tooth implant
#51
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
In case you're about to get a dental implant, ask for one with a "true Morse taper". They have a higher success rate, as they prevent infiltration and bacteria growth that causes bone loss, decay, and possible failure.
I'm going through an implant now, as the dental surgeon explained to me the virtues of the "true Morse taper" design.
The "Morse" in "Morse taper" is named after its inventor, Stephen Morse, a distant cousin of mine.
Likes For terrymorse:
#52
Quoted: 811 Post(s)
Liked 1,024 Times
The same Morse taper that milling machine, lathes and similar machines use? Of course, they work great in metal working machines. That is why they have hung around for so long. Why mess with success?
I'll just add that I have to places in my mouth could use implants but, I'm waiting since they are less visible. It is not just money. I'm holding out for better outcomes.
My dad had implants for 20 years but the bone eventually deteriorated and he had to get new implants/bridge put in. The dentist, proclaimed that they did pretty good lasting 20 years. The one thing is that my dad is a cigar smoker and this may also affect the health of the bone in his mouth.
The dentist and oral surgeon teamed up and performed this procedure again at 94 year old. The new one are not Zirconia though.
Likes For Velo Mule:
#53
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I have no implants in my mouth. But I do have 2 bridges that have been in place since 1984. My dentist, recently retired, told me many times that I must have the world record for life span of that type of bridge, known as a Maryland bridge. I had another bridge that had to be removed due to recession of the gums around the anchor tooth. That tooth is also gone. I have 4 crowns that had to be replaced after 20 plus years. My youngest sister has been going through the process of implants, but one of them failed, so has to be redone. I did not say anything to her, but she is a smoker, and I suspect that could be the cause. I gave those up shortly after having all that dental work done. Velo Mule, I find it amazing that your Dad was able to have that work done at 94.
Likes For delbiker1:
#54
Quoted: 811 Post(s)
Liked 1,024 Times
Are Morse tapers also the same tapers that are used for tie rod ends, ball joints and flywheels on small engines? They lock in nice and proper.
#55
climber has-been
Liked 3,567 Times
Stephen Morse also invented and patented the twist drill bit, founded the Morse Tool Company, then was fired by the board. Then he moved to Pittsburgh and started the Morse Elevator Company.
#56
Quoted: 5224 Post(s)
Liked 3,584 Times
yesterday was new tooth day. I have my complete smile back & can chew any way I want. woo hoo! for the time being anyway ... hehehe
