what I used:
The threaded rod is 20 mm in diam.
Worked perfectly. The cups went in like a hot knife through butter.
Total cost was equivalent to US$15, but then the rod is 1 m long...
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
Stuart Black
Stuart Black
Hoosier Pedaler
I too have the Cyclus. It is heavy and well made. Really pretty nice. Works like a charm. I have BB facing tool as well. Same comment.
I use the newest of the park ones on a regular basis. We used to have a 10 year old version of it untill I dropped it and it broke in half. Low and behold they warrantied it! As far as major shop tools and equipment, you cant beat park.
Quoted: 443 Post(s)
Liked 27 Times
A dead blow hammer and a block of wood has always worked so well for me that I can't justify buying a press or even making one.
I'll probably change my mind if I ever damage a light alloy cup or crack a head tube.
hello
Here's my $5 headset press. Never 'ruined' a headset using it, even those $120 sets...
la vache fantôme
I have under 4 dollars invested into mine, and have pressed in at leats 5 headsets. I used 3/8-16 threaded rod from home depot, 12 inch length i think. Then i got the largest diameter washer i could find, and just kept going down. Using a bit of duct tape, i taped them all together. Now with the largest washer i can find i always ensure there is pressure on the cup. If i was concerned, i would get rubber padding or brass like other posters suggested
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
Bikes: Colnago Altain, Klein Pulse II, Stumpjumper FSR, GT Zaskar LE, Pedalforce RS2
Darn ingenious. I am impressed with the resourcefulness of you all.
I've been using a bearing press designed for VW front bearings. But I've been using Allthreads for some stereo shelving and your designs make a lot of sense.
Now what do you guys use to install the lower bearing race on the forks?
I've been using an old Kalloy Uno 30.4mm seatpost which no one in this world ever uses except for old Supergo Access MTB frames.
I removed the seat clamp and then slide it over the steerer tube. It rests on the flats of the bearing race and I lightly tap on top of the seatpost to push the bearing race into position.
98 Colnago Altain
08 Pedalforce RS2
00 Specialized Stumpjumper FSR
06 NYCbikes Single Speed (John Deere Special)
98 Colnago Altain
08 Pedalforce RS2
Thanks for all the tips, guys. I was on the right track, but I never would have thought of the brass bushings. My inexpensive homemade press is well on its way to years of infrequent use.
Liked 4,219 Times
To remove the cups, I cut an old steerer off of a broken fork, cut 4 slots in it with a dremel, flared the slots slightly and popped it into the head tube. It works just as well as the Park headset remover (the Park isn't superior to this one, just prettier )
Stuart Black
Stuart Black
Bikes: Too Many
Originally Posted by Lunigma
yeah i was going to do that, but i got ahold of a really nice headset. and i don't want to ruin it. by the way i think that the park tools tool kinda looks like what you suggested, just nicer looking
What are you going to do with it - carry it around the mall to pick up women??
Bikes: paratrooper, bullhead, cdale bad boy
Nashbar makes a fine headset press that I have been using for a few years now. If you wait they normally go on sale for about 45.00.
