7 speed to 8 speed with just a casette?
Bikes: 1991 Team Miyata, and a 2014 Cannondale Synapse (for sale)
On my Team Miyata I have an 8-speed setup with a 7-speed cassette. I am wondering since the rear spacing is 130mm if I can just buy an 8-speed cassette or if I have to buy a new rear hub and then buy the 8-speed cassette. I am already going to buy a new front hub since it is not Campagnolo (it's a shimano 600 hub) so I am wondering if I need to buy a rear one as well (saves shipping cost, and cost in general to buy both at the same time).
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 268 Post(s)
Liked 339 Times
What rear hub is on the bike?
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
What do you mean by "an 8-speed setup with a 7-speed casette"?
If you have a 7 speed cassette, then I'd call it a 7 speed setup.
Do you have 8 speed shifters and hub, but only a 7 speed cassette (plus a spacer)?
The 1991 Miyata catalog doesn't list a Team Miyata model, just the Team Titanium (which is 7 speeds).
Quoted: 18431 Post(s)
Liked 4,548 Times
Verify you are using a cassette and not a freewheel.
If you have a Shimano hub with a Shimano 7 speed freehub, then most of the freehubs can be replaced with an equivalent 8/9/10 speed freehub, and it isn't that expensive.
Campagnolo or Shimano compatible?
On Shimano hubs, it is possible to run 8 sprockets from a 9 speed on a 7 speed freehub. But, for indexed shifting, it would require 9 speed shifters.
My current setup has 8-speed shifters, it is a Sachs 7-speed cassette. The hub itself is Campagnolo since it was an option from the factory to have Campagnolo Chorus (7-speed). I believe the Team Miyata is on their 1990 catalog.
Quoted: 268 Post(s)
Liked 339 Times
Campy did make a 7sp cassette hub - they're uncommon but they do exist. It appears that you might be able to use a Campy 8sp cassette on it - Cassettes and Cogs - Branford Bike - Seattle/Bellevue - Campagnolo Pro Shop
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,115 Times
There are 8-speed freewheels again now, too.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 268 Post(s)
Liked 339 Times
I just thought of something. Even though you said that your rear spacing is 130mm, the Campy 7sp hub that I once owned was 126mm so you might want to double-check. If it's 126 then you probably can only fit 7 of the 8 cogs on it. VeloBase.com - Component: Campagnolo Athena 7 speed
Quoted: 110 Post(s)
Likely you'll have a 7 speed freehub, which an 8 speed cassette won't fit on. You can buy a new freehub, but costs range from $15-$$$. You'll also want to confirm your hub will take a new freehub. I made the mistake of buying an 8/9/10 shimano freehub for my 7 speed bike before realizing it was a Joytech hub with a proprietary freehub.
I highly doubt that my current hub will accept an 8-speed freehub. I was just trying to see if there was any way that I didn't have to spend the extra money on an 8-speed hub.
Ditto for Campagnolo 7-speed cassette hubs. I have only ever seen one, which I own. I doubt more than 100 of these came over to America. There was never such thing as a Chorus 7-speed cassette hub. There was Athena, but not Chorus.
The chance of you having two very rare products (Sachs cassette and Campy 7-speed cassette hub) together is incredible.
Sachs cassettes are very rare on this this side of the Atlantic. I've never seen one. But I've seen (and own) buckets of Sachs 7-speed freewheels.
Quoted: 268 Post(s)
Liked 339 Times
You have a freewheel hub....not a cassette.
So I've been told... The bike's older than I am. I am trying my best to be somewhat correct.
Quoted: 268 Post(s)
Liked 339 Times
A freewheel is different than a cassette. You can put any freewheel on there that has the same threads....likely BSC or ISO. It should be marked on the hub; IIRC. on that hub it's located where you can't see it unless the freewheel is removed.
Anyway, if it's 130 and if there's clearance between the end of the hub and the dropout then you can fit an 8sp freewheel. But as has been mentioned, the extra length and resulting torque makes for the possibility of a bent axle.
Should I keep it a 7-speed but make it so that it's no longer 13-21t, or should I make it an 8-speed?
Freewheel Medic
Quoted: 1468 Post(s)
Liked 2,233 Times
Yes, that is very much a 7 speed Sachs freewheel and not a cassette. Sachs did make an 8 speed freewheel and I have a few which I used for their sprockets. But looking at the first picture I'm not certain you have enough space for an additional sprocket. It will be a tight fit.
Bob
Bob
Quoted: 268 Post(s)
Liked 339 Times
Here is how it looks on the bike.
