recommend a truing stand
nothing: lasts forever
i've done a few wheel builds the old fashioned (crappy) way. they've turned out fine, but i'm thinking of investing in some phil hubs, so naturally i want to do a good job. i'm looking for a truing stand in the neighborhood of 40-80 bucks. i don't need perfect, i just need more precise than eyeballing brake pads.
I, too, have the PerformanceBike Spin Doctor truing stand and find it good enough for everything I ever want to do with my wheels. I can get very precise truing of my wheels. It's not in the same league as a Park professional stand, but unless you're building wheels for a living I think the cheaper Spin Doctor is fine.
-Kevin
-Kevin
spin doctor is very accurate. The Park pro will be much faster, since its so sturdy and the autocentering mechanism. But the spin doctor works very well
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
Senior Member (Retired)
Bikes: Vittorio, Centaur triple; Casati Laser Piu, Chorus Triple.
My TACX T3175 is great for the amount of use it gets truing wheels. I might spring for more if I were building wheels.
Though not as precise as above, I use an old Schwinn frame and fork flipped over to true my wheels...using a zip tie or two and a magic marker.
All you do with an old frame is cold set the rear stays to 130mm to accomodate the wider cassettes of later wheels. Front forks are all 100mm so need to change up front.
A truing stand is handy if you true a fair amount of wheels which I don't.
Good Luck...this weekend am truing my Campy Vento rear wheel which is relatively new and wasn't true from the factory.
George
George
Bikes: Voodoo Wanga, Waterford RS, Gitane SS
I have the consumer Park (TS-7) and it works well. It came with a dishing tool also. Not as sturdy as the pro model Park makes, but it gets the job done.
Park now makes a TS-8 model which I have not used yet. Any feedback from this model?
Bikes: Lemond Alpe d´Huez, Scott Sub 10, homemade mtb, Radlbauer adler (old city bike), Dahon impulse (folder with 20 inch wheels), haibike eq xduro
I have the consumer Park Tool (TS-7). It is not bad value for money as you get the dishing tool as well and it does work but I would not particularly recommend it. It is immensely heavy yet unstable and has to be bolted down to use it properly. You can only work on one side of the wheel at once. I also have difficulty getting my axle fixed straight in it and use extra washers to make sure the axle goes in straight.
only the dead have seen the end of mass motorized stupidity
Plato
(well if he was alive today he would have written it)
Plato
eeeh i tried the TS-7, its HORRIBLE. It looks nice, its very beefy. But it only trues one side and checking radial error is a pain. I cut my truing time in half when i got the spin doctor
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
I have the Park TS-2 truing stand and WAG-4 dishing tool. Both are very solid tools, and easy to understand and use. They are, however, more expensive than the "home mechanic" grade tools. Since I don't have a car, I have a few thousand dollars per year to splurge on other things, one of those being tools.
![Big Grin](images/smilies/biggrin.gif)
Bikes: Surly Long Haul Trucker
The TS7 has apparently been discontinued by Park Tools (I'm sure you could find it easily out there though) and replaced by the TS8. I'm not sure what the differences are between the two, but it's something else to look at.
https://www.parktool.com/tools/TS_8.shtml
Si Senior
Bikes: Too Numerous (not)
Liked 10 Times
Minoura Workman Pro. I love it. Also consider a spoke tensiometer. I thought I was pretty good at getting a firm even tension. After getting the Park tensiometer and checking some wheels, I discovered I was way off in some places. Guess I'll use the tensiometer to tweak my "feel."
Bikes: 1990 Burley Bossa Nova, 1992 Paramount PDG-70, 1993 Specialized Stumpjumper, 2005 Jamis Dakar XC Pro, 2007 Rivendell Bleriot
Liked 5 Times
I recently got the Minoura workman pro stand.. Havent' used the others mentioned here, but the Minoura seems fine. It's compact (folds up), has a dish gauge built in, and is really cheap (i paid $32 with a Nashbar coupon). Made in Japan too.
Liked 5 Times
I just googled the spin doctor stand, and it looks to me like the Spin Doctor Pro and the Minoura Workman Pro are almost the same stand.. The Spin Doctor II looks a bit different, but still similar.
