Single speed rear wheel spoke tensions?
Quoted: 16 Post(s)
I'm building a single speed rear mtb wheel with a symmetrical hub, equal spoke lengths on each side. I'm curious if I should tension both sides to where I'd normally tension the DS spokes on a freehub wheel, or if I should drop both sides down a bit so that the total tension on the rim is the same as a freehub wheel?
I.e. set the tension on each spoke to the average of DS and NDS spoke tensions on a freehub wheel.
Quoted: 1074 Post(s)
Liked 295 Times
I do the average thing, and I think it's the most common.
Although I seem to remember one poster here shooting for DS tension both sides.
Not all rims can take both sides DS tension w/o taco-ing.
Be aware that a SS hub might not be perfectly symmetrical, even if it uses the same length spokes.
Last one I built needed a 10% spoke tension difference DS / NDS to center correctly.
That was a coaster brake hub though.
Quoted: 6004 Post(s)
Liked 2,940 Times
On most modern rear wheels, builders bring the drive side tension higher than they'd like. That's because it's the only way to get the left side tension high enough.
On a symmetrical hub, freed form concerns about inadequate left side tension, I drop down to tensions nearer to 80kgf (using 20./1.8 DB spokes). I might go higher with 2.0 straight spokes, but I build with those so rarely that I don't think about much.
FB
Chain-L site
FB
Chain-L site
Quoted: 16 Post(s)
I was thinking something more like 90-100 kg since I'd normally do 120-130 kg on the DS. I can't really find any specs for my rim regarding max tension, mavic xm317 (nondisc). I'm using 36x 2.0/1.8 DB spokes.
