Touring UL, how to do it?
Platform pedals
No fenders
Lighter tires
Down quilt
2 panniers only, pockets removed, no straps
Lightweight kitchen
Minimal stuff sacks
Minimal clothing
Lighter weight tent stakes
Lost 20 lbs of body weight
In the process of upgrading to lightweight handlebar bag
I may also try Arkel Dry Lite panniers
No fenders
Lighter tires
Down quilt
Lightweight kitchen
Minimal stuff sacks
Minimal clothing
Thanks
I use some rei ground hog stakes, maybe 6" and a thin triangle cross section design. Pretty light.
Bikes: 2015 synapse
![](https://i.imgur.com/mlOzjMBh.jpg)
There's the bike & cold weather setup for a mini-tour. Same setup I'd carry on a full tour except I'd bring a few more clothes and some more charging cables.
Top tube bag has snacks, phone, $$.
Water bottle pod held food and my repair kit.
Frame bag held a 20000mah battery and charging cables, food, and clothing accessories I want access to without getting out of the saddle, stuff like warm and cold weather gloves, headband etc.
Rear bag (revelate viscacha) is where I kept my shelter and additional cold weather layers I'd need at night. Tarp and hammock for this trip.
Some things that help me stay light:
-Low spoke count wheels with 25mm tires.
-Road bike not overbuilt for touring with loads heavier than I plan to ever bring.
-Frame bags instead of racks. Shaved at least a pound and a half just from ditching my old rear rack and bag for the viscacha.
-Single water bottle.
-No cooking gear, buy ready to eat food and eat while I ride, stop in a restaurant for a hot lunch or dinner once a day.
-Barebones repair kit. Spare tube, single tire lever, mini pump, three hex keys. Might make some nervous but its gotten me over 5k miles safely.
-When its cool enough bugs are no concern, hammock + tarp for a simple, lightweight shelter.
-Minimal clothing. Bring liquid soap and wash your clothes in sinks and under spigots as you travel.
-Bring minimal to no luxuries. For me those items are a bluetooth speaker, the smallest go pro model, and a super light bluetooth gaming controller so I can unwind with some NES/SNES/GBA/PS1/PS2 games if I want.
What about the durability of the dry lite panniers, they are super light. And I'm going there about the platform pedals. Clipped in for me. I have yet to decide on fenders. I'm a slob in recovery, I need the stuff sacks to try to be a bit more organized.Ti stakes are pricy, not sure that I'm willing to go there for an oz or 2.
Thanks
Thanks
Zpacks has UL stuff sacks. Freezer bags are even better since you can find what you want more easily (e.g. tools and toiletries). Zpacks stakes might be inexpensive too, not sure. Sometimes you sort of have to upgrade because the stakes that come with tents are weak and heavy.
While I don't go UL, I have been cutting some weight here and there over the year, particularly in the area of my tent. The Big Agnes aluminum stakes that come with their SL and UL tents are very light. You might want to check their web site to see if you can purchase them separately. I just picked up the Fly Creek UL2. The packed weight, including 11 SL stakes, is listed at 2 lbs. 5 oz.
Clark W. Griswold
Liked 4,279 Times
What is your definition of lightweight? What kind of bike do you have or are you looking for? Your budget?
If you want to go lightweight I'd start by making a detailed gear list with weights.
Try to get your big 4 things (shelter, sleeping bag, sleeping pad and cook set) to total less than 5 lbs.
Take fewer clothes
Try to avoid things like cast iron pans, SLR cameras, multiple electronic devices and guitars.
Use compression sacks to reduce volume.
Know your route. If you will be riding for weeks away from resupply you need to pack more food. If there are towns on the route there is no need to carry multiple cans of food and 2oz of shampoo can be replenished at the pharmacy "tester" section.
Take fewer clothes
By itself, that is the kind of thing that adds weight, and work. It could be part of using a smaller rack or pannier set-up which might save weight. However compression sacks are heavier, and presumably this all starts with too much gear.
It is the general problem of featuring up.
The main thing is to set your bike up for a trip to the barber, and then shoot a lot of photos with some trees in the background.
Seriously though here are 3 strategies that are simple and work:
- Learn about UL backpacking, there are some good books like Ray Jardine's, and if time is no object lots of forums. Main point as above is to get core gear down to a small number.
- leave behind categories, this hurts, but if it is only a few days or weeks, it isn't normally a biggie and may have experience value. So the first UL tour I did I left all cameras and cook gear. It is a lot easier and cheaper to simply go cold turkey, and I didn't miss either. Over time I got lighter gear, though I still don't bother with cooking as the best time for me to tour is during the harvest.
- If you are currently riding heavy, just cut your weight in half. If you carry 40-60 pounds 20-30 should not require any special gear to hit, and will give you a flavour of what is possible.
Get real about it. UL touring doesn't really make any sense other than for gear hogs and fantasists. Actually, I may be the only person here who is real about it here. I started in 05, and did it because I was under threat of a bypass. I finally had the heart attack this September. But UL allowed me to keep riding for a decade. Not having a whole toothbrush (I do) is better than having a heart attack. But aside from that I see no convincing benefit to UL. In backpacking where resupply can be days or weeks apart, and you carry the gear on your back, and you walk, it is life changing as I discovered as a healthy young guy in the 70s, back when we carried monster packs. In the Himalayas or on a 1 day ascent of El Cap it changes the whole calculation. Messner climbed Everest Solo by a new route, without oxygen or 100 porters with a pack with very little in it. That totally changes the world. There is nothing like that for most people to gain in cycling so you have to be careful what you buy into.
Another option might be self guided tour vs guided with support vehicles. In UL you really don't have to carry any more weight, but most people doing those trips have lots of other reasons for travelling in groups than pack weight.
Remember food and water aren't counted. And if you bike tour near services, they really may not add up.
Take fewer clothes
Take fewer clothes
revelate designs viscacha seat bag (pica if you'e really UL)
light weight down bag like this (get summer weight one if you're really UL)
tent like this or bivvy like this (if you're really UL)
sleeping pad like this (get the small if you're really UL)
toothbrush, phone, spare tire & repair kit
Ride the lightest bike you own at least 60 miles (100+ if you're really UL) camp-out one night and ride back.
Then you'll be able to evaluate if you need more.
Bikes: 2015 synapse
Bikes: 2015 synapse
This x5. The most important thing you can do to prepare for a tour it to test out your load on an overnighter. Gives you a good idea of what works, what doesn't, if your packing method is ideal, etc. Experience is an amazing teacher.
You could even go out for a day ride with your gear and then cook/sleep in the back yard .
Liked 3,699 Times
Ok, maybe this will answer at least some of your questions:
99 Ultralight Bike Touring Lifehacks
snip . . .
snip . . .
Bye Bye
A couple of compression sacks will add a few oz, but they are great for packing your tent fly and sleeping bag, which should be in their own bags anyway. Once those two things have been packed everything else can be arrange around them. Two compression sacks allow me to fit most of my gear into the 23 liter Carradice Camper.
So long. Been nice knowing you BF.... to all the friends I've made here and in real life... its been great. But this place needs an enema.
Tent and rainfly(3-season) in blue bag, 25F synthetic bag in green bag, and thermarest in orange bag. Even with Thermarest Pro 4 (4 season) pad, and only counting my share of the tent; my sleeping gear is a little more than 5 lb., including compression sacks, tent poles and stakes. These could fit easily into one pannier with room to spare.
![](https://i783.photobucket.com/albums/yy112/Doug64_photos/Bike%20Trips/Pacific%20Coast/TentandWaterbottle-2.jpg)
Other thoughts:
Fenders- I would not take a long tour without fenders. My wife and I encountered 35 days of rain a few years ago during a 3-month tour. We also rode in Alberta near Calgary right after the floods of 2013. To me fenders are worth the weight penalty. As you might guess I'm also a believer in good raingear.
Mud picked up by front fender on my wife's bike.
![](https://i783.photobucket.com/albums/yy112/Doug64_photos/Bike%20Trips/Vancouver%20to%20Kallispell/e56ac708-e6f1-422b-bdf7-4b4eab4861ea.jpg)
Note how much mud actually made it onto her bike's gear train.
![](https://i783.photobucket.com/albums/yy112/Doug64_photos/Bike%20Trips/Vancouver%20to%20Kallispell/390279f5-2914-490e-a539-eff24207c11a.jpg)
