Advice on Southern UT tour
Bikes: Trek Madone 5.2
Hello all,
I need some advice, I'm planning on a 2 week bike tour this fall. Below is the route I'm not concerned with the distance or elevation mostly its road condition, and direction of travel. My main concern at the moment is the route thru Cottonwood Canyon Rd, and the route to the North Rim of the canyon.
Here is my gear list:
https://lighterpack.com/r/5mev0c
Her is the route:
https://www.google.com/maps/dir/Bryc...474855!1m0!3e1
Her is the route:
Rhythm is rhythm
As a Utah native, I have been on all those roads, and biked on about half of them. The North Rim of the Grand Canyon is gorgeous and you shouldn't have a problem. Riding over Boulder Mountain will definitely be the toughest climb. Riding to Bullfrog marina will be great, albeit washboard dirt roads. I gotta say it though - you should keep going over to Canyonlands. If you like dirt and solitude, you could ride from Hanksville all on dirt roads to the Maze in Canyonlands which overlooks the Confluence of the Green and Colorado (which i think might be one of the least visited areas of any national park). You could ride the White Rim trail, or just cruz through Moab to Arches. The roads are probably a little more crowded in that area but really awesome. If you like hiking then check out the Henry Mountains which were the last mountain range mapped in the United States. Or you could spend a couple cool nights on top of Boulder mountain where there is a lot of good camping. The possibilities in the area are literally limitless and you could spend years down there never hiking the same gully twice.
Suggested reading:
Desert Solitaire by Ed Abbey
A Vagabound for Beauty by Everett Ruess
Have fun and hope to see you out there!
Suggested reading:
Thanks MAX5480,
From Hanksville to The Maze? Sounds interesting, but I could continue thru Island in the Sky back to Moab? I've seen the confluence from the Needles side on the beginning of a 5 day back-country trip. I have also been to Horseshoe Canyon which I believe is The Maze.
Are these roads doable with my road bike?
40 yrs bike touring
Bikes: Bruce Gordon Ti Rock N Road [1989], Fat Chance Mountain Tandem [1988], Velo Orange Neutrino (2020)
Liked 6 Times
What tire size maximum for your Madone? I remember lots of soft, rocky and loose conditions on the Canyonlands area routes mentioned above. I was glad i used 700x47 tires.
700x28 which should be good for the established route I showed you? Did you do these on a mountain bike?In particular have you biked the Cottonwood Canyon rd?
Rhythm is rhythm
28s will not be wide enough for the Burr Trail road. I would definitely not do that. I had 2.25" Schwalbe big apples when I did it and wouldn't go less than 1.75" in a pinch. Ideally 2" or fatter. Especially not on a Madone. Sorry to burst your bubble.
40 yrs bike touring
Liked 6 Times
After Long Canyon along the Burr Trail to Bullfrog Ferry i had some very soft sand for a mile or two. Even the pavement is rough there and eats up tires under loaded riding. I then took ferry across to pavement on 276 then heading through Canyonlands on the way to Crested Butte.
I would choose a different bike with wider tires than your 28mm max on your Madone to allow more freedom of route choice. Have a great ride through some lovely country.
*Bruce Gordon RockNRoad w/700x47 tires
Bruce,
I don't have any bike options the road bike is the plan. Since you have done that road to the ferry is it doable on the Madone with 28's? I don't mind pushing several miles thru sand if the majority of it is doable with my Schwalbe Marathons.
Has anyone done Cottonwood Canyon rd lately?
Max,
Thanks for the "local" advice, any thoughts on revising the route to include a better scenic option if in fact the Burr Trail is not an option?
Don't let the road bike fool ya, I'm up for any challenge!
40 yrs bike touring
Liked 6 Times
The Burr Trail switchbacks crossing the Waterpocket Fold is the main problem due to sandy conditions over 3 miles then 8-10 miles of graded dirt and some gravel before you reach pavement and then over 18 miles to Bullfrog.
I have not been through there for five years. My knowledge is ancient for your specific purposes. An e-mail to the rangers at Escalante or Boulder or Capitol Reef NP may provide the best current conditions information.
