Do I need to change my crankset to get a 50t chainring?
I have a 2004 Specialized Crossroads Hybrid. The triple chainrings are stock 48x38x28t with a 4-bolt pattern.
The Bottom Bracket is: TH Sport, square taper, 68mm shell, 113mm spindle, sealed cartridge.
The bike has a Shimano 7-speed HG41 (CS725) 11-28t cassette.
I want to see if I can get a bit more speed with a 50t ring, if compatible or available?
I lack knowledge in this area, so I'm not sure what, if any, options I might have here?
A compact crank would be nice, but...?
Any suggestions appreciated, thanks Sumbikerguy123.
Super Moderator
Liked 1,013 Times
48x11 is a pretty big gear. 50 is 4% bigger. How fast do you go ?
I have a 53x12 (about the same as 48x11) and once I hit 40 mph or so downhill, I think I go faster, with less effort by tucking and coasting.
What model crankset ?
I don't know what model the crankset is, only info I could get from the Specialized Archives is: Specialized Forearm. I don't know what this means, if anything?
Best info I can give is in my OP.
Thanks!
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
The TA Chinook chainring is available in 50 tooth 104 BCD but it can be hard to find and will will probably exceed the capacity of your FD. IMHO it's a too big expense for such a small gain.
Edit: Just looked up the bike specs and I'd be surprised if the chainrings aren't riveted on.
R. Thanks! My chainrings are hex bolted together.
My front derailleur is also bolted on, so it can slide it up or down to meet the size of larger ring.
I don't have calipers to correctly measure my BCD, but I rough measured with a ruler an looks like approximately 2.5" center bolt to center bolt across.
I'll check out the 104 BCD Chinook chainring anyway. What expense do you figure this chainring cost?
Thanks again!
Bikes: s-1
total waste of money, you won't really go much faster at all. you could easily spin up that difference by increasing your cadence. if you want to go faster, don't push a harder gear, push a smaller gear around more quickly. SPIN!
with that said, I would say find a bike store that has a spare parts bin, and buy a 53T chainring used for under $10, that way if you don't like it or it doesn't work, you won't be out much money. plus 53 will be different enough from the 48 that you will notice it.
also, tires make a HUGE difference. what kind of tires are you riding? smooth tread, narrow, higher pressure tires will have much lower rolling resistance than knobby wide hybrid tires. this change would make a bigger difference than 2 teeth on the chainring.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Liked 7 Times
My commuter runs a 52-39 double with a 14-32 custom 8 speed rear cassette to best suit me and my present commute. There is one hill I need to the 39/32 combination (with 35-622 tire). 52-14 (equivalent to 48-13) is only useful downhill or with a very strong tail wind.
Mechanic/Tourist
For that 4% larger gear that you can only use downhill you will be raising ALL of your gears with that chainring by 4%, possibly making the 12 tooth slightly less useable as well. You will not go faster - if you can't manage to pedal 4% faster on the 48 tooth the 50 will not make you any more able to put out that amount of power.
Bikes: S-Works Tarmac, Nashbar CX, Trek 2200 trainer bike, Salsa Casseroll commuter, old school FS MTB
R. Good idea, but does anyone make a 53t ring that would fit my 4 bolt ring pattern?
That is NOT the issue - the problem is the radius of the curve on the underside of the FD maybe to tight to work properly with a 50T front ring. Look up the specifications of your front derailleur.
R. Gotcha. FRONT DERAILLEUR: Shimano C-051, 28.6mm clamp, bottom pull
Thanks.
What tires do you recommend?
Thanks.
I recommend the best tire you can obtain, realistically in a 28mm for a hybrid wheel. A GP4000, vittoria open corsa, or any other top level tire will make a real difference in your ride.
+1. I've be n riding my cross bike lately because the weather has been crap, large gear is 48/12. For general riding it's actually a more useful setup for me than my race crank, and have considered switching my other bikes, but when I'm flying downhill or in a fast pack I need that top end that's cut off by the 48.
Bikes: 1996 LeMond Yellow Jersey, 2013 Soma Saga, 1980 Zebrakenko Wind, 1980 Nishiki Ultimate
Sprocket says its a Specialized Forearm Triple too Sprocket: Share
Google search says nothing specific about the BCD of a Specialized Forearm crank though. One way you can tell without measuring is by taking a chainring you know has a 130 or a 110 or whichever BCD and seeing if the holes line up.
