Do you take a Spare tire on your bike touring trips???
Bikes: Surly LHT 26in 52cm 2008
How to Fold a Bicycle Tire
I plan to take a Spare tire on my bike touring trips!
and I use 26X1.75in
How to fold a Tire
Fold 1
Fold 2
Fold 3
and I use 26X1.75in
How to fold a Tire
Fold 1
Fold 2
Fold 3
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
Yes, but I carry a folding tire with Kevlar beads. Much lighter and easier to fold than a wire bead tire.
Your photo is for a tire with wire beads. Who buys heavy tires? Just roll up a kevlar bead tire. I just carry 2 tubes, a patch kit and some duck tape to boot a tire if needed.
Depends. If I'm going where I know there are no bike shops, I bring a spare folding tire, otherwise I always try to have two new tubes along.
Uber Goober
On randonneuring rides, I've not carried a spare tire on the single bike, always have on the tandem. After 3 years or so, that finally paid off when I had a tire on the tandem blow through right at the bead.
So just depends on how far from civilization you'll be, how much you're willing to hitchhike or whatever.
Ideally, you use Kevlar-bead tires all the time, then save one that's pretty worn but still usable, and use that for a spare.
But in my case, I didn't have any like that. I normally use 32mm tires on the tandem, and carried a folding 28mm for a spare.
Perhaps equally likely to be a problem- that was the first time I EVER needed a tire like that- but I have broken the shaft on one Road Morph pump, have lost the little end cap that holds the insert on another, have seen another rider do the same thing, have seen another rider with some other pump that wouldn't work. IE, based on my experience, you're more likely to need a spare pump than you are a spare tire. Or, if you carry CO2 instead, well, I've seen people have 5 or 6 flats in a day's ride, too, so still a possible issue.
If you ride in a group with friends, that'll save you in a pump failure and MIGHT save you in a tire failure. If you're using some oddball tire size, beware, though.
Quoted: 18596 Post(s)
Liked 16,096 Times
Took one for the first time in June because I had planned to ride a stretch of rough dirt in a remote area and my tires already had some miles on them, but not enough to ditch.
Yes.. and I used it .. sidewall on rear gave out . abandoned it in a tractor shed in Scotland.
heavy steel bead tires dont work like a thin 700c /27" in that bandsaw blade like fold.
but tying the sides close U shaped the tire to drape over my panniers..
of course buying a Kevlar bead spare tire will fold flattish.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 13042 Post(s)
Liked 7,970 Times
For spares I usually take two tubes and one tire. Patch kit also.
I typically take folding bead tires, however.
I do often fold wire bead tires that I purchase, so that I can haul them home in my backpack.
If you're running touring grade tires, in good condition, and not in the outback then dragging around an extra tire is a waste.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
I've kinked a bead trying that trick. The advice I found on BF was "just use it." That led to a tire that didn't seat properly and rubbed down to the steel before I figured it out, took it off and unkinked it. I'm worried about it.
Obligatory joke about trying to lose my "spare tire"
I've noticed something else funny... we all seem to think of folding bead tires as premium, but my local Walmart has a large bike section and all the tires they sell are folders. They need the shelf space, they can sell a complete selection in the space it would have taken for one size of wire beads.
Genesis 49:16-17
Genesis 49:16-17
Bikes: Brompton M6R Raw, Pashley Roadster Sovereign, ICE Trike with Rohloff (SOLD) - Pacific Coast Highway
I have carried a spare tire. I would probably do it again if the trip was long enough, but as it is, my trips are about a week at most. I stopped carrying the spare. I carry at least one, sometimes two tubes. If I have to use a spare tube, I pick up another as soon as possible. I also try to keep a spare tire at home. There's always one on deck, and in a pinch, my wife could send it to me, but on a week long trip, it's unlikely that I have time to sit anywhere waiting for the mail to come. More likely I'd find a way to the nearest town and make due with whatever the local bike shop has.
bicycle tourist
Depends where I'm going and how long.
When going only a week, I'll usually carry a spare tire. I don't bother with shorter weekend overnight rides. When I've gone for multiple months at times I've carried two spares.
For example, cycling around Australia nothing in way of bike shops between Mt Isa and Katherine ~1250km. In that case, I forgot to get an extra spare and my tires were well worn by time I arrived in Katherine: 284 so in that case, I ended up getting two replacements...
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 16 Times
Tubes, definitely. Tire maybe. I am a thrifty soul and hate to swap out a tire that still has life left in it. If I think it will wear out before the tour is over I may take a spare, or put the new one on and carry the old one as a spare. I carried spare tires on most of my tours in the 70's and 80's. The new tires are much better and have kevlar in them, that along with tires being readily available along with overnight delivery to most of the world it is much less of an issue these days.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Mad bike riding scientist
Quoted: 6295 Post(s)
Liked 4,331 Times
Yup. If you are touring in the US or Canada, you can even get bicycle tires at Helmart. No need to carry spares.
Stuart Black
Stuart Black
just another gosling
Quoted: 3920 Post(s)
Liked 1,991 Times
I carry a spare tire on sport rides. I've lent it out more often then I've used it myself. Sure beats a long walk or trying to hitch. Lent it to a cyclist on a long mountain ride just a few weeks ago. She was walking and it was near 100°. Doesn't need to be your standard touring tire. A 200g 23mm tire is fine.
Quoted: 613 Post(s)
Liked 292 Times
It used to be tough finding a 700c tire in any width at a Walmart or the like, but 26" tires were always available so it depended on which bike I was using as to if I would carry a spare or not. I was amazed that up until a few years ago, a 27" tire was still more available than a 700c at these big box stores but I think recently the situation has righted itself.
Bikes: everywhere
Liked 7,970 Times
Bikes: everywhere
Liked 7,970 Times
Quoted: 613 Post(s)
Liked 292 Times
You're exactly right, a friend of mine needed a modest 700c tire on one of our mini tours and all we found at the local wallyworld and one other smaller sporting goods store were too large for his chainstay length and so we ended up using a Gawd awful amount of Gorilla tape to keep the tire together and on the rim. It was ugly, rode like garbage but got us back to our vehicle the next day.
