Trek Shift 2 vs Giant Sedona DX
Bikes: 2017 Giant Sedona DX
So, like many others, I'm new here and getting back into biking to lose weight and for overall fitness. I will mainly be riding the neighborhood and local greenway trails. All paved. I would like to work up to a trip on the Katy Trail (packed gravel). I'm 40 and check in around 250. I currently have a cheapo Walmart MTB. The biggest problem with it is, well, its just not very comfy. I have to lean forward too far and i stay stretched out. So, after some research at a couple lbs, I think I have narrowed down my search to two bike. Trek Shift 2 and Giant Sedona DX. I like the looks (mainly cosmetic finishes) of the Trek better, but I'm not sure that is worth $110.00 more. Are there any legitimate or tangible reasons to spend 25% more to get the Trek? Are they really that much better? Thanks for any help and info!
Liked 1,710 Times
I feel ya bro. I started out on a cheap POS Walmart mountain bike back in August, but luckily bought a hybrid which is much easier to ride. Which ever bike you choose you'll definitely be happy to be off the Walmart BSO.
The Improbable Bulk
Bikes: Many
Liked 7 Times
I don't see any need to spend extra for the Trek. In general, Giant is usually a good buy as far as bang for the buck.
I would however suggest a different option. I bought a Sedona DX in 2003, and rode it as my primary bike for a decade, and loved it, except for a couple of things.
1) I did not like the shock, or the suspension seat post. I ended up replacing both with rigid counterparts after a few years.
2) I found myself mildly regretting going with the Sedona instead of the Cypress. Part of my reluctance to buy the cypress was that I preferred the 26" wheels since I weigh over 300 pounds. In hindsight, I would have preferred the 700c, which is part of why I no longer ride the Sedona, I upgraded to 700c. At your weight, 250, I would definitely suggest the 700c wheels on the Cypress. It is basically the same bike with different wheels. The reasons are slightly better rolling, and a wider variety of available tires.
FYI - The Sedona lasted a decade and thousands of miles of mostly gravel, and I broke one spoke and otherwise only replaced consumables for that decade. (Other than the mods noted above for personal preference over the years)
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
I checked out both the Sedona and Cypress at the same time. The Cypress just didn't feel right. The Sedona just "felt" better and was more comfortable. I do like the idea of the 700c better than the 26", but of every brand I tried that had comparable bikes in the 700c vs 26", I felt better on the 26" (wish I didn't though). That's also the main reason I narrowed down the Trek to the Shift instead of the Verve.
So far, then, that is one vote for "no reason to spend more just to get the Trek". Any other votes?
I agree with LD that you really don't need the shocks for riding on the Katy Trail or much of anywhere else short of mountain biking. The suspension seat post was the first thing to go out on a buddy's bike. He weighs a little more than you.
I see one problem with the Trek: It only has a place for one water bottle holder. There are places on the Missouri Katy Trail where water isn't available for many miles especially if you ride during the winter time where water is shut off at many trail heads.
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Liked 208 Times
I am not especially a fan of either bike. The suspension seatpost and fork isn't well suited for a 250 pounder. That said, the Giant looks to have better components than the Trek.
Bikes: 2016 Trek Shift 3
I just ordered a Shift 3 and its nice. My local LBS suggested the Trek Shift, Verve or Giant Sedona DX, Being heavier than you and wanting to sit more upright. The shift 3 has a lockable fork which will be nice.
Thanks for all the input! So, I'm hearing the seat post suspension and front fork aren't necessary, and possibly even considered a negative. I think I'm going to take another test drive, but this time focus on these two components. As long as I don't notice something on this next test drive, I will probably pull the trigger on the Giant Sedona DX. That bike just felt so good. Sounds like the Trek is out of the running due to no reason to justify the higher price. I won't be able to do anything for about a week, so if there are any last minute nuggets of info, please drop them here!
So, i pulled the trigger on the Giant Sedona DX. I had to order it as my lbs was out of stock. No more 2016's available, so mine will be a 2017. It should take about 3 weeks to arrive, so excited! Thanks for all the input! So, now i have 3 weeks to wait, and wait. That should give me plenty of time to think about add-ons. I think i want to go with full fenders front and rear, a rear rack, headlight, tail light, pump, and basic tool/repair kit. Whew, still have a lot of research to do. Google, here i come! If anyone has any suggestions, feel free to jump in a drop some wisdom! Thanks everyone!
Liked 208 Times
RE: Fenders. Do you plan to ride in the rain? If so, fenders are a good idea.
RE: Pump. You need to consider a floor pump, and possibly also a frame pump. Lots of good floor pumps. I use a Bontrager Charger. It is decent, but lots of other decent options from Nashbar (online store) to Topeak Joe Blow, Lezyne. Just a few examples. Any pump you get at a bike shop will be alright, I imagine. As for a frame pump, I use the Topeak Road Morph G, and can't recommend it highly enough. It is almost good enough to use as a floor pump.
You will probably need a multi tool. Lots of different brands. I have a Nashbar multi tool that I bought years ago that is holding up well. you should get a patch kit, tire levers, spare tube, and a seatbag to hold all that stuff, unless you get a rack, in which case you could put that stuff in a trunk bag.
RE: lights. Don't know. I don't have lights on my bike since I don't ride at night.
Also, if you leave your bike, even for a few minutes, you should get a decent lock. A U lock from Kryptonite or an Abus Folding lock are good choices. A cable lock is better than nothing, but is easily defeated by wire cutters or bolt cutters, which a thief could easily conceal in a backpack.
Oh yeah, i forgot about a lock. Add that to the list. I do have a floor pump already, i just need one to carry on the bike. I don't necessarily plan on riding in the rain, but in case i do (or just after a rain) i want to be set up for it. Also, i don't plan to ride at night, but again, just in case. I want to be prepared. As far as a rear rack, just something basic for all around utility, again, you never know.
Bikes: Diamondback Insight, Motobecane Mirage
Liked 5 Times
I found the suspension saddle annoying and got rid of it ASAP, also it was pretty wide, i think they assume the only people buying these "comfort bikes" are big people who want a plush saddle.........but in the long run you want a skinny one for your sit bones to sit on.
So far the suspension seat post is not a problem, and I do like the wider seat (I am a little larger myself). I'm sure with more miles on the bike and less weight on me, I might feel a little differently. Plenty of time to tweak and modify to meet my needs in the future after many miles logged. I'm really diggin' how everything is working out on the bike (including the front suspension). No complaints yet!
