Difference in frame sizes and bike geometry
Old 03-31-16, 05:09 AM
azza_333
azza_333's Avatar
Bikes: A few
Liked 3 Times in 3 Posts
Again sorry about asking more silly questions, but I don't really know much about bicycle geometry, I do hear that it gets very technical though.
I am trying to pick a new frame, I had a look about Surly Disc trucker, 520, Fuji touring, AWOL, I decided I like the Kona Sutra the best(although I hear very good things about the disc trucker)
I owned a 53cm 2015 Kona Sutra, on this I had a 110mm 6 degree rise stem, and I had not that much of the seat post showing.
KONA BIKES | 2015 BIKES | FREERANGE | SUTRA
For the 2016 Kona Sutra, their website recommends 3 sizes for my height range 168-180cm (I'm 173cm)
The 3 sizes are 52, 54, and 56cm
KONA BIKES | 2016 BIKES | SUTRA | Sutra
Now to my question. How much difference will I notice in the frame sizes, I will want to be able to run a seat post bag that needs 5inches of exposed seat post, which I was pushing it with the old 53cm frame. my LBS doesn't stock Kona bikes, so I would have to order a bike online without testing out the frame size first. Or I may just wait until the 2017 bikes come out.
azza_333 is offline
Old 03-31-16, 06:57 AM
nun
Bikes: Rivendell Quickbeam, Rivendell Rambouillet, Rivendell Atlantis, Circle A town bike, De Rosa Neo Primato, Cervelo RS, Specialized Diverge
Liked 43 Times in 40 Posts
What is your inside leg measurement?......pubic bone to floor.....and what is the length of your torso?
nun is offline
Old 03-31-16, 07:16 AM
azza_333
azza_333's Avatar
Bikes: A few
My inseam? everytime I measure it changes, but its between 77-79cm barefoot.
I will most likely be buying 170mm cranks if that helps, since Shimano don't seem to make 167.5mm in the XT trekking groupset.
azza_333 is offline
Old 03-31-16, 07:34 AM
chasm54
The crank length is immaterial to what you're asking.
A rough guide is to measure your inseam accurately then subtract 25cm. So if your inseam is 77cm a 52cm frame would be a good place to start, and a 56cm would almost certainly be too big. If you are between sizes it is usually better to go for the smaller one.
How much seat post is exposed depends in part on whether the bike has a sloping top tube. A traditional horizontal top tube will mean less seat tube being exposed.
chasm54 is offline
Old 03-31-16, 07:38 AM
robow
robow's Avatar
Liked 292 Times in 200 Posts
According to the geometry charts offered, your 2015 has a seat tube length of 53 cm and the nearest in the 2016 line up is the Med. with a 52 cm length seat tube so you would gain an extra 1 cm of exposed seat post theoretically. The next size larger, the M/L has a 54 cm seat tube so you would lose another 1 cm of exposed seat tube. The new medium frame is definitely closest to what you have now in terms of reach and stack and a 110 stem is a solid average length that is neither too short nor too long, soooo bottom line is, if you feel your present frame fits you well, go for the M.
robow is offline
Old 04-01-16, 03:29 AM
azza_333
azza_333's Avatar
Bikes: A few
I might go with the 54cm them just to get that little bit more reach, and head tube length.
azza_333 is offline
Old 04-01-16, 07:11 AM
robow
robow's Avatar
azza, you could do that but realize the effective top tube on that 54 will be a full 2 cm longer on the new bike and you may very well need a shorter stem, no big deal since you're sporting a 110 now, unless you're already pretty well stretched out. Look forward to seeing pics.
robow is offline
Old 04-01-16, 07:23 AM
BobG
Liked 121 Times in 84 Posts
Unfortunately your saddle height is pre-determined by your leg length. The amount of exposed seat post will be determined by your "saddle pedal start height" combined with the frame geometry. The only way to add more exposed seat post is to choose the smallest possible frame along with a more sloping top tube. Even with a steeper TT your saddle rear will be the same distance from the rear wheel.
Pictured are my 52cm Litespeed with level TT and 41cm BG Rock & Road with steeply sloping TT. Identical pedal start heights. Seat bag clearance to rear wheel is identical on each. Of course a bit closer clearance on the bike with rack and fenders but same distance to wheel.
As an example, a Revelate Viscacha requires 9.5" clearance between rails and tire. I only have 8.5" on either bike despite the difference in seat post extension. Short people just have to ride closer to the rear wheel. Aside from going to 26" wheels altering frame shape will never change that!
BobG is offline
erbfarm
25
04-16-20 10:16 AM
frofro
Commuting
26
02-20-19 01:58 PM
3speed
Fitting Your Bike
14
12-14-17 12:26 PM
bbelo
Fitting Your Bike
2
03-08-17 10:20 AM
WizardOfBoz
General Cycling Discussion
17
01-26-17 08:02 AM
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
