Help identifying drilled Campagnolo crank.
I found this on Yahoo Auction and am tempted to pull the trigger. Can anyone explain to me what the deal is with the "Strada" thing? Is this a Record crank?
More importantly, just by looking can anyone tell me what size inner chain ring the crank is drilled for? This looks too big to be 74 bcd compared to pictures of other cranks drilled for that size on the internet. Looks too small for 100. Are cranks drilled like this safe?
Thanks.
![](https://bikeforums.net/attachment.php?attachmentid=509669)
Thanks.
Bikes: 2012 Moots VaMoots-74 Peugeot Mixtie U018-73 Peugeot U018
Quoted: 17 Post(s)
Liked 9 Times
No, Not safe at any speed. Shy away from this crank. If it breaks, you'll upset the little guy's.
Thanks.
![](https://bikeforums.net/attachment.php?attachmentid=509670)
Thanks.
Moots VaMoots 2012-Peugeot Mixte 1974-Peugeot Mixte 1973
Bikes: Colnago Super, Giant, Waterford X11, Look 785 Huez, Merlin Titanium, in past times...Gitane Super Corsa, Ron Stout, Ciocc San Cristabal, Ciocc CX, Colnago Master, Pogliaghi TT, Crescent
Quoted: 10 Post(s)
Liked 9 Times
This is an old Campy Record crank, pre-1976 or whenever Campy started putting a year number on the back of the crank.
It also is drilled to be used as a triple. Pretty rare even in its day.
Safe? It's a 50 year old bike part YMMV.
elcraft
"Strada" means "Road" as opposed to"Pista" which means"Track" These are Record cranks that appear to have ben drilled (and tapped?) for a triple set up.
Thanks. Can anyone guess what size the inner ring is supposed to be?
This is 74 BCD.
![](https://bikeforums.net/attachment.php?attachmentid=509674)
This is 100 BCD.
![](https://bikeforums.net/attachment.php?attachmentid=509675)
It seems to be neither. Can anybody tell?
This is 74 BCD.
This is 100 BCD.
Quoted: 1628 Post(s)
Liked 635 Times
It's a fairly popular modification, don't know if they're notorious for breakage. It's the cheapest way to add a granny ring to an NR crank, but I think I'd spring for a Red Clover tripleizer ring instead, since I'm in the Clyde range.
Old fart
Quoted: 3619 Post(s)
Liked 3,460 Times
Extraordinary Magnitude
Quoted: 2612 Post(s)
Liked 1,733 Times
Quoted: 18463 Post(s)
Liked 4,568 Times
Those cranks appear to be without a date code, so they would be from the first decade or so of production.
I'm guessing maybe 85 or 86 BCD based on attempting proportional measurement in Gimp. Assuing 144 bcd for outer rings, I think the PISTA cranks were 151.
Almost certainly an aftermarket modification.
Thanks. 86 seems to be correct. I managed to find this image of a Record crank drilled for 86 and it seems to match. Now where to find a 30T 86 BCD chain ring?
![](https://bikeforums.net/attachment.php?attachmentid=509702)
Liked 4,568 Times
You didn't ask for cheap did you?
Stronglight Chainring 30T Black Anodized Road 86 BCD 3 32" Vintage Bicycle | eBay
I'd get the crankset in hand before ordering parts. 85bcd is also a possibility, and you should try to measure.
New 30 Tooth Gipiemme Aluminum Chainring 85 mm BCD | eBay
New 28 Tooth Gipiemme Aluminum Chainring 85 mm BCD | eBay
New Gipiemme 32 Tooth Chain Ring 85mm BCD Fits Old Shimano Deore Takagi Triples | eBay
For the 86's. For some reason I missed the UK sellers with my first search![Frown](images/smilies/frown.gif)
30 Tooth SR Sakae 86BCD 3 32" Chainring | eBay
32 Tooth 86BCD 3 32" Chainring | eBay
Sugino Chainring 32 T Triple Inner 86BCD 3 32" Vintage Touring Bicycle | eBay
Stronglight Chainring 32 T Triple Inner 86BCD 3 32" Vintage Touring Bicycle | eBay
1982 SR Super Custom JIS Triple Touring Crank 86 BCD 26 45 50 | eBay (take what you need, resell the rest, inner ring is a 28?).
Stronglight Triple Chainring 30T Inner 86 BCD 3 32" Vintage Road Bike MTB | eBay
