Question about tire brands
Hello All,
It is new tire time, as have worn through the outer rubber and the poly-belts of my tires. I would like some advice of which brands are better. I probably can't afford the very best. But I am wise enough to know that I certainly cannot afford to buy the cheapest either. I need a 26 X 2.125. I thought of Michelin, but they don't make that size. I thought of Goodyear, but their 26's "fit" multiple widths (1.75 - 2.125), per their packaging, as seen on the internet.
I did look thru the other categories for this subject and was unable to find it. I hope you can help.
Sincere thanks,
Paul
Sincere thanks,
Paul
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
All brands have their fans. I couldn't say which is better. I personally like Avocet, but they've been out-of-business for years (I buy good used ones when I can find them!). Names that get bandied about often as being good include Panaracer, Schwalbe, Continental, Michelin, Specialized. There are others as well.
Your bike can fit many different sizes; it does not have to be 2.125 in with width. You can install narrower if you want the bike a little lighter and faster, or wider for more traction and comfort. What kind of bike is it?
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
I presume this is a mountain bike. If you are using it mainly on pavement as a commuter, I have used the Kenda K193 Kwest (smooth pattern, actually modeled off a motorcycle tire, also had it on my Honda ) which I really liked, tough and smooth rolling. I switched those up to the Forte Gotham when I moved to using the bike more on clay and limestone trails, bit more aggressive tread to counteract slickness when wet, and a bit narrower too. Both were infinitely nicer to ride on than knobby MTB tires. Neither were expensive, got the Kendas from a local sporting good chain for like $11, and the Fortes were $12 IIRC.
Quoted: 18576 Post(s)
Liked 16,037 Times
Pirelli.
Liked 2,574 Times
Well, I'll be!
Although I couldn't find anything on a Goodyear website about their tires, I found a lot of press heralding their return to bike tire manufacturing. But you're right. Who really knows who makes what. I was a GE appliance tech for a couple decades and it blew my mind how much the manufacturers bought and sold to one another, then re-branded.
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
Schwalbe, Continental, Panaracer, etc. Since you ride on the street any tire with a kevlar belt to protect against cuts and punctures should be good.
Liked 81 Times
A vote to stick with something smooth treads, then. Simply amazing how much going from knobbies to smooth tread improves a MTB on pavement, even if you don't take down the width at the same time (always liked the cushion the Kendas provided at 1.95").
The Kenda Kwest mentioned above are decent budget tires; we stock the 26 x 1.5 at the co-op for people who want their mountain bike to roll more like a hybrid.
Quoted: 4560 Post(s)
Liked 2,804 Times
Bike Tires Direct has Michelins in 26" and 1.4" (Wild Run'R slicks) to 1.75" widths (Country Rock all around tread) for around $15 or less apiece. Both get good reviews from folks wanting something pavement friendly for their mountain bikes. I can see why -- I briefly road a bike with knobbies just around a parking lot a few days ago and wouldn't want to ride those more than a mile. Felt like half my effort was going into tread squirm.
SE Wis
Quoted: 2755 Post(s)
Liked 3,427 Times
Liked 81 Times
So in other words, they'll be the exact same thing as my Fortes, some Cheng Shens with a Goodyear sticker stuck over the CS branding.
Super Moderator
Quoted: 1174 Post(s)
Liked 936 Times
Consider a smooth tread, and narrower, such as 26 x 1.75 or so.
No wonder they had nothing to say about it on their website! They have nothing to do with it... Deception. Renting out one's good name for a few bucks spoils one's good name.
Quoted: 1071 Post(s)
Liked 804 Times
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,582 Times
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
So many to choose from. If you are riding mostly pavement, 26 x 1.5 to 2.0 is fine. Go with a smooth tread. You can find adequate tires from about $20 to $30 a piece.
A few brands, models that come to mind are the Kenda Kwest, Panaracer Ribmos, Geax Street Runners, Michelin City, Schwalbe Marathon Plus. Other brands that are known for quality are Continental, Specialized, Vittoria (Geax is owned by them). This is far from an exhaustive list. You could even look for budget choices, like Nashbar, which will sometimes offer their house brand tires at a good price.
Based on what I read about Good Year bike tires, I would stay away from them except in an emergency situation, like maybe you had a catastrophic tire failure just outside a Wal Mart and the nearest bike shop is a hundred miles away.
Your decision how much you want to spend. Something like the Schwalbe is expensive but close to bulletproof. Might be overkill for what you want to do, but might be worth it if you are going on an unsupported cross country tour. Kenda or Geax are decent budget tires and should last a number of years without trouble but won't be as resistant to punctures as the Schwalbe. Panaracer is somewhere in between.
I ended up buying a Schwalbe Big Apple 26 Inch Performance Line Tire. It is a 26 x 2.35
I went wide because the tire description mentioned that it was E-Bike ready, as mine is an e-bike.
And it is rated up to 300 lbs. As I weigh about 250 and carry a backpack that weighs about 35 lbs, as well as sometimes picking up cargo while I'm out, I figured that weight rating would be a good thing.
Thanks very much for all your advice. Because of you, I shopped only the brands mentioned & I shopped at biketiresdirect-com. That was good because they were having a sale and I saved over $10 on tyre and tube.
Greatfully yours,
Paul
Greatfully yours,
Paul
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
What I can't figure out is why a company like Goodyear who makes really good car and truck tires would want to make schity bicycle tires? You would think they would go the same direction as Conti and Michelin who make quality bicycle and car tires, and keep their image intact. But that's just me, I guess I'm silly for thinking that way.
